[?]: PCS7 v7.1 license error
sttrue88
Post by sttrue88 » Thu May 21, 2009 3:18 pm
Dear Comod,
I hope you are well,
I have a problem with license of ,that is ,when I open my OS project ,it is in DEMO mode and when I check which license is needed ,it show the PCS7 WINCC , but I installed the mentioned license and also when I check the license in ALM it showed that in use , but I don’t know why wincc in Demo mode.
Could you please give me some guide line?
if i have your email ,I can send you necessary information.
Thanks in Advance,
Sttrue88
Post by CoMod » Thu May 21, 2009 6:23 pm
try to install "Trial" key PCS7 SIFLPCS7T20701 with PO tags
lhnhan
Re: [?]: PCS7 v7.1 license error
Post by lhnhan » Sun May 30, 2010 8:03 pm
I also have the same error. When i open winCC project, license is 256k tag. But When i start OS from Simatic manager, Wincc license is "DEMO". Then i change to WinCC project , license is 256k. How can i solve this problem? Please help me!
Post by CoMod » Sun May 30, 2010 8:11 pm
lhnhan wrote:I also have the same error. When i open winCC project, license is 256k tag. But When i start OS from Simatic manager, Wincc license is "DEMO". Then i change to WinCC project , license is 256k. How can i solve this problem? Please help me!
I can't help without full info from you - ALM screenshot, info from C:\Program Files\Siemens\WINCC\diagnose
lhnhan
Post by lhnhan » Sun May 30, 2010 8:34 pm
This my license in ALM
my license in ALM
"Status";"Family";"Product";"Version";"Number of license keys";"Standard license type";"License type";"Validity";"License number";"License key";"Order number"
"License key in use";"SIMATIC STEP 7";"STEP 7 Professional Edition 2006";"5.4";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLS7PROF0504";"-"
"License key in use";"SIMATIC PCS7";"PCS 7 WinCC";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLPCS7T20701";"-"
"License key OK";"SIMATIC HMI";"WinCC User Archives";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WARC0700";"-"
"License key OK";"SIMATIC HMI";"WinCC TI Ethernet Layer4";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WC190700";"-"
"License key OK";"SIMATIC HMI";"WinCC SIMATIC 505 TCP/IP";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WC250700";"-"
"License key OK";"SIMATIC HMI";"WinCC Server";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WSEC0700";"-"
"License key OK";"SIMATIC HMI";"WinCC S5 Ethernet Layer4";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WC180700";"-"
"License key OK";"SIMATIC HMI";"WinCC RT (153600)";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WRT80700";"-"
"License key OK";"SIMATIC HMI";"WinCC Redundancy";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WSRD0700";"-"
"License key OK";"SIMATIC HMI";"WinCC RC (153600)";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WRC80700";"-"
"License key OK";"SIMATIC HMI";"WinCC Profibus FMS";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA9WCL60700";"-"
"License key OK";"SIMATIC HMI";"WinCC Advanced Process Ctrl";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1WPC20700";"-"
"License key OK";"SIMATIC PCS 7";"Version Cross Manager";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1VXME0701";"-"
"License key OK";"SIMATIC PCS 7";"TH-PO";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1THPO0701";"-"
"License key OK";"SIMATIC NET";"SNMP-OPC-Server Power Pack";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNOPCSE0701";"-"
"License key OK";"SIMATIC NET";"SNMP-OPC-Server Basic";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNOPCSB0701";"-"
"License key OK";"SIMATIC STEP 7";"SFC for TDC";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1SFCT0701";"-"
"License key OK";"SIMATIC PCS 7";"SFC-Visualization";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1SFCV0701";"-"
"License key OK";"SIMATIC PCS 7";"SFC";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1SFC_0701";"-"
"License key OK";"SIMATIC STEP 7";"S7-SCL V5.3";"5.3";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1SCL_0503";"-"
"License key OK";"SIMATIC STEP 7";"S7-PLCSIM V5.4";"5.4";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1PLCS0504";"-"
"License key OK";"SIMATIC NET";"PROFIBUS SOFTNET-S7";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNSPBS70701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS SOFTNET-DP Slave";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNSPBDS0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS SOFTNET-DP";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNSPBDP0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS S7-5613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNHPBS70701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS FMS-5613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNHPBFM0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS DP-5613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNHPBDP0701";"-"
"License key OK";"SIMATIC PCS 7";"PID-Tuner";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1PIDT0701";"-"
"License key OK";"SIMATIC PCS 7";"Maintenance RT";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLYMAINR0701";"-"
"License key OK";"SIMATIC PCS 7";"Maintenance ES";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLMAINES0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET PN IO";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNSIEPN0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET-S7 Power Pack";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNSIESE0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET-S7 Lean";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNSIESL0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET-S7 Basis";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNSIEPG0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet S7-REDCONNECT";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNIERCN0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet S7-1613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNHIES70701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet PN CBA OPC-Server";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNOPCCB0701";"-"
"License key OK";"SIMATIC PCS 7";"IEA";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1IEA_0701";"-"
"License key OK";"SIMATIC NET";"DX OPC-Server";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLNOPCDX0701";"-"
"License key OK";"SIMATIC";"DOCPRO";"5.4";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1DOCP0504";"-"
"License key OK";"SIMATIC STEP 7";"CFC STEP 7 Sinamics";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1CFCN0701";"-"
"License key OK";"SIMATIC STEP 7";"CFC STEP 7 Simotion";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1CFCM0701";"-"
"License key OK";"SIMATIC STEP 7";"CFC STEP 7 Option";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1CFCS0701";"-"
"License key OK";"SIMATIC PCS 7";"CFC - unlimited";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1CFCU0701";"-"
"Unknown";"SIMATIC STEP 7";"Version Cross Checker";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLA1VCCH0701";"-"
"Unknown";"-";"SIK/SIMATIC Version Cross Manager (Import) V7.1";"7.1";"1";"Single";"Unlimited";"Unlimited";"0420100531";"A1VXMI71";"-"
"Unknown";"SIMATIC PCS7";"PCS7 RC (153600)";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLPCS7TT0701";"-"
"Unknown";"SIMATIC STEP 7";"Device Drivers S7DOS";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00401000002010005031";"SIFLSS7DOS0700";"-"
and this error License.Log
05/31/2010 03:16:00 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
05/31/2010 03:16:00 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
05/31/2010 03:16:21 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
05/31/2010 03:16:21 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | Relevant Limit = 0000000512 |
05/31/2010 03:16:21 Control Center - Demo Mode Runtime enabled -
05/31/2010 03:16:21 NoLicense RT | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | Exists = Yes | Limit Exceeded = No | Emergency License = No |
05/31/2010 03:22:35 ExitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
05/31/2010 03:22:35 ExitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
05/31/2010 03:22:54 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
05/31/2010 03:22:55 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC | Relevant Limit = 0000000512 |
05/31/2010 03:22:55 Control Center - Demo Mode Runtime enabled -
05/31/2010 03:23:45 ExitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
05/31/2010 03:23:45 ExitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | Name of License = SIFLPCS7T20701 | Text of License = PCS 7 WinCC |
Authorinformation.inf file
2010-05-31 03:34:49
License   			installed			needed			to install			Product
SIFLPCS7T20701			No      			Yes      			Yes        			PCS 7 WinCC
SIFLA1SFCV0701			Yes  [MINHANH]		No      			No        			SFC-Visualization
SIFLA9WC180700			Yes  [MINHANH]		No      			No        			Channel SIMATIC S5 Ethernet Layer 4
SIFLA9WC190700			Yes  [MINHANH]		No      			No        			Channel SIMATIC TI Ethernet Layer 4
SIFLYMAINR0701			Yes  [MINHANH]		No      			No        			Maintenance RT (Count Relevant)
SIFLA9WSEC0700			Yes  [MINHANH]		No      			No        			Server
SIFLA9WCL60700			Yes  [MINHANH]		No      			No        			Channel PROFIBUS FMS
SIFLA9WSRD0700			Yes  [MINHANH]		No      			No        			Redundancy
SIFLA9WARC0700			Yes  [MINHANH]		No      			No        			User Archives
SIFLMAINES0701			Yes  [MINHANH]		No      			No        			Maintenance ES
SIFLA1WPC20700			Yes  [MINHANH]		No      			No        			Advanced Process Ctrl
SIFLA9WC250700			Yes  [MINHANH]		No      			No        			Channel SIMATIC 505 TCPIP
Thanks for reply.
Post by CoMod » Sun May 30, 2010 8:52 pm
Install SIFLA9WCP70700 (and SIFLA9WCP70700)
See EKB_Install keyset for PCS7>PCS7 v7.1>
minilnar
Post by minilnar » Fri Jun 04, 2010 9:42 am
I also have the same error. When i open winCC project, license is 256k tag. But When i start OS from Simatic manager, Wincc license is "DEMO". Then i change to WinCC project , license is 256k. How can i solve this problem? Please help me TOO!
06/04/2010 10:42:59 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRP70700 | Text of License = WinCC RT PO (10000) | Relevant Limit = 0000010000 |
06/04/2010 10:42:59 InitLicense RT | AppName = AppRT:Mcp_Server | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WSEC0700 | Text of License = WinCC Server |
06/04/2010 10:42:59 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WRP70700 | Text of License = WinCC RT PO (10000) | Relevant Limit = 0000000512 |
06/04/2010 10:42:59 Control Center - Demo Mode Runtime enabled -
06/04/2010 10:42:59 NoLicense RT | Name of License = SIFLA9WRP70700 | Text of License = WinCC RT PO (10000) | Exists = Yes | Limit Exceeded = Yes ,512 Archive Tags | Emergency License = No | TLG = 0000629 |
06/04/2010 10:43:10 InitLicense RT | AppName = OptRT:SIMATIC PCS7 StoragePlus Server (ALG) | CycleCheck = yes | NameForMessageBox = | Name of License = A1STOP0103 | Text of License = |
06/04/2010 10:43:29 InitLicense RT | AppName = OptRT:SIMATIC PCS7 StoragePlus Server (TLG_F) | CycleCheck = yes | NameForMessageBox = | Name of License = A1STOP0103 | Text of License = |
06/04/2010 10:44:26 InitLicense RT | AppName = OptRT:SIMATIC PCS7 StoragePlus Server (TLG_S) | CycleCheck = yes | NameForMessageBox = | Name of License = A1STOP0103 | Text of License = |
06/04/2010 10:44:36 InitLicense RT | AppName = OptRT:UserArchive | CycleCheck = yes | NameForMessageBox = User Archive Runtime | Name of License = SIFLA9WARC0700 | Text of License = WinCC User Archives |
and license info:
04.06.2010 10:42:39 License_Info start -----------------------------------------------------------------------
04.06.2010 10:42:41 Is PCS7 project -> PO Licensing
04.06.2010 10:42:42 PO Licensing Mode -> POs:306 Tags:11695
04.06.2010 10:42:59 ================TLG RTLimit=======================
04.06.2010 10:42:59 TLG Tags in the project: 629
04.06.2010 10:42:59 Limit in the Licence: 512
04.06.2010 10:42:59 No runtime licence: Type:AppRT:TlgASO Key:SIFLA9WRP70700 -> Activating demo mode
Post by CoMod » Fri Jun 04, 2010 10:03 am
TagLogging RunTime Limit wrote:04.06.2010 10:42:59 TagLogging Archive Tags in the project: 629 Archive Tags
04.06.2010 10:42:59 Limit in the SIFLA9WRP70700 Licence: 512 Archive Tags
You need add Archive Tags license for additional tags for TagLogging - but in this time I don't know how to made it for V7.0.
try SIFCY9WTGX07001 WINCC-V7 Arch 1500 ATg
or decrease Archive Tags count to 512 Archive Tags
mistey
Post by mistey » Wed Feb 15, 2012 2:29 pm
CoMod wrote:Install SIFLA9WCP70700 (and SIFLA9WCP70700)
I have same problem here. In Automation License Manager, there is no missing license.
But in WinCC License Analysis tool :
"SIFLA9WCP70700 | WinCC RC PO(10000) | 300 tags is present, limit is 10000. | ..."
In Authorinformation file :
SIFLA9WCP70700 No Yes Yes WinCC RC PO (10000)
Regards.
Post by CoMod » Wed Feb 15, 2012 5:05 pm
mistey wrote:In Authorinformation file :
:anon: I can't help without full info from you - ALM screenshot, info from C:\Program Files\Siemens\WINCC\diagnose
mistey
Post by mistey » Wed Feb 15, 2012 6:00 pm
License keys.cvs :
License keys.cvs
"Unknown";"SIMATIC PCS 7";"Maintenance RT (10)";"7.0";"1";"Floating";"Count relevant";"10";"00411000002012002015";"SIFCYMAINR07001";"-"
"License key OK";"SIMATIC PCS 7";"Maintenance RT (1000)";"-";"1";"Floating";"Count relevant";"1000";"00411000002012002015";"SIFCYMAINR99997";"-"
"License key in use";"SIMATIC STEP 7";"STEP 7-BASIS V5.5";"5.5";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA171040505";"-"
"License key OK";"SIMATIC STEP 7";"CFC STEP 7 Simotion";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1CFCM0701";"-"
"License key OK";"SIMATIC STEP 7";"CFC STEP 7 Sinamics";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1CFCN0701";"-"
"License key OK";"SIMATIC STEP 7";"CFC STEP 7 Option";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1CFCS0701";"-"
"License key OK";"SIMATIC PCS 7";"CFC - unlimited";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1CFCU0701";"-"
"License key OK";"SIMATIC";"DOCPRO";"5.4";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1DOCP0504";"-"
"License key OK";"SIMATIC PCS 7";"IEA";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1IEA_0701";"-"
"License key OK";"SIMATIC PCS 7";"PID-Tuner";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1PIDT0701";"-"
"License key OK";"SIMATIC STEP 7";"S7-PLCSIM V5.4";"5.4";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1PLCS0504";"-"
"License key OK";"SIMATIC STEP 7";"S7-SCL V5.3";"5.3";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1SCL_0503";"-"
"License key OK";"SIMATIC STEP 7";"SFC for TDC";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1SFCT0701";"-"
"License key OK";"SIMATIC PCS 7";"SFC-Visualization";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1SFCV0701";"-"
"License key OK";"SIMATIC PCS 7";"SFC";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1SFC_0701";"-"
"License key OK";"SIMATIC PCS 7";"TH-PO";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1THPO0701";"-"
"Unknown";"SIMATIC STEP 7";"Version Cross Checker";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1VCCH0701";"-"
"License key OK";"SIMATIC PCS 7";"Version Cross Manager";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1VXME0701";"-"
"License key OK";"SIMATIC PCS 7";"Version Cross Manager (Import)";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA1VXMI0701";"-"
"Unknown";"SIMATIC PCS 7";"PDM Integration in STEP 7";"6.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA3SPBI0600";"-"
"License key in use";"SIMATIC PCS 7";"PDM Basic";"6.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA3SPBS0600";"-"
"Unknown";"SIMATIC PCS 7";"PDM HART Mux";"6.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA3SPHX0600";"-"
"Unknown";"SIMATIC PCS 7";"PDM Routing";"6.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA3SPIE0600";"-"
"License key in use";"SIMATIC PCS 7";"PDM SinglePoint";"6.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA3SPSP0600";"-"
"Unknown";"SIMATIC PCS 7";"PDM (128)";"6.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA3SPT10600";"-"
"License key in use";"SIMATIC PCS 7";"PDM (unlimited)";"6.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA3SPT90600";"-"
"License key OK";"SIMATIC HMI";"WinCC User Archives";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WARC0700";"-"
"Unknown";"SIMATIC HMI";"WinCC S5 Ethernet TF";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WC170700";"-"
"License key OK";"SIMATIC HMI";"WinCC S5 Ethernet Layer4";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WC180700";"-"
"License key OK";"SIMATIC HMI";"WinCC TI Ethernet Layer4";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WC190700";"-"
"License key OK";"SIMATIC HMI";"WinCC SIMATIC 505 TCP/IP";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WC250700";"-"
"License key OK";"SIMATIC HMI";"WinCC Profibus FMS";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WCL60700";"-"
"Unknown";"SIMATIC HMI";"WINCC Interf. S7-PMC";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WCL70700";"-"
"License key in use";"SIMATIC HMI";"WinCC RC PO (10000)";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WCP70700";"-"
"License key OK";"SIMATIC HMI";"WinCC RC (262144)";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WRC70700";"-"
"License key OK";"SIMATIC HMI";"WinCC RT (262144)";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WRT70700";"-"
"License key OK";"SIMATIC HMI";"WinCC Server";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WSEC0700";"-"
"License key OK";"SIMATIC HMI";"WinCC Redundancy";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLA9WSRD0700";"-"
"License key OK";"SIMATIC PCS 7";"Maintenance ES";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLMAINES0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet S7-1613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNHIES70701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS DP-5613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNHPBDP0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS FMS-5613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNHPBFM0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS S7-5613";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNHPBS70701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet S7-REDCONNECT";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNIERCN0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet PN CBA OPC-Server";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNOPCCB0701";"-"
"License key OK";"SIMATIC NET";"DX OPC-Server";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNOPCDX0701";"-"
"License key OK";"SIMATIC NET";"SNMP-OPC-Server Basic";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNOPCSB0701";"-"
"License key OK";"SIMATIC NET";"SNMP-OPC-Server Power Pack";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNOPCSE0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET-S7 Basis";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNSIEPG0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET PN IO";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNSIEPN0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET-S7 Power Pack";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNSIESE0701";"-"
"License key OK";"SIMATIC NET";"Industrial Ethernet SOFTNET-S7 Lean";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNSIESL0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS SOFTNET-DP";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNSPBDP0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS SOFTNET-DP Slave";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNSPBDS0701";"-"
"License key OK";"SIMATIC NET";"PROFIBUS SOFTNET-S7";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLNSPBS70701";"-"
"License key OK";"SIMATIC PCS7";"PCS 7 WinCC";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLPCS7T20701";"-"
"Unknown";"SIMATIC PCS7";"PCS7 RC (153600)";"7.1";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLPCS7TT0701";"-"
"Unknown";"SIMATIC STEP 7";"STEP 7 Professional Edition 2010";"5.5";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLS7PROF0505";"-"
"Unknown";"SIMATIC STEP 7";"Device Drivers S7DOS";"7.0";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLSS7DOS0700";"-"
"Unknown";"SIMATIC PCS 7";"Maintenance RT";"9.9";"1";"Floating";"Unlimited";"Unlimited";"00411000002012002015";"SIFLYMAINR0909";"-"
Authorinformation
Authorinformation
2012-02-15 18:50:46
SIFLA9WC170700			Yes  [PC]        		No      			No        			Channel SIMATIC S5 Ethernet TF
SIFLA1SFCV0701			Yes  [PC]        		No      			No        			SFC-Visualization
SIFLA9WC180700			Yes  [PC]        		No      			No        			Channel SIMATIC S5 Ethernet Layer 4
SIFLA9WC190700			Yes  [PC]        		No      			No        			Channel SIMATIC TI Ethernet Layer 4
SIFLYMAINR0909			Yes  [PC]        		No      			No        			Maintenance RT (Count Relevant)
SIFLA9WSEC0700			Yes  [PC]        		No      			No        			Server
SIFLA9WCL60700			Yes  [PC]        		No      			No        			Channel PROFIBUS FMS
SIFLA9WSRD0700			Yes  [PC]        		No      			No        			Redundancy
SIFLA9WARC0700			Yes  [PC]        		No      			No        			User Archives
SIFLMAINES0701			Yes  [PC]        		No      			No        			Maintenance ES
SIFLA9WC250700			Yes  [PC]        		No      			No        			Channel SIMATIC 505 TCPIP
Post by CoMod » Wed Feb 15, 2012 6:13 pm
Need C:\Program Files\Siemens\WINCC\diagnose\License.Log :?:
mistey
Post by mistey » Wed Feb 15, 2012 7:53 pm
License.log
02/15/2012 20:27:40 InitLicense CS | AppName = DMAso:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) | Relevant Limit = 0000010000 |
02/15/2012 20:27:42 InitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) | Relevant Limit = 0000010000 |
02/15/2012 20:27:42 InitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | NameForMessageBox = | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) | Relevant Limit = 0000010000 |
02/15/2012 20:31:27 InitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) | Relevant Limit = 0000010000 |
02/15/2012 20:31:27 InitLicense RT | AppName = AppRT:Mcp_Server | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WSEC0700 | Text of License = WinCC Server |
02/15/2012 20:31:27 InitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | NameForMessageBox = | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) | Relevant Limit = 0000000512 |
02/15/2012 20:34:01 InitLicense RT | AppName = OptRT:OSStateMachinex | CycleCheck = yes | NameForMessageBox = | Name of License = SIFCYMAINR99997 | Text of License = Maintenance RT (1000) | Relevant Limit = 0000001000 |
02/15/2012 20:46:00 ExitLicense RT | AppName = OptRT:OSStateMachinex | CycleCheck = yes | Name of License = SIFCYMAINR99997 | Text of License = Maintenance RT (1000) |
02/15/2012 20:46:19 ExitLicense RT | AppName = AppRT:Mcp | CycleCheck = yes | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) |
02/15/2012 20:46:19 ExitLicense RT | AppName = AppRT:Mcp_Server | CycleCheck = yes | Name of License = SIFLA9WSEC0700 | Text of License = WinCC Server |
02/15/2012 20:46:19 ExitLicense RT | AppName = AppRT:TlgASO | CycleCheck = yes | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) |
02/15/2012 20:47:30 ExitLicense CS | AppName = AppCS:Mcp | CycleCheck = yes | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) |
02/15/2012 20:47:30 ExitLicense ED | AppName = AppEd:Mcp | CycleCheck = own | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) |
02/15/2012 20:47:35 ExitLicense CS | AppName = DMAso:Mcp | CycleCheck = yes | Name of License = SIFLA9WCP70700 | Text of License = WinCC RC PO (10000) |
Post by CoMod » Wed Feb 15, 2012 8:03 pm
I not view Demo Mode problem
need:
- FULL License.log
- ScreenCopy with error message
- info about your project
mistey
Post by mistey » Wed Feb 15, 2012 8:32 pm
I have created a PCS7 project with ES and single OS.
I'm trying to configurate a Maintenance Station integrated in OS.
Due to license error, the asset faceplates are not shown.
Releted screenshoots is below :
That was full license.log.
Fresh Installition of PCS7.
after installation of some keys (SIFLA9WOP10700)
Post by CoMod » Wed Feb 15, 2012 8:55 pm
mistey wrote:That was full license.log.
(no) see minilnar report
You need to install some keys
Open EKB_Install
see in the Tree
Yellow Disk Keyset > PCS7 v7.1
and check notBlueColor position...
for example
SIFLA1WPC20700 not installed
Ahnenerbe
Post by Ahnenerbe » Wed Nov 23, 2016 10:35 am
Hi, I can not find key for maintenance RT v8.0 and whether it is needed at all? Packcage PCS7 v8.0 EKB2016. Please help me
Post by CoMod » Wed Nov 23, 2016 8:53 pm
Ahnenerbe wrote:Hi, I can not find key for maintenance RT v8.0 and whether it is needed at all? Packcage PCS7 v8.0 EKB2016. Please help me
Open EKB_Install
see in the Tree
Yellow Disk Keyset > PCS7 v8.0 > ....
Ahnenerbe
Post by Ahnenerbe » Fri Nov 25, 2016 2:34 pm
CoMod wrote:
Open EKB_Install
see in the Tree
Thank you, but I found only v7.1 in EKB2016
Post by CoMod » Fri Nov 25, 2016 6:20 pm
use actual version 2016_month_day
