[?+]: unPassword Library in ABB Compact Control Builder
How can I open password protected library in ABB compact control builder AC800M?I don't have password of library.
Re: Library protection in ABB Compact Control Builder
Hi smb
I can find password for CB password-protected library.
Please upload library or tell library name + version (in case you want to know password from standard library).
Please pay attention to some cyrillic symbols in password - you can get cyrillic symbols from Windows character map:Please pay attention to some cyrillic symbols in password wrote:password example: Tcaцrmqo62
Re: [?]: unPassword Library in ABB Compact Control Builder
There are no library file. The CCB library file should have .lbr extension.
Plz, upload L_BLib-1-0-0.lbrThis file normally located in the same folder where you got L_BLib-1-0-0.
By the way: tell me the CCB version you use to open this library.
It should looks like this:I didn't find any file with *.lbr extenstion.The software which I use is "Compact Control Builder AC 800M version 5.0.0/0".
The file icon may be different (I use CCB v5.1.0-0).
File name should be: BLib-1-0-0.lbr
This library has dependency from BoilerLib:
The password from BoilerLib-1-0-0: indgidej
I can't see any functional block in BoilerLibWhen I enter the password.it seems it's correct.But I couldn't open the library and I got the following page.
Link_is_Dead :(/page.rar
What's my problem?
Plz upload folder L_BoilerLib-1-0-0 also
Or maybe whole Library folder (C:\ABB Industrial IT Data\Engineer IT Data\Compact Control Builder AC 800M\Projects\Libraries).
There are many standard libraries: BasicLib, IconLib, ControlStdLib etc.
Actually, right name for that - system libraries.
Which of those system libraries password you want to know?
ControlSimpleLib 1.0-10 password: b45927gFB
These functions are defined in ControlSupportLib. You have to unprotect ControlSupportLib 1.1-6 using password: Tcaцrmqo62I open "PiecewiseLinearReal" in "ControlSimpleLib 1.0-10" with your password.I find two another function "PiecewiseLinearCalc" and PiecewiseLinearInverse" in it. How can see inside of these functions?
Please pay attention to 4th symbol (cyrillic charmap) in password - you can get it from Windows character map:
After unprotect ControlSupportLib you'll be able to see PiecewiseLinearCalc and PiecewiseLinearInverse by rightclick, Go to PiecewiseLinearReal->In Editor.
You can't see these functions because they are hidden - it become visible after enter the password. Password is correct.It seems the password is not correct.In addition I don't see these two functions under ControlSupportLib 1.1-6.
Ok, I know what's goin' on:I right click on ControlSupportLib and select Properties->Protection and I got the following picture.
I got "Invalid password" message.
[url=hhttp://img825.spamm.us/img825/9793/pswccp.gif][/url]
Make the follow change in Windows regional settings: Add RUSSIAN language support
Insert Windows XP installation disc (if required), restart PC and try again.
It works.
Thank you.
Re: [?+]: unPassword Library in ABB Compact Control Builder
System libraries password cannot be removed because these libraries have both attributes - "secured" and "released".How can I remove password from standard library?
These attributes can't be conjunctively applied for user library.
That was quite difficultWhat's the password of "BasicLib 1.4-9"?
Password is : HUULДЦЕW
where ДЦЕ are from cyrillic. As we discussed - type it using character map.
or HUULÄÖÅW
Password is: weiKgytfcn7brave_eagle wrote:Basic Lib 1.5-7 PLS
Could you tell us which software you used to open this file? This file doesn't seems a Compact Control Builder library...
Maybe is AC31GRAF or 907AC1131
Finally I've downloaded it (AC1131).. viewtopic.php?f=3&t=8905&p=21001 Much more time spent for download rather than for the RE-search.
When opening abb-bib4.lib type in password-popup: sst_ts_kb2 and click OK.tschanski wrote:i tried to open with 907ac1131 and codesys 2.3 and was prompted with a password-popup...
tschanski wrote:it works!!!!!
thank you for your efforts!!!
puppy75 wrote:Hello,
if possible, I need password for following libraries:
- ControlBasicLib 1.1-4
- ControlSimpleLib 1.1-2
- ControlStandardLib 1.3-8
Theese are part of RevD 800xA AC800M Connect installations.
Thanks in advance.
ControlBasicLib 1.1-4: 35UjhGsVkp
ControlSimpleLib 1.1-2: 2gyHDreQA
ControlStandardLib 1.3-8: fpRcYniAfr
ControlSupportLib 1.2-2: yPUg56FE
Are you sure "ControlBasicLib" has 1.6-9 version?st_e_fan wrote:Yes it's ControlBasicLib 1.6-9. I will try to bring it with me and send it..i'm just not sure will be only export from the Lib structure enough
Best Regards!
Would it be possible also for ControlBasicLib 1.6-9 and ControlStandardLib 1.4-6
ControlStandardLib 1.4-6: hjHghgdfddbg
systane wrote:I have CCB 5.1
And i´m pretty sure he is referring to basiclib not to control basiclib
I adjoined to his request. I need pass for:
AlarmEventLib 1.5-8
BasicLib 1.6-9
ControlBasicLib1.2-3
Control SimpleLib 1.2-3
ControlSUpportLib 1.3-4
AlarmEventLib 1.5-8 J589544gfcBfB
BasicLib 1.6-9: Hasiw834ghYiU
ControlBasicLib 1.2-3: IopVmLkt54drB
ControlSimpleLib 1.2-3: bvfr56788iJM
ControlSupportLib 1.3-4: ttkllues545gB
lolo_xyz wrote:It would be possible to unPassword the
SystemLib
MMSCommLib 1.3-4
ModBusCommLib 1.3-3
ModBusTCPCommLib 1.2-4
Any detailed procedure to unPassword with the Olydbg would be appreciated
System : kdY73kjdkl
MMSCommLib 1.3-4 : rGHVBG67535
ModBusCommLib 1.3-3 : Dsavxcmhjyrt
ModBusTCPCommLib 1.2-4 : 9nhfDFdfjkghRj
System version 4.1.0-6 ?elcole wrote:It would be possible to unPassword the
Basiclib 1.3-3
ControllStandardlib 1.2-4
Basiclib 1.3-3: g620gG
ControlStandardLib 1.2-4: KOURcdG
puppy75 wrote:can I got the password for the two custom libraries contained in following zip?
http://dl.dropbox.com/u/15190010/CBM4.1Libraries.zip
MacroLib: MacroABBEAAC800M7067
MacroLibDefaults not protected
Hello again,
Is possible to obtain password relatedto three libraries included in following zip?
http://dl.dropbox.com/u/15190010/PCdeviceLibs.zip
Thank in advance
Thank in advance
I don't have Compact Control Builder version 5.1.0\1.Propane wrote:I just installed the new Compact Control Builder version 5.1.0/1.
The previously posted passwords for BasicLib no longer work.
I would like to know the new password for BasicLib 1.6-10.
Very strange... It usually not happen between the revisions, only between versions... Probably protection was changed...
Could you share the software to let me check?
See answer in PMPropane wrote:It's been 2.5 months since you got Compact Control Builder version 5.1.0/1.
Were you able to reveal the password for BasicLib 1.6-10?
I remember in this thread a reply about this request....but seems deleted...?puppy75 wrote:Hello again,
Thank in advance
More exactly: here was a reply and the request about BMI libraries to upload.... All gonepuppy75 wrote:I remember in this thread a reply about this request....but seems deleted...?
Actually, is it make any sence for you if you already got the password for
P.S. Can anyone contribute BMI (Minerals Library) for 800xA 5.1?
Hi Linkinx64,
Could you please help me unpassword below file
http://www.megaupload.com/?d=SA0GXDES
Thank you and Best regards.
mandichi wrote:please help me unpassword below file http://www.megaupload.com/?d=SA0GXDES
CraneAdvancedLib: Akterspegel
CraneBasicLib: Helljuset
CraneLpsLib: Kronprinsessa
CraneMathLib: windmill
CranePE1373: SkitKey01
CraneStandardLib: Avgaserna
CraneTpsLib: svenskadagbladet
ControlAdvancedLib 1.3-4 q3321mGDe
ControlExtendedLib 1.2-3 IjuyGDE69
ControlObjectLib 1.1-5 nfRDKi78wn
ControlSolutionLib 1.1-4 FGdcGOW
MMSCommLib 1.2-13 hwoHF56VTg
ModBusTCPCommLib 1.1-2 MjiJSAQ54y
ModBusCommLib 1.2-2 JHfg65DSWbH
Here your passwords:anldon wrote:Can you help me get the password of the lib:http://www.megaupload.com/?d=D0JC8078
MineHoistAppLib: cie5W9jice
MineHoistBasicLib: uVCa3TvYNp
MineHoistBrake: hn8u87wfKF
MineHoistPosLib: DanielDummy
This will work:anldon wrote:In pursuit:http://www.megaupload.com/?d=Y745VPK9
AHLib olofbriljerar
AHLib0 orvar626
AHLib1 arne726
AHLib2 bertil036
AHLib3 curt536
AHLib4 daniel246
AHLib5 erik156
AHLib6 fredrik266
AHLib7 gustav576
AHLib8 henrik096
Dear Linkinx64,
Do you have a SupervisionLib 2.4-4?, because i have the project with AC800 Compact Control Builder Professional version 5.0.2/2
after i check on the library there is no SupervisionLib 2.4-4 on Compact Control Builder Professional
Please advice
Please advice
Dear hina
The SupervisionLib (as well as some other system libraries) is not presented in compact version of Control Builder, only in Control Builder M (that's a part of 800xA System).
You need install 800xA SV5 SP2 or later version, then restore project made in CCB 5.0.2/2 (actually, made in 800xA's CBM and exported to compact version).
To restore compact project in Control Buider M use Tools >> Maintenance >> Compact CB >> Open From Compact CB Format.
Regards
Regards
elcole wrote:It would be possible to unPassword the controlsimplelib 1.0-4
jKgafJK
SOULHACK wrote:the CommunicationLib 1.0-0
CpiwkK7653
Linkin', sorry for delaying in my replay, but unfortunately I lost your posted password
Can you send me again the password of that libraries?
I link you the new place for the lib: https://dl.dropbox.com/u/15190010/PCDeviceLib.zip
Thank a lot!
Thank a lot!
Go look for where you lost itpuppy75 wrote: sorry for delaying in my replay, but unfortunately I lost your posted password
You don't need this really.ionold3 wrote:Could you post the pass for
SignalLib 1.6-9 library
Esoteric method of password revealing using crystal ball:azhw wrote:amit_sabby wrote:Can you help me get the password of the lib:rcrTechnoGenLib-5-0-2.lbrrcrTechnoSystemLib-5-0-1.lbrrdDriveGenLib-1-0-0.lbrrdDriveSystemLib-1-6-0.lbrrfmDriveGenLib-5-0-2.lbrrfmDriveSystemLib-5-0-0.lbrrfmMdrLib-5-0-0.lbrrfmSystemLib-5-0-1.lbrcrystal ball ? what is it?Linkinx64 wrote:Wait until I find my crystal ball...
sounds very interesting!
I think classic reveal password methods are still actual and easier than the supernatural. Isn't it?
sorry for misunderstanding...here is the link for library for which i need password thank you.
http://dl.dropbox.com/u/36769999/rfmSystemLib-5-0-1.rar
thanks azhw
thanks azhw
amit_sabby wrote:http://dl.dropbox.com/u/36769999/rfmSystemLib-5-0-1.rar
rfmSystemLib 5.0-1: rfmSystemLib1872
rfmDriveSystemLib 1.6-0: rfmDriveSystemLib312
rfmDriveGenLib 1.0-0 not protected
rfmMdrLib 5.0-0 not protected
rdDriveSystemLib 1.6-0: rdDriveSystemLib3127
rdDriveGenLib 1.0-0 not protected
rcrTechnoSystemLib 5.0-1: rcrTechnoSystemLib74
rcrTechnoGenLib 5.0-2 not protected
thank you very much, you solved my four year old head nagging...it works wonder
very great!
Linkinx64 is really a genius, and a helpful and respectable man!
I wonder what method Linkin64 used to find the password so fast and exact?
you have a keygener? use ollydbg ? or using some bug of CCB itself?
I use Ollydbg + special conversion and decryption software (developed by myself).
There's nothing genious in unpassword libraries. I think everyone who have target, patience and basic knowledge of asm and c++ can do the same...
lolo_xyz wrote:I need the password of SerialCommLib 2.1-2
hgcfgdjhgGF47v
This post with the crystal ball makes my day!!!
Thanks for the good humor!!
Now i"m pointing to my subject - i need the password for the Fort Knox Bullion Depository. Please help!
I will start to process your request as soon as the Ecuadorean embassy established in my townst_e_fan wrote:i need the password for the Fort Knox Bullion Depository. Please help!
Picture: Julian Assange gave a defiant statement from a balcony at the Ecuadorean embassy in London.
Source: http://www.telegraph.co.uk
http://dl.dropbox.com/u/36769999/WINDER-1-0-0.rar
i would like to have your service again.
please i need password for few libraries in link given.
thanks for your last posting. it is really helpful.
Hi Linkinx64, can you post the pass anyway for this lib? We need it....Linkinx64 wrote:You don't need this really.
Hello Linkinx64!
Could you please give the password for SupervisionBasicLib 1.1-7 ?
Thanks in advance.
Thanks in advance.
This system library is protected using the latest encryption algorithm. See PM.
Hello Linkinx64
Would it be possible to unlock these libraries:
http://depositfiles.com/files/7yfoitq2y
http://depositfiles.com/files/7yfoitq2y passwords
ControlSimpleLib:
ControlSupportLib:
rdDriveSystemLib:
rdSystemLib:
rdTechnoSystemLib:
rmcSystemLib:
Frsimp3g
prSupllz
rdSystemLib1872
rdTechnoSystemLib740
veronika
Anybody can upload it?
Hello Linkinx64!
Would you be willing to provide the passwords for the following library files?
CraneStandardLib-1-0-0.lbr
CranePE1373Lib-1-0-0.lbr
CraneCableReelLib-1-0-0.lbr
CraneBasicLib-1-0-0.lbr
CraneAdvancedLib-1-0-0.lbr
https://dl.dropbox.com/u/81530526/CraneLib.zip
Thank you!
Thank you!
Can you please upload folder for the CranePE1373Lib? It must be in the same directory and has name L_CranePE1373Lib-1-0-0.power2l wrote:Would you be willing to provide the passwords for the following library files?
Thank you Linkinx64, here is a link to the folder you requested.
https://dl.dropbox.com/u/81530526/L_Cra ... -1-0-0.zip
