[?+]: unPassword Library in ABB Compact Control Builder
другие контроллеры
smb
Post by smb » Mon Dec 27, 2010 7:01 am
How can I open password protected library in ABB compact control builder AC800M?I don't have password of library.
Linkinx64
Re: Library protection in ABB Compact Control Builder
Post by Linkinx64 » Mon Dec 27, 2010 8:15 am
Hi smb
I can find password for CB password-protected library.
Please upload library or tell library name + version (in case you want to know password from standard library).
Please pay attention to some cyrillic symbols in password wrote:password example: Tcaцrmqo62
Please pay attention to some cyrillic symbols in password - you can get cyrillic symbols from Windows character map:
Linkinx64
Re: [?]: unPassword Library in ABB Compact Control Builder
Post by Linkinx64 » Mon Dec 27, 2010 9:21 am
It''s library folder which has license.
Link_is_Dead :(/L_BLib-1-0-0.rar
There are no library file. The CCB library file should have .lbr extension.
Plz, upload L_BLib-1-0-0.lbrThis file normally located in the same folder where you got L_BLib-1-0-0.
By the way: tell me the CCB version you use to open this library.
I didn't find any file with *.lbr extenstion.The software which I use is "Compact Control Builder AC 800M version 5.0.0/0".
It should looks like this:
The file icon may be different (I use CCB v5.1.0-0).
File name should be: BLib-1-0-0.lbr
This library has dependency from BoilerLib:
The password from BoilerLib-1-0-0: indgidej
When I enter the password.it seems it's correct.But I couldn't open the library and I got the following page.
Link_is_Dead :(/page.rar
What's my problem?
I can't see any functional block in BoilerLib
Plz upload folder L_BoilerLib-1-0-0 also
Or maybe whole Library folder (C:\ABB Industrial IT Data\Engineer IT Data\Compact Control Builder AC 800M\Projects\Libraries).
There are many standard libraries: BasicLib, IconLib, ControlStdLib etc.
Actually, right name for that - system libraries.
Which of those system libraries password you want to know?
ControlSimpleLib 1.0-10 password: b45927gFB
Linkinx64
Post by Linkinx64 » Sat Jan 22, 2011 2:11 pm
I open "PiecewiseLinearReal" in "ControlSimpleLib 1.0-10" with your password.I find two another function "PiecewiseLinearCalc" and PiecewiseLinearInverse" in it. How can see inside of these functions?
These functions are defined in ControlSupportLib. You have to unprotect ControlSupportLib 1.1-6 using password: Tcaцrmqo62
Please pay attention to 4th symbol (cyrillic charmap) in password - you can get it from Windows character map:
After unprotect ControlSupportLib you'll be able to see PiecewiseLinearCalc and PiecewiseLinearInverse by rightclick, Go to PiecewiseLinearReal->In Editor.
It seems the password is not correct.In addition I don't see these two functions under ControlSupportLib 1.1-6.
You can't see these functions because they are hidden - it become visible after enter the password. Password is correct.
I right click on ControlSupportLib and select Properties->Protection and I got the following picture.
I got "Invalid password" message.
[url=hhttp://img825.spamm.us/img825/9793/pswccp.gif]Image[/url]
Ok, I know what's goin' on:
Make the follow change in Windows regional settings: Add RUSSIAN language support
Insert Windows XP installation disc (if required), restart PC and try again.
It works.
Thank you.
Linkinx64
Re: [?+]: unPassword Library in ABB Compact Control Builder
Post by Linkinx64 » Mon Jan 24, 2011 11:09 am
How can I remove password from standard library?
System libraries password cannot be removed because these libraries have both attributes - "secured" and "released".
These attributes can't be conjunctively applied for user library.
Linkinx64
Post by Linkinx64 » Tue Jan 25, 2011 7:45 am
What's the password of "BasicLib 1.4-9"?
That was quite difficult :)
Password is : HUULДЦЕW
where ДЦЕ are from cyrillic. As we discussed - type it using character map.
or HUULÄÖÅW
Linkinx64
Post by Linkinx64 » Fri Mar 25, 2011 12:11 pm
brave_eagle wrote:Basic Lib 1.5-7 PLS
Password is: weiKgytfcn7
Linkinx64
Post by Linkinx64 » Tue Apr 12, 2011 5:19 am
tschanski wrote:i need password for "abb-bib4.lib" in 907 ac 1131....
Link_is_Dead :(/abb-bib4.lib
Could you tell us which software you used to open this file? This file doesn't seems a Compact Control Builder library...
brave_eagle
Post by brave_eagle » Tue Apr 12, 2011 9:00 am
Maybe is AC31GRAF or 907AC1131
Linkinx64
Post by Linkinx64 » Wed Apr 13, 2011 7:58 am
Finally I've downloaded it (AC1131).. viewtopic.php?f=3&t=8905&p=21001 Much more time spent for download rather than for the RE-search.
tschanski wrote:i tried to open with 907ac1131 and codesys 2.3 and was prompted with a password-popup...
When opening abb-bib4.lib type in password-popup: sst_ts_kb2 and click OK.
tschanski wrote:it works!!!!! :D :D
thank you for your efforts!!! (tyou) (pgood) (pgood)
Linkinx64
Post by Linkinx64 » Sat Jul 02, 2011 3:36 am
puppy75 wrote:Hello,
if possible, I need password for following libraries:
- ControlBasicLib 1.1-4
- ControlSimpleLib 1.1-2
- ControlStandardLib 1.3-8
Theese are part of RevD 800xA AC800M Connect installations.
Thanks in advance.
(thnx)
ControlBasicLib 1.1-4: 35UjhGsVkp
ControlSimpleLib 1.1-2: 2gyHDreQA
ControlStandardLib 1.3-8: fpRcYniAfr
ControlSupportLib 1.2-2: yPUg56FE
Linkinx64
Post by Linkinx64 » Fri Jul 08, 2011 5:56 am
st_e_fan wrote:Yes it's ControlBasicLib 1.6-9. I will try to bring it with me and send it..i'm just not sure will be only export from the Lib structure enough
Best Regards!
Would it be possible also for ControlBasicLib 1.6-9 and ControlStandardLib 1.4-6 (thnx)
Are you sure "ControlBasicLib" has 1.6-9 version?
ControlStandardLib 1.4-6: hjHghgdfddbg
Linkinx64
Post by Linkinx64 » Mon Jul 11, 2011 10:27 am
systane wrote:I have CCB 5.1
And i´m pretty sure he is referring to basiclib not to control basiclib
I adjoined to his request. I need pass for:
AlarmEventLib 1.5-8
BasicLib 1.6-9
ControlBasicLib1.2-3
Control SimpleLib 1.2-3
ControlSUpportLib 1.3-4
AlarmEventLib	1.5-8	J589544gfcBfB
BasicLib	1.6-9:	Hasiw834ghYiU
ControlBasicLib	1.2-3:	IopVmLkt54drB
ControlSimpleLib	1.2-3:	bvfr56788iJM
ControlSupportLib	1.3-4:	ttkllues545gB
Linkinx64
Post by Linkinx64 » Mon Jul 11, 2011 4:44 pm
lolo_xyz wrote:It would be possible to unPassword the
SystemLib
MMSCommLib 1.3-4
ModBusCommLib 1.3-3
ModBusTCPCommLib 1.2-4
Any detailed procedure to unPassword with the Olydbg would be appreciated
(thnx)
System : kdY73kjdkl
MMSCommLib 1.3-4 : rGHVBG67535
ModBusCommLib 1.3-3 : Dsavxcmhjyrt
ModBusTCPCommLib 1.2-4 : 9nhfDFdfjkghRj
Linkinx64
Post by Linkinx64 » Fri Aug 26, 2011 9:19 am
elcole wrote:It would be possible to unPassword the
Basiclib 1.3-3
ControllStandardlib 1.2-4
System version 4.1.0-6 ?
Basiclib 1.3-3: g620gG
ControlStandardLib 1.2-4: KOURcdG
Linkinx64
Post by Linkinx64 » Thu Sep 01, 2011 3:45 am
puppy75 wrote:can I got the password for the two custom libraries contained in following zip?
http://dl.dropbox.com/u/15190010/CBM4.1Libraries.zip
MacroLib: MacroABBEAAC800M7067
MacroLibDefaults not protected
puppy75
Post by puppy75 » Fri Nov 11, 2011 11:20 am
Hello again,
Is possible to obtain password relatedto three libraries included in following zip?
http://dl.dropbox.com/u/15190010/PCdeviceLibs.zip
Thank in advance
Linkinx64
Post by Linkinx64 » Wed Nov 16, 2011 8:08 am
Propane wrote:I just installed the new Compact Control Builder version 5.1.0/1.
The previously posted passwords for BasicLib no longer work.
I would like to know the new password for BasicLib 1.6-10.
I don't have Compact Control Builder version 5.1.0\1.
Very strange... It usually not happen between the revisions, only between versions... Probably protection was changed...
Could you share the software to let me check?
Propane wrote:It's been 2.5 months since you got Compact Control Builder version 5.1.0/1.
Were you able to reveal the password for BasicLib 1.6-10?
See answer in PM (thnx)
puppy75
Post by puppy75 » Thu Nov 24, 2011 9:33 pm
puppy75 wrote:Hello again,
Thank in advance
I remember in this thread a reply about this request....but seems deleted...?
Linkinx64
Post by Linkinx64 » Fri Nov 25, 2011 7:02 am
puppy75 wrote:I remember in this thread a reply about this request....but seems deleted...?
More exactly: here was a reply and the request about BMI libraries to upload.... All gone :(
Actually, is it make any sence for you if you already got the password for
P.S. Can anyone contribute BMI (Minerals Library) for 800xA 5.1?
mandichi
Post by mandichi » Sat Nov 26, 2011 7:22 am
Hi Linkinx64,
Could you please help me unpassword below file
http://www.megaupload.com/?d=SA0GXDES
Thank you and Best regards.
Linkinx64
Post by Linkinx64 » Sat Nov 26, 2011 10:25 am
mandichi wrote:please help me unpassword below file http://www.megaupload.com/?d=SA0GXDES
CraneAdvancedLib: Akterspegel
CraneBasicLib: Helljuset
CraneLpsLib: Kronprinsessa
CraneMathLib: windmill
CranePE1373: SkitKey01
CraneStandardLib: Avgaserna
CraneTpsLib: svenskadagbladet
How's about to upload folders L_CraneBasicLib-1-0-0, L_CraneStandardLib-1-0-0 etc. for the files above?
Linkinx64
Post by Linkinx64 » Thu Dec 01, 2011 4:48 am
ControlAdvancedLib	1.3-4	q3321mGDe
ControlExtendedLib	1.2-3	IjuyGDE69
ControlObjectLib	1.1-5	nfRDKi78wn
ControlSolutionLib	1.1-4	FGdcGOW
MMSCommLib	1.2-13	hwoHF56VTg
ModBusTCPCommLib	1.1-2	MjiJSAQ54y
ModBusCommLib	1.2-2	JHfg65DSWbH
Linkinx64
Post by Linkinx64 » Tue Dec 06, 2011 2:27 pm
anldon wrote:Can you help me get the password of the lib:http://www.megaupload.com/?d=D0JC8078
Here your passwords:
MineHoistAppLib: cie5W9jice
MineHoistBasicLib: uVCa3TvYNp
MineHoistBrake: hn8u87wfKF
MineHoistPosLib: DanielDummy
Linkinx64
Post by Linkinx64 » Wed Dec 07, 2011 5:02 pm
This will work:
AHLib	olofbriljerar
AHLib0	orvar626
AHLib1	arne726
AHLib2	bertil036
AHLib3	curt536
AHLib4   daniel246
AHLib5	erik156
AHLib6	fredrik266
AHLib7	gustav576
AHLib8	henrik096
Who all these people? :)
hina
Post by hina » Fri Dec 23, 2011 9:45 pm
Dear Linkinx64,
Do you have a SupervisionLib 2.4-4?, because i have the project with AC800 Compact Control Builder Professional version 5.0.2/2
after i check on the library there is no SupervisionLib 2.4-4 on Compact Control Builder Professional
Please advice
Linkinx64
Post by Linkinx64 » Sat Dec 24, 2011 5:10 am
Dear hina
The SupervisionLib (as well as some other system libraries) is not presented in compact version of Control Builder, only in Control Builder M (that's a part of 800xA System).
You need install 800xA SV5 SP2 or later version, then restore project made in CCB 5.0.2/2 (actually, made in 800xA's CBM and exported to compact version).
To restore compact project in Control Buider M use Tools >> Maintenance >> Compact CB >> Open From Compact CB Format.
Regards
Linkinx64
Post by Linkinx64 » Wed Feb 01, 2012 4:15 am
elcole wrote:It would be possible to unPassword the controlsimplelib 1.0-4
jKgafJK
Linkinx64
Post by Linkinx64 » Mon Jun 04, 2012 8:47 pm
SOULHACK wrote:the CommunicationLib 1.0-0
CpiwkK7653
puppy75
Post by puppy75 » Tue Jun 12, 2012 10:06 am
Linkin', sorry for delaying in my replay, but unfortunately I lost your posted password (boom)
Can you send me again the password of that libraries?
I link you the new place for the lib: https://dl.dropbox.com/u/15190010/PCDeviceLib.zip
Thank a lot!
Linkinx64
Post by Linkinx64 » Tue Jun 12, 2012 3:37 pm
puppy75 wrote: sorry for delaying in my replay, but unfortunately I lost your posted password
(clap) Go look for where you lost it
Linkinx64
Post by Linkinx64 » Mon Jul 23, 2012 5:50 am
ionold3 wrote:Could you post the pass for
SignalLib 1.6-9 library
You don't need this really.
Linkinx64
Post by Linkinx64 » Fri Aug 24, 2012 8:07 am
azhw wrote:
amit_sabby wrote:Can you help me get the password of the lib:rcrTechnoGenLib-5-0-2.lbrrcrTechnoSystemLib-5-0-1.lbrrdDriveGenLib-1-0-0.lbrrdDriveSystemLib-1-6-0.lbrrfmDriveGenLib-5-0-2.lbrrfmDriveSystemLib-5-0-0.lbrrfmMdrLib-5-0-0.lbrrfmSystemLib-5-0-1.lbr
Linkinx64 wrote:Wait until I find my crystal ball... (sbutton)
crystal ball ? what is it?
sounds very interesting!
Esoteric method of password revealing using crystal ball:
I think classic reveal password methods are still actual and easier than the supernatural. Isn't it? :)
amit_sabby
Post by amit_sabby » Fri Aug 24, 2012 1:50 pm
sorry for misunderstanding...here is the link for library for which i need password thank you.
http://dl.dropbox.com/u/36769999/rfmSystemLib-5-0-1.rar
thanks azhw
Linkinx64
Post by Linkinx64 » Fri Aug 24, 2012 3:06 pm
rfmSystemLib 5.0-1: rfmSystemLib1872
rfmDriveSystemLib 1.6-0: rfmDriveSystemLib312
rfmDriveGenLib 1.0-0 not protected
rfmMdrLib 5.0-0 not protected
rdDriveSystemLib 1.6-0: rdDriveSystemLib3127
rdDriveGenLib 1.0-0 not protected
rcrTechnoSystemLib 5.0-1: rcrTechnoSystemLib74
rcrTechnoGenLib 5.0-2 not protected
(thnx)
amit_sabby
Post by amit_sabby » Fri Aug 24, 2012 3:58 pm
thank you very much, you solved my four year old head nagging...it works wonder
azhw
Post by azhw » Sat Aug 25, 2012 8:57 am
very great!
Linkinx64 is really a genius, and a helpful and respectable man! (clap)
I wonder what method Linkin64 used to find the password so fast and exact?
you have a keygener? use ollydbg ? or using some bug of CCB itself? :haha:
(tyou)
Linkinx64
Post by Linkinx64 » Sat Aug 25, 2012 1:07 pm
I use Ollydbg + special conversion and decryption software (developed by myself).
There's nothing genious in unpassword libraries. I think everyone who have target, patience and basic knowledge of asm and c++ can do the same...
Linkinx64
Post by Linkinx64 » Thu Aug 30, 2012 3:38 am
lolo_xyz wrote:I need the password of SerialCommLib 2.1-2
hgcfgdjhgGF47v
st_e_fan
Post by st_e_fan » Fri Aug 31, 2012 8:12 pm
This post with the crystal ball makes my day!!! :)
Thanks for the good humor!!
Now i"m pointing to my subject - i need the password for the Fort Knox Bullion Depository. Please help!
Linkinx64
Post by Linkinx64 » Sat Sep 01, 2012 9:00 am
st_e_fan wrote:i need the password for the Fort Knox Bullion Depository. Please help!
I will start to process your request as soon as the Ecuadorean embassy established in my town :)
Picture: Julian Assange gave a defiant statement from a balcony at the Ecuadorean embassy in London.
Source: http://www.telegraph.co.uk
amit_sabby
Post by amit_sabby » Tue Sep 18, 2012 1:02 pm
http://dl.dropbox.com/u/36769999/WINDER-1-0-0.rar
i would like to have your service again.
please i need password for few libraries in link given.
thanks for your last posting. it is really helpful.
puppy75
Post by puppy75 » Tue Nov 20, 2012 4:05 pm
Linkinx64 wrote:You don't need this really.
Hi Linkinx64, can you post the pass anyway for this lib? We need it.... (pgood)
iatsiman
Post by iatsiman » Thu Nov 22, 2012 12:02 pm
Hello Linkinx64!
Could you please give the password for SupervisionBasicLib 1.1-7 ?
Thanks in advance.
Linkinx64
Post by Linkinx64 » Thu Nov 22, 2012 3:00 pm
This system library is protected using the latest encryption algorithm. See PM.
drgry
Post by drgry » Wed Nov 28, 2012 11:13 pm
Hello Linkinx64
Would it be possible to unlock these libraries:
http://depositfiles.com/files/7yfoitq2y
Linkinx64
Post by Linkinx64 » Thu Nov 29, 2012 11:15 am
http://depositfiles.com/files/7yfoitq2y passwords
ControlSimpleLib:
Frsimp3g
ControlSupportLib:
prSupllz
rdDriveSystemLib:
rdSystemLib:
rdSystemLib1872
rdTechnoSystemLib:
rdTechnoSystemLib740
rmcSystemLib:
veronika
Do you have rd libraries for the 800xA 5.x (with a graphic aspects)?
Anybody can upload it?
power2l
Post by power2l » Thu Dec 13, 2012 9:00 pm
Hello Linkinx64!
Would you be willing to provide the passwords for the following library files?
CraneStandardLib-1-0-0.lbr
CranePE1373Lib-1-0-0.lbr
CraneCableReelLib-1-0-0.lbr
CraneBasicLib-1-0-0.lbr
CraneAdvancedLib-1-0-0.lbr
https://dl.dropbox.com/u/81530526/CraneLib.zip
Thank you!
Linkinx64
Post by Linkinx64 » Fri Dec 14, 2012 5:30 am
power2l wrote:Would you be willing to provide the passwords for the following library files?
Can you please upload folder for the CranePE1373Lib? It must be in the same directory and has name L_CranePE1373Lib-1-0-0.
power2l
Post by power2l » Fri Dec 14, 2012 2:01 pm
Thank you Linkinx64, here is a link to the folder you requested.
https://dl.dropbox.com/u/81530526/L_Cra ... -1-0-0.zip
