IEC standards
Прочие книги
weko
[?]: iec 61131 standards
Post by weko » Mon Apr 14, 2008 12:22 am
where can i find the iec 61131 standards for download?
stas
Post by stas » Thu May 01, 2008 11:58 am
Welcome
under this link http://www.plcopen.org
Schtiel
Post by Schtiel » Sun May 04, 2008 6:14 pm
IEC 61131 Control Languages Introduction:
http://rapidshare.com/files/112531896/IEC61131.rar
Schtiel
[LINK:] IEC 61131 Standards
Post by Schtiel » Mon Aug 10, 2009 10:00 am
Schtiel
Re: IEC standards
Post by Schtiel » Fri Oct 28, 2011 10:05 am
https://rapidshare.com/files/3096653765 ... .part1.rar
https://rapidshare.com/files/1802004595 ... .part2.rar
https://rapidshare.com/files/58387732/I ... .part3.rar
https://rapidshare.com/files/213425491/ ... .part4.rar
https://rapidshare.com/files/3891958110/IEC.rar
list of standards
list of standards
IEC TR 62271-310 High-voltage switchgear and controlgear - Electrical endurance testing for circu.pdf
IEC TR 62095 Electric cables - Calculations for current ratings - Finite element method.pdf
IEC PAS 62030 Real-Time Publish-Subscribe (RTPS) Wire Protocol Specification Version 1.0.pdf
IEC 62271-308 High-voltage switchgear and controlgear - Guide to Asymetrical shoet circuit breaki.pdf
IEC 62271-203 High-voltage switchgear and controlgear - Gas-insulated metal-enclosed swithgear.pdf
IEC 62271-200 High-voltage switchgear and controlgear - AC metal-enclosed switchgear and controlg.pdf
IEC 62271-105 High-voltage switchgear and controlgear - Alternating-current Switch Fuse Combinati.pdf
IEC 62271-102 High-voltage switchgear and controlgear - High-voltage alternating-current Disconne.pdf
IEC 62271-100 High-voltage switchgear and controlgear - High-voltage alternating-current circuit-.pdf
IEC 62086-1 Electrical apparatus for explosive gas atmospheres - Electrical resistance trace he.pdf
IEC 61892-6 Mobile and fixed offshore units - Electrical installations.pdf
IEC 61832 Analyser systems - Guide to technical enquiry & Bid Evaluation.pdf
IEC 61831 On-line analyser systems - Guide to design and installation.pdf
IEC 61537 Cable tray systems and cable ladder systems.pdf
IEC 61511 Part-3 Guidance for the determination of safety integrity levels - informative.pdf
IEC 61511 Part-2 Guidelines in the application of IEC 61511-1 - Informative.pdf
IEC 61511 Part-1 Framework, definitions, system, hardware and software requirements.pdf
IEC 61508 Part 7 Overview of Techniques & Measures.pdf
IEC 61508 Part 6 - Guidelines on the application of parts 2 and 3.pdf
IEC 61508 Part 5 Addenda.pdf
IEC 61508 Part 5 - Examples of Methods for the determination of safety integrity levels.pdf
IEC 61508 Part 4 Addenda.pdf
IEC 61508 Part 4 - Definitions and Abbreviations.pdf
IEC 61508 Part 3 Addenda.pdf
IEC 61508 Part 3 - Software Requirements.pdf
IEC 61508 Part 2 - Requirements for Electrical - Electronic programmable electronic safety-related systems.pdf
IEC 61508 Part 1 Addenda.pdf
IEC 61508 Part 1 - General Requirements.pdf
IEC 61158-3 Data link service definition.pdf
IEC 61158-2 Physical layer specification and service definition.pdf
IEC 61158-1 Overview and guidance for the IEC 61158 series.pdf
IEC 61131-8 Programmable controllers - Guidelines for the application and implementation of programming languages.pdf
IEC 61131-7 Programmable controllers - Fuzzy control programming.pdf
IEC 61131-5 Programmable controllers - Communications.pdf
IEC 61131-4 Programmable controllers - User guidelines.pdf
IEC 61131-3 Programmable controllers - Programming languages.pdf
IEC 61131-2 Programmable controllers - Equipment Requirements and Tests.pdf
IEC 61131-1 Programmable controllers - General information.pdf
IEC 60947-7-1 Low-voltage switchgear and controlgear - Ancillary equipment - Terminal blocks for .pdf
IEC 60947-6-2 Low-voltage switchgear and controlgear - Multiple function equipment - Control and .pdf
IEC 60947-6-1 Low-voltage switchgear and controlgear - Multiple function equipment - Automatic tr.pdf
IEC 60947-4-3 Low-voltage switchgear and controlgear - Contactors and motor-starters - AC semicon.pdf
IEC 60947-4-2 Low-voltage switchgear and controlgear - Contactors and Motor Starters - AC Semicon.pdf
IEC 60947-4-1 Low-voltage switchgear and controlgear - Contactors and Motor Starters - Electromec.pdf
IEC 60947-3 Low-voltage switchgear and controlgear - Switches, disconnectors, switch-disconnector.pdf
IEC 60947-2 Low-voltage switchgear and controlgear - Circuit Breakers.pdf
IEC 60947-1-2004 Low-voltage switchgear and controlgear - General rules.pdf
IEC 60947-1 Low-voltage switchgear and controlgear - General rules.pdf
IEC 60909-4 Short-circuit currents in three-phase a.c. systems - Examples for the calculation of .pdf
IEC 60909-3 Short-circuit currents in three-phase a.c. systems - Currents during two separate sim.pdf
IEC 60909-2 Electrical equipment - Data for short-circuit current calculations.pdf
IEC 60909-1 Short-circuit currents in three-phase a.c. systems - Factors for the calculation of s.pdf
IEC 60909-0 Short-circuit currents in three-phase a.c. systems - Calculation of currents.pdf
IEC 60874-14-4 Connectors for optical fibres and cables - Detail specification for fibre optic adaptor (simplex) type SC for multimode fibre.pdf
IEC 60793-1-44 Optical fibres - Measurement methods and test procedures - Cut-off wavelength.pdf
IEC 60751 Industrial platinum resistance thermometer Sensors.pdf
IEC 60726 Dry Type Power Transmformers.PDF
IEC 60694 Common specifications for high -voltage switchgear and controlgear standards.pdf
IEC 60584-3 Thermocouples - Extension and compensating cables.pdf
IEC 60584-2 Thermocouples - Tolerances.pdf
IEC 60584-1 Thermocouples - Reference tables.pdf
IEC 60534-8_4 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60534-8_3 Control valve aerodynamic noise prediction method.pdf
IEC 60534-8_2 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60534-8_1 Industrial Process Control Valves - Noise Considerations.pdf
IEC 60534-7 Industrial Process Control Valves - Data Sheet.pdf
IEC 60534-6_2 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-6_1 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-6 Industrial Process Control Valves - Mounting details for attachment of positioners.pdf
IEC 60534-5 Industrial Process Control Valves - Marking.pdf
IEC 60534-4 Industrial Process Control Valves - Inspection & Routine Testing.pdf
IEC 60534-3_3 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_2 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3_1 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-3 Industrial Process Control Valves - Dimensions.pdf
IEC 60534-2_5 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_4 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_3 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-2_1 Industrial Process Control Valves - Flow capacity Equations.pdf
IEC 60534-1 Industrial Process Control Valves - Terminology & General Considerations.pdf
IEC 60529 Degrees of protection provided by enclosures (IP Code).pdf
IEC 60502-4 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60502-2 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60502-1 Power cables with extruded insulation and their accessories for rated voltages.pdf
IEC 60439-5 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf
IEC 60439-4 Low-voltage switchgear and controlgear assemblies - Particular requirements for assem.pdf
IEC 60439-3 Low-voltage switchgear and controlgear assemblies - Particular requirements for Iow-v.pdf
IEC 60439-2 Low-voltage switchgear and controlgear assemblies - Particular requirements for busba.pdf
IEC 60439-1 Low-voltage switchgear and controlgear assemblies - Type-tested and partially ty.pdf
IEC 60364-7-707 Electrical installations of buildings - Requirements for special installations or.pdf
IEC 60364-5-548 Electrical installations of buildings - Selection and -spam- of electrical equi.pdf
IEC 60364-5-56 Electrical installations of buildings - Selection and -spam- of electrical equip.pdf
IEC 60364-5-55 Electrical installations of buildings - Selection and -spam- of electrical equip.pdf
IEC 60364-5-54 Electrical installations of buildings - Selection and -spam- of electrical equip.pdf
IEC 60364-5-52 Electrical installations of buildings - Selection and -spam- of electrical equip.pdf
IEC 60364-1 Electrical installations of buildings - Fundamental principles, assessment of general.pdf
IEC 60332-3-25 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-24 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-23 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-22 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-22 Test on Electrical Cables Under Fire Condition.pdf
IEC 60332-3-21 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-3-10 Tests on electric cables under fire conditions - Test for vertical flame spread of.pdf
IEC 60332-2_2 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-2_1 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-2 Tests on electric cables under fire conditions - Test on a single small vertical insu.pdf
IEC 60332-1_3 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-1_2 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-1_1 Tests on electric and optical fibre cables Under Fire Condition.pdf
IEC 60332-1 Tests on electric cables under fire conditions - Test on a single vertical insulated .pdf
IEC 60331-31 Test on Electrical Cables Under Fire Condition.pdf
IEC 60331-12 Test on Electrical Cables Under Fire Condition.pdf
IEC 60331-11 Test on Electrical Cables Under Fire Condition.pdf
IEC 60331 Fire Resisting Charecteristics of Electric Cables.PDF
IEC 60298 A.C. metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to .pdf
IEC 60269-4-1 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of.pdf
IEC 60269-4 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of s.pdf
IEC 60269-2-1 Low-voltage fuses - Supplemetary Requirements for Fuses for use by authorized perso.pdf
IEC 60269-2 Low-voltage fuses - Supplementary requirements for fuses for use by authorized person.pdf
IEC 60269-1 Low-voltage fuses - General requirements.pdf
IEC 60255-24 Electrical relays - Common format for transient data exchange (COMTRADE) for power s.pdf
IEC 60255-23 Electrical Relays - Contact Performance.pdf
IEC 60255-22-5 Electrical relays - Electrical disturbance tests for measuring relays and protecti.pdf
IEC 60255-13 Electrical relays - Biased (percentage) differential relays.pdf
IEC 60255-8 Electrical relays - Thermal electrical relays.pdf
IEC 60255-6 Electrical relays - Measuring relays and protection equipment.pdf
IEC 60255-5 Electrical relays - Insulation coordination for measuring relays and protection equip.pdf
IEC 60255-3 Electrical relays - Single input energizing quantity measuring relays with dependent .pdf
IEC 60245-3 Rubber Insulated Cables.pdf
IEC 60228 Conductors of Insluated Cables.PDF
IEC 60092_376 Cable for Control & Instrumentation Circuits.pdf
IEC 60092_375 General Instrumentation, Control & Communication Cables.pdf
IEC 60092-375 Ship board telecommunication cables and radio-frequency cables - General instrumentation, control and communication cables.pdf
IEC 60092-352 Choice & Installation of Cables for Low Voltage Power Systems.pdf
IEC 60092-350 Elecetrical Installations in Ship.pdf
IEC 60079-27 Fieldbus intrinsically safe concept (FISCO) and Fieldbus non-incendive concept (FNICO).pdf
IEC 60079-15 Electrical apparatus for explosive gas atmospheres - Construction, test and marking of type of protection n electrical apparatus.pdf
IEC 60079-14 Electrical apparatus for explosive gas atmospheres - Electrical installations in hazardous areas.pdf
IEC 60079-11 Electrical apparatus for explosive gas atmospheres - Intrinsic safety 'i'.pdf
IEC 60079-10 Electrical apparatus for explosive gas atmospheres - Classification of hazardous areas.pdf
IEC 60079-7 Electrical apparatus for explosive gas atmospheres - Increased safety 'e'.pdf
IEC 60079-6 Electrical apparatus for explosive gas atmospheres - Oil-immersion 'o'.pdf
IEC 60079-5 Electrical apparatus for explosive gas atmospheres - Powder Filling 'q'.pdf
IEC 60079-4 Method of test for ignition temperature.pdf
IEC 60079-2 Electrical apparatus for explosive gas atmospheres - Pressurized enclosures 'p'P.pdf
IEC 60079-1 Electrical apparatus for explosive gas atmospheres - Flameproof enclosures 'd'.pdf
IEC 60076-10 Power transformers - Determination of sound levels.pdf
IEC 60076-8 Power transformers - Application guide.pdf
IEC 60076-5 Power transformers - Ability to withstand short circuit.pdf
IEC 60076-4 Power transformers - Guide to the lightning impulse and switching impulse testing.pdf
IEC 60076-3 Power transformers - Insulation levels, dielectric tests and external clearances in a.pdf
IEC 60076-2 Power transformers - Temperature rise.pdf
IEC 60076-1 Power transformers - General.pdf
IEC 60071-4 Insulation Co-Ordination - Computational guide to insulation co-ordination and modell.pdf
IEC 60071-2 Insulation Co-Ordination - Application guide.pdf
IEC 60071-1 Insulation Co-Ordination - Definitions, principles and rules.pdf
IEC 60044-1 Instrument Transformers Part-1 Current Transformers.pdf
60364-3 Electrical Installations of Buildings.pdf
IBMAcer
Re: IEC standards
Post by IBMAcer » Fri Oct 28, 2011 11:45 am
The same? or IEC, IEEE.....
IEC, IEEE list
1. ANSI C37.42-1996 American National Standard Specification for High-Voltage Expulsion Type Distribution Class Fuses%2C Cutouts%2C Fuse Disconnecting Switches and Fuse Links.
2. ANSI_IEEE C67.92-1987 --- IEEE Guide For The Application Of Neutral Grounding In Electrical Utility Systems Part I-introduction.
3. ANSI_IEEE Std 432-1976 --- IEEE guide for insulation maintenance for rotating electrical machinery (5 hp to less than 10 000 hp).
4. ANSI_IEEE Std 665-1995 --- IEEE guide for generating station grounding.
5. ANSI-IEEE Std 125-1988 --- IEEE recommended practice for preparation of equipment specifications for speed-governing of hydraulic turbines intended to drive electric generators.
6. ANSI--IEEE Std 576-1989 IEEE recommended practice for installation, termination, and testing of insulated power cable as used in the petroleum and chemical industry.
7. ANSI--IEEE Std C37.97-1979 --- IEEE Guide for Protective Relay Applications to Power System Buses.
8. ANSI--IEEE Std C57.12.56-1986 --- IEEE Standard Test Procedure for Thermal Evaluation of Insulation Systems for Ventilated Dry-Type Power and Distribution Transformers.
9. IEEE Std 18-2002 --- IEEE Standard for Shunt Power Capacitors.
10. IEEE Std 80-2000 - IEEE guide for safety in AC substation grounding.
11. IEEE Std 142-2007 --- IEEE Recommended Practice for Grounding of Industrial and Commercial Power Systems.
12. IEEE Std 260.1-2004 --- IEEE Standard Letter Symbols for Units of Measurement
13. IEEE Std 519-1992 --- IEEE recommended practices and requirements for harmonic control in electrical power systems.
14. IEEE Std 929-2000 --- IEEE recommended practice for utility interface of photovoltaic (PV) systems.
15. IEEE Std 937-2000 --- IEEE recommended practice for installation and maintenance of lead-acid batteries for photovoltaic.
16. IEEE Std 937-2007 --- IEEE Recommended Practice for Installation and Maintenance of Lead-Acid Batteries for Photovoltaic %28PV%29 Systems.
17. IEEE Std 943-1986 (1992) --- IEEE Guide for Aging Mechanisms and Diagnostic Procedures in Evaluating Electrical Insulation Systems.
18. IEEE Std 946-1992 --- IEEE recommended practice for the design of DC auxiliary power systems for generating stations.
19. IEEE Std 946-2005 --- IEEE recommended practice for the design of DC auxiliary power systems for generating stations.
20. IEEE Std 958-2003 --- IEEE Guide for the Application of AC Adjustable-Speed Drives on 2400 to 13 800 V Auxiliary Systems in Electric Power Generating Stations.
21. IEEE Std 1010-2006 --- IEEE Guide for Control of Hydroelectric Power Plants.
22. IEEE Std 1050-1996 --- IEEE Guide for Instrumentation and Control Grounding in Generating Stations.
23. IEEE Std 1100-1992 --- IEEE recommended practice for powering and grounding sensitive electronic equipment.
24. IEEE Std 1100 - 2005 --- IEEE Recommended Practice for Powering and Grounding Electronic Equipment.
25. IEEE Std 1120 - 2004 --- IEEE Guide for the Planning, Design, Installation, and Repair of Submarine Power Cable Systems.
26. IEEE Std 1125-1993 --- IEEE guide for moisture measurement and control in SF6 Gas-Insulated Equipment.
27. IEEE Std 1138-1994 --- IEEE Standard Construction of Composite Fiber Optic Overhead Ground Wire - OPGW - for Use on Electric Utility Power Lines.
28. IEEE Std 1142-1995 --- IEEE Guide for the Design, Testing, and Application of Moisture-Impervious, Solid Dielectric, 5-35 kV Power Cable Using Metal-Plastic Laminates.
29. IEEE Std 1143-1994 IEEE guide on shielding practice for low voltage cables.
30. IEEE Std 1159-1995 --- IEEE Recommended Practice for Monitoring Electric Power Quality.
31. IEEE Std 1159.3-2003 --- IEEE Recommended Practice for the Transfer of Power Quality Data.
32. IEEE Std 1184-2006 --- IEEE Guide for Batteries for Uninterruptible Power Supply Systems.
33. IEEE Std 1247™-2005 --- IEEE Standard for Interrupter Switches for Alternating Current, Rated Above 1000 Volts.
34. IEEE Std 1248-1998 --- IEEE guide for the commissioning of electrical systems inhydroelectric power plants.
35. IEEE Std 1248-1998 IEEE guide for the commissioning of electrical systems in hydroelectric power plants.
36. IEEE Std 1283-2004 --- IEEE Guide for Determining the Effects of High-Temperature Operation on Conductors%2C Connectors%2C and Accessories.
37. IEEE Std 1300-1996 IEEE guide for cable connections for gas-insulated substations.
38. IEEE Std 1349-2001--- IEEE Guide for the Application of Electric Motors in Class I, Division 2 Hazardous (Classified) Locations.
39. IEEE Std 1366-2003 --- IEEE Guide for Electric Power Distribution Reliability Indices.
40. IEEE Std 1366- 2001 --- IEEE guide for electric power distribution reliability indices.
41. IEEE Std 1410-2004 --- IEEE guide for improving the lightning performance of electric power overhead distribution lines.
42. IEEE Std 1513-2001--- IEEE Recommended Practice for Qualification of Concentrator.
43. IEEE Std C37-91-2000 --- IEEE guide for protective relay applications to power transformers.
44. IEEE Std C37.1-1994 --- IEEE Standard Definition, Specification, and Analysis of Systems Used for Supervisory Control, Data Acquisition, and Automatic Control.
45. IEEE Std C37.2-1991 --- IEEE standard electrical power system device function numbers.
46. IEEE Std C37.011-1994 --- IEEE Application Guide for Transient Recovery Voltage for AC High- Voltage Circuit Breakers Rated on a Symmetrical Current Basis.
47. IEEE Std C37.13-1990 (1995) --- IEEE Standard for Low-Voltage AC Power Circuit Breakers Used in Enclosures.
48. IEEE Std C37.013-1997 --- IEEE Standard for AC High-Voltage Generator Circuit Breaker Rated on a Symmetrical Current Basis.
49. IEEE Std C37.14-1992 --- IEEE Standard for Low-Voltage DC Power Circuit Breakers Used in Enclosures.
50. IEEE Std C37.20.1-1993 --- IEEE Standard for Metal-Enclosed Low-Voltage Power Circuit Breaker Switchgear.
51. IEEE Std C37.20.2-1993 --- IEEE Standard for Metal-Clad and Station-Type Cubicle Switchgear.
52. IEEE Std C37.21™-2005 --- IEEE Standard for Control Switchboards.
53. IEEE Std C37.90™-2005 --- IEEE Standard for Relays and Relay system Associated with electric Power Apparatus.
54. IEEE Std C37.96-2000 --- IEEE Guide for AC Motor Protection.
56. IEEE Std C37.99-2000 --- IEEE guide for the protection of shunt capacitor banks.
57. IEEE Std C37.113-1999 --- IEEE guide for protective relay applications to transmission lines.
58. IEEE Std C57.12.00-1993 IEEE Standard General Requirements for Liquid-Immersed Distribution.
59. IEEE Std C57.12.01-1989 --- IEEE standard general requirements for dry-type distribution and power transformers including those.
60. IEEE Std C57.12.90-1993 --- Liquid-Immersed Distribution, Power, and Regulating Transformers and Guide for Short-Circuit Testing.
61. IEEE Std C57.12.91-1995 --- IEEE Test Code for Dry-Type Distribution and Power Transformers.
62. IEEE Std C57.92-1981 --- IEEE Guide for Loading Mineral-Oil-Immersed Power Transformers up to and Including 100 MVA with 55 C or 65 C Average Winding Rise.
63. IEEE Std C57.94-1982 --- IEEE recommended practice for installation, application, operation and maintenance of dry-type general purpose distribution and power transformers.
64. IEEE Std C57.98-1993 --- IEEE Guide for Transformer Impulse Tests.
65. IEEE Std C57.106-1991 --- IEEE guide for acceptance and maintenance of insulating oil in equipment.
66. IEEE Std C62.11™-2005 --- IEEE Standard for Metal-Oxide Surge Arresters for AC Power Circuits %28over 1 kV%29.
67. IEEE Std C62.64 TM -1997 --- IEEE Standard Specifications for Surge Protectors Used in Low-Voltage Data, Communications and Signaling.
IEEE guide for the application of neutral grounding in electrical utility systems.
68. IEEE Std C62.92.1-2000 --- Part I --- introduction.
69. IEEE Std C62.92-1989 --- Part II - grounding of synchronous generator systems.
70. IEEE Std C62.92.3-1993 --- Part III-Generator Auxiliary Sys
71. IEEE Std C62.92.4-1991 --- part IV - distribution
72. IEEE Std C62.92.5-1992 --- part V - transmission systems and subtransmission systems
Schtiel
Re: IEC standards
Post by Schtiel » Fri Oct 28, 2011 7:07 pm
IBMAcer
Re: IEC standards
Post by IBMAcer » Wed Nov 02, 2011 4:36 pm
EXam....
IEC 60364-3 Electrical Installations of Buildings.pdf
Umencho
Re: IEC standards
Post by Umencho » Wed Nov 02, 2011 5:04 pm
Could you prepare a list with standards? Or screen copy at least.
d4ni_R
Re: IEC standards
Post by d4ni_R » Wed Feb 15, 2012 1:34 am
Dead link, could you re upload again please?
nam2012
Re: IEC standards
Post by nam2012 » Wed Feb 15, 2012 3:41 am
d4ni_R wrote:Dead link, could you re upload again please?
http://letitbit.net/download/94194.9714 ... 1.rar.html
d4ni_R
Re: IEC standards
Post by d4ni_R » Thu Feb 16, 2012 6:09 am
nam2012 (tyou) (tyou) (tyou) (gpost) (gpost) (gpost)
but where are another links?
d4ni_R
Re: IEC standards
Post by d4ni_R » Fri Feb 17, 2012 3:00 am
nam2012, I cannot combine your part with other parts from IBMAcer. (sos) (sos)
Linkinx64
Re: IEC standards
Post by Linkinx64 » Fri Feb 17, 2012 4:03 am
pupena_san
Re: IEC standards
Post by pupena_san » Sun Feb 19, 2012 12:10 pm
d4ni_R wrote:nam2012, I cannot combine your part with other parts from IBMAcer. (sos) (sos)
+1
upload part1 please
nam2012
Re: IEC standards
Post by nam2012 » Wed Feb 22, 2012 5:38 am
u download http://letitbit.net/download/94194.9714 ... 1.rar.html
after
Delete* _ * to --> file *IECstandards.part1.rar* then combine with other parts ok, goodluck
bond
Re: IEC standards
Post by bond » Wed Feb 22, 2012 12:13 pm
It is not possible, because PART1 content “IEC standards\IEC standards.rar”, but in PART2-4 content “IEC.rar”
pupena_san
Re: IEC standards
Post by pupena_san » Fri Feb 24, 2012 8:38 am
to IBMAcer: upload part1 please
pupena_san
Re: IEC standards
Post by pupena_san » Fri Feb 24, 2012 5:29 pm
(gpost) (tyou) (tyou) (tyou)
d4ni_R
Re: IEC standards
Post by d4ni_R » Fri Mar 02, 2012 10:00 am
Linkinx64 wrote:Unpacked "IEC Standards":
http://www.4shared.com/folder/YjmlZk2Q/ ... dards.html
d4ni_R
Re: IEC standards
Post by d4ni_R » Fri Mar 02, 2012 10:04 am
I cannot find IEC 62278 and IEC 60721.
Could anyone help me? Please. (sos) (sos) (sos)
Thank you.
caspercasper
Re: [?]: iec 61131 standards
Post by caspercasper » Fri Jan 11, 2013 6:04 am
Links broken
muglicar
Re: IEC standards
Post by muglicar » Mon Feb 18, 2013 3:12 pm
Hello everbody can some ohne help me please I need IEC 60364 complete standard if somebody has it i would be wery gratfull
cheres (oo)
frotico
Re: IEC standards
Post by frotico » Fri Jun 07, 2013 3:12 pm
In this folder I have all the files from the links above and others:
https://www.dropbox.com/sh/teejjloh8xjdcsc/4yhOY2GD4B [ old]
https://www.dropbox.com/sh/jdzizy3eiwwc ... L_6za?dl=0 [ new]
I am searching for these ones follow. The ones I have already find (and you can download from the link above) I will put an (0k) beside.
Data Organisation
IEC 82045-2
IEC 61360
ISO 10303-210
ISO 10303-212
Designation
IEC 61175 (0k)
IEC 61666 (0k)
IEC 81346-1
IEC 61346-1 (0k)
IEC 81346-2 (0k)
Documentation Rules
IEC 61355
IEC 62023
IEC 62424
IEC 82045-1 (0k)
Labelling
IEC 62491
Preparation of Documents
IEC 60848 (0k)
IEC 61082 (0k)
IEC 62027 (0k)
IEC 82079
Symbols
IEC 60617 (0k)
ISO 14617
ISO 81714 (0k)
Specially for IEC81346-1
mdim
Re: IEC standards
Post by mdim » Tue Jun 11, 2013 3:15 pm
Hi all,
Can anyone send EN ISO/IEC 17050
Thank's a lot
frotico
Re: IEC standards
Post by frotico » Wed Jun 12, 2013 4:32 pm
mdim wrote:Hi all,
Thank's a lot
Spanish... but can help
http://pt.scribd.com/doc/50086155/NTC-ISO-IEC17050-1
http://pt.scribd.com/doc/50085573/NTC-ISO-IEC17050-2
mdim
Re: IEC standards
Post by mdim » Thu Jun 13, 2013 12:05 am
Gracias, frotico
But english would be better, if anyone has it
caspercasper
Post by caspercasper » Mon Jul 01, 2013 1:39 pm
Links still broken. Any updates?
frotico
Re: IEC standards
Post by frotico » Tue Aug 20, 2013 2:28 pm
caspercasper wrote:Links still broken. Any updates?
CasperCasper,
My dropbox folder is still on
and
have all the links posted until now.
Give a look.
reeaws
Re: IEC standards
Post by reeaws » Mon Nov 11, 2013 4:04 pm
@fortico thank you for the dropbox folder, very usefull. (tyou)
IBMAcer
Re: IEC standards
Post by IBMAcer » Thu Dec 26, 2013 5:42 am
IBMAcer
Re: IEC standards
Post by IBMAcer » Fri Dec 27, 2013 3:16 pm
iec 60439-2 low-voltage switchgear and controlgear assemblies - particular requirements for busbar http://123doc.vn/share/NDUw
IBMAcer
Re: IEC standards
Post by IBMAcer » Sat Dec 28, 2013 8:41 am
iec 60364-7-707 electrical installations of buildings - requirements for special installations http://123doc.vn/share/NjUw
frotico
Re: IEC standards
Post by frotico » Tue Feb 04, 2014 9:53 pm
IBMAcer
Re: IEC standards
Post by IBMAcer » Mon Apr 07, 2014 11:14 am
iec-60584-2-thermocouples-tolerances http://123doc.vn/share-iec-60584-2-ther ... s/MTcyNjg=
iec-60584-1-thermocouples-reference-tables http://123doc.vn/share-iec-60584-1-ther ... s/MTcyNjk=
arifinbc
Re: IEC standards
Post by arifinbc » Mon Apr 07, 2014 1:24 pm
dear all,
please share for standard:
iso 1219:2012
iso 5599
NFPA 780:2013
eamonnatwork
IEC 61131-3:2013
Post by eamonnatwork » Wed Sep 02, 2015 12:45 pm
Would anyone here be able to provide IEC 61131-3:2013 Programmable controllers - Part 3: Programming languages.
This is the document: https://webstore.iec.ch/publication/4552
I have the 2003 version (2nd Edition) but cant get the 2013 (3rd Edition) having the object-orientated changes anywhere :(
It really would be a great help to me to get it :(
OK, thanks for reading :?
luuxiii
Re: IEC standards
Post by luuxiii » Fri Mar 25, 2016 9:59 pm
anyone who would have
IEC 62941 - Labeling of cables and cores
Zer0G
Re: IEC standards
Post by Zer0G » Fri Nov 25, 2016 2:44 pm
Does any one have: IEC 60945:2002 Maritime navigation and radiocommunication equipment and systems - General requirements - Methods of testing and required test results ?
Thank you!
Schtiel
Post by Schtiel » Sat Nov 26, 2016 3:53 pm
Zer0G wrote:IEC 60945:2002 Maritime navigation and radiocommunication equipment and systems - General requirements - Methods of testing and required test results
http://sendspace.com/file/xx1r2x
http://ifolder.ru/45431692
