[?]: XBTOT V5.1 and Vijeo Designer
hugoso
Post by hugoso » Tue Jan 31, 2012 1:13 am
Hello Everybody .
I have a XBTOT aplication V5.1 and Vijeo Designer, but I havent the driver.
:( What can I do ? Anybody have a crack?
Many Thanks
vlad2006gr
Re: [?]: XBTOT V5.1 and Vijeo Designer
Post by vlad2006gr » Tue Jan 31, 2012 10:40 am
Instructions: Menu About, bookmark License.
Click Upgrade ...
To add XBTOT in the window that appears enter the code: VJDHTGTOPV51M. (For Vijeo Designer v5.1)
The result is a new "iron" - XBTOT Series.
See http://www.rakurs.su/news/news/2009/07/14/59/
Good luck!
Behzad_msh
Post by Behzad_msh » Thu Sep 08, 2016 4:51 am
hi vlad2006gr
i want get backup from XBT OT HMI.
I download and install Vijeo Designer 6.0.0201 by your link. Thanks
but in About-->License . not have upgrade link.
there is just register link.
vlad2006gr
Post by vlad2006gr » Fri Sep 09, 2016 10:01 am
First you need to register the program. Then you will be able to update it.
Behzad_msh
Post by Behzad_msh » Sat Sep 10, 2016 5:07 am
vlad2006gr wrote:First you need to register the program. Then you will be able to update it.
hi
thanks vlad2006gr for answer
I try to register but encountered below message:
Our apologies, the maximum number of authorizations has been reached for this product.Please contact a service organization listed below...
vlad2006gr
Post by vlad2006gr » Tue Sep 13, 2016 6:10 am
You have entered incorrect registration number many times.
Go to the folder C: \ Program Files \ Schneider Electric \ Vijeo-Designer 6.0 \ Vijeo-Frame \ Registration. Looking Authorize.dat file. Go to the Windows folder. We search all the files of the figures. For example 146686.ocx or 146686. compare them one by one with Authorize.dat. The size of these files, 3120 or 4096 bytes. These two files are responsible for and authorized. When you reinstall them to delete.
vlad2006gr
Post by vlad2006gr » Tue Sep 13, 2016 7:16 am
Try as restore. Here files Authorize.dat for VJD and VJD Runtime is version 6.0.0.201.
https://www.sendspace.com/file/60g5ox
One file is copied to the C: \ Program Files \ Schneider Electric \ Vijeo-Designer 6.0 \ Vijeo-Frame \ Registration. The same file rename in XXXX and copy a folder in Windows. XXXX = number that you identified earlier.
Behzad_msh
Post by Behzad_msh » Thu Sep 15, 2016 5:22 am
vlad2006gr wrote:Try as restore. Here files Authorize.dat for VJD and VJD Runtime is version 6.0.0.201.
thanks vlad for answer
I copying your files and try to register by internet but encountered bellow page:
https://www.sendspace.com/file/3mscyp
vlad2006gr
Post by vlad2006gr » Thu Sep 15, 2016 10:41 am
If you do not have a license, you do not register the program via the Internet. Look at the forum, how to register the program.
mohdabshr
Post by mohdabshr » Thu Jan 25, 2018 2:48 pm
Hi All I need add file for XBTOT for vijeo designer v5.1 please if have share or send it my email mohdabshr@,gmail.com
