It is currently Sat Jan 19, 2019 5:22 am
PostPosted: Sat Oct 01, 2011 10:15 pm
A scalance X204-2 is connected to system... The scalance seems to be working normally but the fault led is on...
I checked the internet for same problems and found this;
Need to find out the reason for fault (lit red "F" LED) on scalance X204-2. The communication is working fine for all the ports (flashing yellow/green LED's for ports), but the "F" is still red.
No fault mask have been used for any of the ports, and redundant power is also disabled.
The guy answering this post mentions of Web Based Management but i don't know of any...
Please help, i am definitely open to all advices... (I have to connect and -if possible- remove fault without restarting.. Due the system is working in a plant and plant is on....
Thanks in advance,
PostPosted: Sun Oct 02, 2011 4:18 am
When CPU is dropped in STOP mode, look (online) in PLC/CPU Messages/...... You will see the reason.
Good luck.
PostPosted: Sun Oct 02, 2011 9:33 am
What are behavior of CPU' leds?
PostPosted: Mon Oct 03, 2011 1:32 pm
The system is connected to the CPU with "IM 153-4 PN (ERTEC200) for S7-300 SMs"...
Thanks for your interest but there is only problem left is the fault led on the scalance (X204-2)...
Scalance is woking normally but somehow the fault led is on... i checked the internet for same faults and a reply made me interested;
You can delete the name in the Web Based Manager of the switch. Then the F-LED should return to normal again and the Fault should disappear.
what is web based manager????easy to use??? can please someone help???
thanks in advance...
my kind regards.....
PostPosted: Sat Nov 22, 2014 3:24 pm
hi bro,
try to connect the second redundancy power supplie (L2,M2)
