It is currently Mon Jan 21, 2019 12:47 pm
Post new topic Reply to topic  [ 141 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Dec 28, 2010 2:24 am
English http://translate.google.com/translate?j ... 0%23p41070
Under W7 x64 native tablet does not work - if you disable UAC hardlock not start - issued a system error 1275, but ...
All earned by W7 Ultimate x64. The drug took away: http://depositfiles.com/files/69h5ibih0 .
The only thing I would like - to correct statement:
For normal installation, you must disable UAC.
1. Install Eplan P8 2.0.5.4602, required setting the "management rights" from the "examples / basic data" if the installation does not deliver, it just pops up and the message: "Information Rights Management is currently unavailable. The database file is missing or broken access to the file. As to infringement can not be established unequivocally, it is impossible to run the program.
2. Copy the license file (SN-U10225.EGF) from folder to folder EPLAN_P8_2.0_patch_Windows_x32x64 C: \ User \ Public \ Eplan \ Common \;
3. Remove driver protection HL Hasp Control Panel - Programs and Features (Right-click on Eplan License Manager - Edit, then do the hardware key driver is unavailable);
4. Install newer drivers HASPUserSetup.exe;
5. 5189.reg run the file and add data to the registry;
6. Run the driver installation Multikey - emulator from your Release \ MultiKey64 \ install.cmd;
7. Run a test mode in Windows 7 x64 dseo13b.exe running the program and the radio button for "Enable Test Mode".
8. In one corner will display "Test Mode Windows 7 Rekease 7600;
9. 9. Run the program dseo13b.exe;
10. 10. Add a digital signature for the driver Multikey.
11. Reboot your computer;
12. Start the EPLAN Electric P8 2.0.5.4602 and enjoy his work
In Russian
Под W7 x64 родная таблетка не действует - при отключении UAC hardlock не запускается - выдается системная ошибка 1275, но...
Под W7 Ultimate x64 все заработало. Лекарство взял отсюда: http://depositfiles.com/files/69h5ibih0.
Единственное что хотелось бы - поправить инструкцию:
Для нормальной установки необходимо отключить UAC.
1. Устанавливаем Eplan P8 2.0.5.4602, обязательно установив "управление правами" из раздела "примеры/основные данные" если при установке не поставить, то как раз и выскакивает сообщение: "Данные управления правами в настоящий момент недоступны. Файл базы данных отсутствует, либо нарушен доступ к этому файлу. Поскольку причину нарушения не удается установить однозначно, запустить программу невозможно."
Image;
2. Копируем файл лицензии (SN-U10225.EGF) из папки EPLAN_P8_2.0_patch_Windows_x32x64 в папку C:\User\Public\Eplan\Common\;
3. Удаляем драйвер защиты HL Hasp в Панель управления - Программы и компоненты(правой кнопкой по Eplan License Manager - Изменить, далее сделать недоступным драйвер аппаратного ключа);
4. Устанавливаем более новые драйвера HASPUserSetup.exe;
5. Запускаем файл 5189.reg и добавляем данные в реестр;
6. Запускаем установку драйвера Multikey - эмулятора из папки Release\MultiKey64\install.cmd;
7. Включаем тестовый режим Windows 7 x64 запустив программу dseo13b.exe и установив переключатель в положение "Enable Test Mode". Кстати, сразу отметим, что здесь же предусмотрено обратное действие "Disable Test Mode", отключающее тестовый режим;
8. Перезагружаем компьютер. В углу появится надпись “Тестовый режим Windows 7 Cборка 7600”;
9. Запускаем программу dseo13b.exe;
10. Добавляем цифровую подпись для драйвера Multikey. Для этого выбираем "Sign a System File" и вводим имя файла, включая полный путь C:\Windows\System32\Drivers\multikey.sys, тестовый режим не выключаем!!!
11. Перезагружаем компьютер;
12. Запускаем EPLAN Electric P8 2.0.5.4602 и наслаждаемся его работой
PostPosted: Thu Jan 13, 2011 1:02 pm
Does anybody have crack with 3d import option for Eplan 2.0 . Operation system XP x64
PostPosted: Mon Jan 17, 2011 11:54 pm
I made all until this step:
... and obtain a dos windows saying:
"No devices were removed
devcon failed."
and in effect i can't find any multikey file in the c:windows/system32 nor in c:windows/sysWOW64
have you any idea about the problem? my system is of course win7 64bit professional
strangely the "install.cmd" in the MultiKey32 directory seem to work, ... no message error but no multikeys file in any case is installed where it have to
pls anyone can help?
eplan p8 2.0 can work or not under windows 7 64bit (sincerely still i haven't understood this)
thx for your work
PostPosted: Thu Jan 20, 2011 11:10 am
how can i get eplan electric and cabinet work together.
if i use the setup.bat i can't run cabinet until i start dongle service. if i start this dongle emulator the electric give me no licence. (h) (wow)
version 2.0.5 have two seperate cracks can't be together in same time.
version 1.9.5 have the same crack. and it works perfectly.
PostPosted: Thu Jan 20, 2011 10:13 pm
6. Run the driver installation Multikey - emulator from your Release \ MultiKey64 \ install.cmd;...
I had the same problem. You must copy all files from directory \MultiKey64 to \Windows\system32 and then start install.cmd
After this its work fine.
:D
PostPosted: Tue Feb 15, 2011 5:18 pm
Can you please tell me how to stop all emulators and cracks once I already run setup? I have original dongle but now it does not work. How can I stop this emulator and run eplan with my original dongle?
If i delete SN-U10225.EGF from common folder it does nothing.
PostPosted: Tue Mar 22, 2011 8:42 pm
cracking of this program do not understand :(...how this program cracking??? As illustrated explanation of..please..
PostPosted: Sat Mar 26, 2011 8:49 pm
Can anybody help me?
I've got already installed P8 1.9.10 (3725) and Cabinet 1.9.5 (or .6 don't remember now) + 5.5 or 5.7 - doesn't matter. I installed P8 2.0.5 4602 w/o any problems, I copied all .FST and .EFG to the folders where they should be and...
when clicking EPlan 2.0 icon twice - nothing happens. Task manager shows for a few seconds that W3U.EXE starts, but suddenly it disappears.
Why can't I even see EPLAN starting screen?
What am I doing wrong? Should I firstly remove old 1.9.10 version, before I install 2.0 or what?
PS.
Dongle emulator 1.9 is stopped and disabled.
PS2.
I forgot to write : system is WinXP SP2...
PostPosted: Wed Mar 30, 2011 10:23 pm
Nobody knows the answer for my question?
Maybe the problem is with some hardware requirement (?).
Eplan official website is "under reconstruction", so I can't check what are minimum system requirements to start P8 2.0.
hmmm...
But is it possible that 2.0 needs much more "power" than 1.9 SP1?
PS.
I found the reason of the problem. EPLAN 2.0 works only at processors with SSE2, so my old XP2500+ Barton can't run this program :/ .
PostPosted: Fri Apr 15, 2011 7:53 pm
i can´t make it work on Win7 x64. i don´t understand what you mean with "Right-click on Eplan License Manager - Edit, then do the hardware key driver is unavailable"
"Right click on Eplan License Manager - Edit" this is clear so far, but the rest is very bad english....
what do you mean with " then do the hardware key driver is unavailable" ???
PostPosted: Sat Apr 16, 2011 12:22 am
Deimos wrote:
hi, new solution is released in this site http://www.eplan-eb2.ys168.com/ try new solution then post again.
PostPosted: Sun Apr 17, 2011 11:38 am
Thank you very much for your answer. But your manual is in chinese! i don´t understand your manual.
PostPosted: Sun Apr 17, 2011 12:17 pm
Deimos wrote:
http://x7.to/l4jxqs try this
PostPosted: Tue Apr 19, 2011 3:55 pm
i could not fix it this way. Strange; on an other system, the crack worked fine, on mine, it doesn´t. After every reboot, the device manager showed the "SafeNet Hardlock key" with a "!". i tried several hours, but nothing worked. I had to copy all important files from the first system to mine, reboot, and worked.
Thanx anyway for your affort.
PostPosted: Wed Apr 20, 2011 5:20 pm
I tryed to install Eplan P8 2.0.5.4602+Crack. Installation went fine but when i am trying to open Eplan it is asking me to validate a licence. I have also intall the SP1 patch. Can you please help me guys. Thank you
PostPosted: Fri Apr 22, 2011 2:32 pm
hello, please can anybody help me. I am trying to install it on window 7 professionel. :(
PostPosted: Wed Apr 27, 2011 8:54 pm
Hi...
i have been using Eplan 1.9.6 but have been some time since the last time i used it so i am not completely up to date on what is going on with Eplan.
I just downloaded the new one 2.0. I want to know how is it with the Eplan 2.0 and Eplan cabinet. Is there also a new version of Cabinet or is it working with the old one???
Thank you very much!
Bye!
PostPosted: Wed May 25, 2011 10:46 pm
Tanks man !!
PostPosted: Tue Jun 07, 2011 8:38 pm
As far as I understand, installation should be started without those "Test mode", it should be enabled only after certain steps. Maybe thats just your case.
By the way, to enyone, who is annoyed with "test mode". First link google gave me was: http://www.raymond.cc/blog/archives/200 ... 4-bit-x64/ with description of few methods. I like this one: http://www.citadelindustries.net/ReadyDriverPlus/ . But in this case you might be annoyed with modified loader.
PostPosted: Wed Jun 22, 2011 8:38 pm
please experts (oo) (oo) (oo) (oo) (oo) (oo) (oo)
do me a favor and tell me how to use this with windows 7 x64. I'm working with eplan for the last four years. i knew the crack of setup.bat working but only in x86.
some one can do a simple video for it or some screen shots. (wow) (wow) (h) (h)
i'm trying the long way for one month till now. each time i said may be i do a mistake but i could't get it work. someone confirm that it work with windows 7 x64 :anon: :haha:
"3. Remove driver protection HL Hasp Control Panel - Programs and Features (Right-click on Eplan License Manager - Edit, then do the hardware key driver is unavailable)"
there is no license manager only eplan licence client. some can help me?
PostPosted: Wed Jul 06, 2011 2:44 pm
Hi all,
This week i'm following a course for eplan.
On our laptops we have the latest eplan version and a full license dongle in the back.
Can somenone please provide me a how to and the tools to dump this dongles
Thx in advance
PostPosted: Wed Jul 06, 2011 3:50 pm
Dongle monitoring/dumping tools you can find here: http://www.dongla.net/download.html
This topic will be helpful: http://www.reteam.org/board/archive/index.php?t-565.html
PostPosted: Thu Jul 07, 2011 3:11 pm
Thx for the info
I've been busy the last 24h to try the dump al te sticks but it doesn't seem to work.
Ive tried toro and i get the errors 2 and 6
I cant monitor anything.
Its on a original xp sp3 system
On a vmware session it is te same story.
Does someone know this problem?
Or is it something else that i have to take in account?
I would be a shame not be able to dump . These dongles are fully licensed.
PostPosted: Thu Jul 07, 2011 4:42 pm
I will try with my dongle tomorrow and send you "step-by-step" procedure and needed software.
But my dongle is for e-Plan 1.9 , maybe they had changed protector already.
PostPosted: Fri Jul 08, 2011 10:08 am
Step-by-step:
1. HASP HL Drivers: http://www.dongla.net/storage/dongles/H ... _setup.zip
Download, install it and restart PC
2. ToRo Alladine Dongle Monitor: http://www.dongla.net/storage/dongles/haspmon32.zip
Download and install it. Find in UsbFilter "UsbFilter_Install.inf". Right-click it and select "Install" from the context menue. Restart PC on request
3. Run ToRo Alladine Dongle Monitor and run ePlan. In the TORO's log window see for Hardlock_In MODAD.
Write down MODAD
4. Download and unpack HL Dump: http://www.dongla.net/storage/dongles/hl-dump.zip
Run hl-dump.exe. Type your MODAD and press Enter (hex or decimal, better decimal).
Wait when dumping finished, it wil takes a few minutes
5. At the end of dumping type description (e.g. "eplan") and press enter to close console
6. You will find MYLOCK.REG in same folder where hl-dump.exe
7. Download and launch MyLock FST Builder: http://www.dongla.net/storage/dongles/m ... uilder.zip
and convert your .REG to .FST
8. Create new folder (let's call it "eCrack") and copy there MYLOCK.FST
9. Copy all .EGF files from C:\Documents and Settings\All Users\Application Data\EPLAN\Common\ (C:\Users\Public\EPLAN\Common in Win7/Vista) to eCrack
10. Download hardlock emulator: http://www.eplan-eb2.ys168.com/
and copy hardlock.sys and SETUP.BAT to eCrack as well
11. Run SETUP.BAT
PostPosted: Sat Jul 09, 2011 3:25 pm
Special thanks to you Linkinx64, for your time and effort!!!
Unfortunately in the classroom, someone has noticed the things i was doing and during the lunchbreak he talked about it at the table.
The teacher was immediately suspicious and all of our laptops were taken and placed in front of the classroom.
And all afternoon long he came checking our pc's to see what we where doing.
I'm really sorry that i couldn't make it in time.
PostPosted: Sat Jul 09, 2011 5:25 pm
Hello u all,
I do get an error message on step 1
after that i get an error message at step 3, but this is OK, as I have not fulfilled step 1
please advice. I am running win 7 64 bit Ultimate
many thanks!
UPDATE:
The walkthrough of Interlock works 100%
PostPosted: Sat Jul 09, 2011 7:46 pm
Hello to all
can somebody update the dongle modules?
I am interested into the ones in red
many thanks
PostPosted: Wed Jul 13, 2011 1:43 am
I tried to install following instructions but I don't get full license. When I start the EPLAN_Electric_P8_2.0_Emulator and run the setup.bat it says Hardlock is running. What do I wrong?
Note: When I installed eplan p8 1.9.10 and try to run the hardlock emulator I get error message 1275.
I have windows 7 64bit home edition.
Could someone help me please?
PostPosted: Wed Jul 13, 2011 11:20 am
open command prompt
write "net stop hardlock"
then do what is in "Interlock's" post (the top of the page)
then it should work
if it's not working, open again cmd and write "net start hardlock".
keep us posted :)
PS.
Does anyone have any idea about other license keys available in internet for EPLAN? I really need a license key with the Autocad Inventor modules.
Many thanks.
PostPosted: Wed Jul 13, 2011 6:54 pm
(not_allow)
Hi,I have a lot of problem to install Dongle Emulator.
During the installation of HUSP_HL_Driver I have a message "Installation Failed"
During the USBFilter Installation,click dx - install, I have not problem but when restart I have a problem with the startup and The Toro Alladin Dongles Monitor don't connect.I have this message
OPENING HARDLOCKFILTER(......\HASPMON32\HARDLOCKFILTER.SYS)error 6.
My System is WIN7 64Bit
Can you helpme?
I need,if is possible,the procedure that i can tested with my machine.
PostPosted: Wed Jul 13, 2011 9:07 pm
Thanks for your reply.
Everything what you said is written in setup.bat when I run this it says hardlock is running. But I have still no license. I did everything in "Interlock's" post.
Could someone help me?
PostPosted: Thu Jul 14, 2011 12:12 am
download this EPLAN_Electric_P8 2.0 Emulator(2010-08-25).rar from http://www.eplan-eb2.ys168.com/
run setup.bat
if it does not work, PM me ;)
PostPosted: Thu Jul 14, 2011 12:41 am
PDLFFALF wrote:
news crack:
"Net Based Wiring" cracked.
can someboady please post a link to the license key. It's written that it also contains some aditional options for Autocad Inventor
Many thanks
PostPosted: Thu Jul 14, 2011 11:28 am
Hi all,
I can't work with Eplan.Dongle Emulator installation isn't good.I have test again Toro Emulator connection but the result in terrible.I have test on another PC with the same result.
Are you sure that fine well in win 7 64 bit.
Please help me
PostPosted: Thu Jul 14, 2011 12:17 pm
On Windows XP SP3 x86 it works fine - tested. Should work on Win7 x32 as well.
64-bit Windows require 64-bit drivers (kernel-mode drivers at least), so it may influence on Toro.
Dump your dongle with Windows XP. Later converted .reg-file (.fst-file) with hardlock emulator can be used on Win7 x86 7 x64.
PostPosted: Thu Jul 14, 2011 12:31 pm
Ok thanks,I have no problem with XP.EPL 2.0.9 work fine.
Can you show me which is the procedure?
My-lock Builder is the right program for .reg/.fst
PostPosted: Thu Jul 14, 2011 7:30 pm
@sadefa there is no such file on that website. I have already de setup.bat file, when I run this it says hardlock is running but I stille have no license. I have tested on a win7 x86 and works fine. But win7 64 bit does not work.
@Linkinx64 which driver do we need to install? Where can I download the driver?
PostPosted: Thu Jul 14, 2011 7:48 pm
Toro dongle monitor uses Usb Filter driver. Driver name: AladdinUsbFilter.sys
I think no such driver for 64-bit yet. I not found it in search engines.. (Google, Bing, Yandex etc.) So, I think at the moment dongle dump can be done with 32-bit Windows only...
PostPosted: Thu Jul 14, 2011 8:06 pm
:D
Many many thanks.I wait new driver.I reinstall XP and work with this.If you have a news,please contact me.
Bye
PostPosted: Thu Jul 14, 2011 11:24 pm
well there is something that might make your EPLAN work on 64x. I have a 64x and it works. read my previous post
PostPosted: Fri Jul 15, 2011 6:54 am
EPLAN and EPLAN emulator work with x64. Toro doesn't work.
PostPosted: Fri Jul 15, 2011 8:51 pm
YES! It works I don't know what I did wrong but it works finally!
Thanks guys for this great up!
(gpost)
PostPosted: Mon Jul 18, 2011 10:45 am
(boom)
Hi all,
I don't understand but with win 7 64 i can't works fine.Licence manager don't see the key.
Please give me the exatly procedure for win 7 64bit.
PostPosted: Tue Jul 19, 2011 2:21 pm
Use this:
In Russian
I personally tested this and it works 100%. Follow every step that's into the manual and it will work.
PostPosted: Tue Jul 19, 2011 5:09 pm
:D
Thanks.Work fine.
My problem was with UAC.I solve and now work.
how can I repay?
PostPosted: Sun Aug 07, 2011 11:02 am
http://www.ecae.co.kr/download/Electric_P8_2.0_SP1_2.0.9.4831.zip
http://www.ecae.co.kr/download/Trial_License_download.zip
This link is fast speed, But without license.
Please upload license.
Thank you. (tyou)
PostPosted: Mon Aug 08, 2011 12:08 pm
the old one works fine with this version also :)
PostPosted: Mon Aug 08, 2011 5:33 pm
Eplan Electric P8 2.0 SP1 4831 (32Bit/64Bit) | 1.25 GB
EPLAN Electric P8 is the ultimate flexible solution for global controls design engineering. It’s highly innovative and user friendly. In fact, EPLAN Electric P8 is so much more that to better describe what makes it different, superior and ahead of its time, perhaps we should mention what it’s not.
New dimensions in engineering
We have been developing engineering solutions for more than 20 years. As a subsidiary of Rittal within the Friedhelm Loh conglomerate, we are synonymous with continuous development, innovation, longevity and secure investment.
True to our motto "EPLAN your Engineering", we provide our customers with innovative solutions for an array of engineering disciplines and for industrial manufacturing, including professional services for customized solutions and integration of systems within your organisation. When used in conjunction with Autodesk in mechanical design, we become synonymous with global expertise in CAE and CAD.
A presence in over 50 countries across the globe ensure that a professional consultant service is close at hand. More than 18,000 customers of all sizes from a broad range of industries, are using our solutions every day – and are opening up new dimensions in engineering.
About EPLAN Electric P8
EPLAN Electric P8 is proven to help increase quality, reduce cost and bring products to market faster whenever and wherever electrical controls design is an important part of a business.
EPLAN Electric P8 is not a drafting package. With EPLAN Electric P8, you will eliminate, repetitive, unproductive, mundane and tedious manual work associated with traditional drafting packages. No more spending valuable time on wire numbering, device naming, cross referencing, checking for errors and creating bill of materials and wire lists. Instead, you’ll get to focus your full attention on design engineering to meet critical deadlines and fulfill high accuracy and quality expectations.
What's New in EPLAN Electric P8 2.0
Propelled by 25-plus years of solid experience, constant innovation and industry leadership in the electrical CAD/CAE field, EPLAN takes you to a new dimension in design automation where your ability to create, manage and document your controls hardware projects will reach new levels of efficiency, flexibility and global integration. You'll gain unprecedented productivity, quality and accuracy in the design of your electrical schematics and all associated reports, lists and forms.
Version 2.0, the much anticipated and the biggest upgrade since the unveiling of the EPLAN Platform in 2006 boasts over 1,000 new and improved features to make companies’ engineering even more efficient, more precise and more integrated.
Discover the next generation of EPLAN software - Here are just a few of the cutting edge capabilities you'll find in the new EPLAN Electric P8 v2.0.
EPLAN Pro Panel Add-on Module
With the EPLAN Pro Panel module users can now quickly and easily create drawings and production documentation of panel layouts with associated 3D views. Fully integrated into the EPLAN Platform, it offers greater control and flexibility to make optimum use of the available mounting space. The result is substantial quality, cost and efficiency gains in collaborative product development process
Net Based Wiring Add Module
The Net Based Wiring Module allows users to create schematics without having to pay special attention to the order in which the components are connected. They can simply add this information into the schematics later when the spatial arrangement of the components and their optimal wire routing is finalized
link
http://letitbit.net/download/84757.876c7c81c5cac9cb5142fad61521/EPLAN20.part3.rar.html
http://letitbit.net/download/49236.49f5724e5bd8d6335bfa8fcc36d5/EPLAN20.part5.rar.html
http://letitbit.net/download/03775.04660d0cf89aa452b3149857662f/EPLAN20.part1.rar.html
http://letitbit.net/download/11999.16a4f5f0e4bfd19308d7bb55c644/EPLAN20.part2.rar.html
http://letitbit.net/download/24690.2e520c5f2e4842e77feb5ea728df/EPLAN20.part4.rar.html
PostPosted: Tue Aug 09, 2011 8:38 am
plz rapid link
thnx (clap)
Users browsing this forum: No registered users and 9 guests
