[?]: HOW TO REMOVE SOURCE PROTECTION IN RSLOGIX5000
nene
Post by nene » Fri Jan 30, 2009 10:10 am
How to Know How to Remove the Source Protection in Routines written in RSLOGIX5000
Please Post Thanks
Rudi
Post by Rudi » Sun Apr 05, 2009 4:04 pm
There is nothing to remove. Opposite. You have to add the source protection file and point the source protection routine to that file. Usally the file called sk.dat. So you have to look for the this file on the original machine and then you have to know the password as well in order to remove the source protection.
Good Luck :D
BR
Rudi
LogixGuy
Post by LogixGuy » Sun Apr 05, 2009 5:07 pm
Rudi wrote:There is nothing to remove. Opposite. You have to add the source protection file and point the source protection routine to that file. Usally the file called sk.dat. So you have to look for the this file on the original machine and then you have to know the password as well in order to remove the source protection.
Good Luck :D
BR
Rudi
:? If I had the original machine then the source protection question wouldn't have been asked. If I knew the password I wouldn't ask the question. That's kind of obvious...
I know how to protect my routines. I want to to know (a) how protected they are and (b) if other routines that I don't know the password to can be unprotected.
The Siemens S7 routines are not too hard to find unprotection methods for. I was wondering about CLX
Rudi
Post by Rudi » Mon May 11, 2009 5:23 pm
@LogixGuy
How I could know that you know already everything :mrgreen:
It looks like AB did a good job in that case. I don't know how to bypass that kind of protection neither. On the other hand, I did several jobs too with RSLogix5000 and I don't like the idea, that others take my knowledge for nothing. May you find something interesting, than let me know :lol:
Rudi
nene
souce protection
Post by nene » Tue Aug 18, 2009 6:20 pm
brave engineers who can go out almost all the harder to remove the protection of routine Logix 5k
batuhan1234
very easy
Post by batuhan1234 » Wed Sep 30, 2009 6:05 pm
if you sens to protected program ı can unprotect and send you back. :D :D
nsnali
Re: very easy
Post by nsnali » Sun Aug 14, 2011 12:20 pm
batuhan1234 wrote:if you sens to protected program ı can unprotect and send you back. :D :D
Batuhan, do you mean that you can figure out what the source code is?
brave_eagle
Re: [?]: HOW TO REMOVE SOURCE PROTECTION IN RSLOGIX5000
Post by brave_eagle » Mon Aug 15, 2011 7:46 am
it's not so difficult, Pls. upload your source code
nsnali
Post by nsnali » Wed Aug 17, 2011 5:43 am
I do not have the source code. I know how to edit sk.dat file.
jorger1953
Post by jorger1953 » Thu Aug 18, 2011 3:59 pm
Brave_eagle, how can i unportect the code? If I send to you the plc configuration you can unprotect?
brave_eagle
Post by brave_eagle » Fri Aug 19, 2011 1:11 am
jorger1953 wrote:Brave_eagle, how can i unportect the code? If I send to you the plc configuration you can unprotect?
You can upload your source code to rapidshare or other share host then tell me the link, or you can send your code by mail yt_support@163.com
brave_eagle
Post by brave_eagle » Fri Aug 19, 2011 7:19 am
Pls. converter it to v17
brave_eagle
Post by brave_eagle » Fri Aug 19, 2011 12:01 pm
Hi! deaar friend. I've done the job'
I'll send you the unprotected file by mail
yokesh1987
Post by yokesh1987 » Wed Jan 18, 2012 6:40 pm
please can any share how to unprotect the source protection subroutine block?
arfineira
Post by arfineira » Mon Jun 25, 2012 10:36 pm
Any can to share the procedure how to use Olly DBG to uprotect any subroutine ?
davidsk2001
Post by davidsk2001 » Fri Jul 13, 2012 2:41 am
Can you share how to do it? thank you so much.
Yasir Maqsood
Post by Yasir Maqsood » Fri Jul 27, 2012 7:42 am
Dear Brave,
If you done it, then please share the procedure to unprotect the subroutine of Soure Protection.
YM
mrs_oliveira
Post by mrs_oliveira » Tue Sep 25, 2012 1:51 pm
Hi all,
Anibody have sucess on remove source protection of Add-On instruction?? How to do this?
Thanks for any help!
taleb_nour
Post by taleb_nour » Tue Nov 27, 2012 6:17 pm
please brave_eagle can you share the procedure to remove source protection
TornStar
Post by TornStar » Sun Feb 17, 2013 6:25 pm
How can the source protection be cracked if you don't know the password in the original sk.dat file?
Raza
Post by Raza » Wed Nov 23, 2022 2:37 am
Can you please check your email, i have sent you an email with a password-protected file, help me unlock it please.
Thanks,
Raza.
sqhlxdl
Post by sqhlxdl » Tue Jan 31, 2023 8:09 am
【Rslogix5000 Studio5000 Source Protection Decrypt】 https://www.bilibili.com/video/BV13q4y1 ... f5d85750ce
georgegw
Post by georgegw » Mon Feb 06, 2023 7:46 pm
Good evening to everyone! Can anyone help me with this program to unlock the source key??
The plc program:
https://we.tl/t-LJAzOh0Jr8
Thank you for your time and attention! It is in studio5000 v28 and i converted to v30
danangkarunia77
Post by danangkarunia77 » Sat Mar 11, 2023 2:45 am
hello anyone can help me to remove source protection from my file.
Thanks In Advance
