[?]: unPassword Library in ABB Compact Control Builder
I would like to know the PWD for ControlBasic 1.0.11.
I would like to take a look inside PidLoop Func. blocks.
Thanks Linkinx64
Thanks Linkinx64
Re: [?]: unPassword Library in ABB Compact Control Builder
Also SignalLib1.4.7 if possible 10Xste_fan wrote:I would like to know the PWD for ControlBasic 1.0.11.
Thanks Linkinx64
ControlBasicLib 1.0-11: ЕndhcKtalц
SignalLib 1.4-7: 20jbdBCVbq
See this topic how to type characters marked in █ color: viewtopic.php?f=3&t=14434&p=43871
regards, Linkinx64
regards, Linkinx64
10xALot for the help....i wonder who made this tool for password reveal
About how to implement...not a problem...Cyr alphabet is part of my language BIG REGARDS!
Control Builder: Copyright, ABB.ste_fan wrote:....i wonder who made this tool for password reveal
OllyDbg v1.1: Copyright, Oleh Yuschuk.
Bpx and decryption : Copyright, me
... probably Cyr not a problem for you too
Not problem at all. I even understand the words written on Cyrillicste_fan wrote:... probably Cyr not a problem for you too
Here under the spoiler I will explain how to type password with extra characters (e.g. cyrillic letters) without changing Windows regional settings.
Of course, You can also google for the character table matching to your native code page, but the method I describe is valid for all code pages supported by Windows.
Instructions
1. Start Windows Character Map (Start->All Programs->Accessories->System Tools)
2. Select character set Windows:Cyrillic
3. Find character in Cyrillic and remember it ASCII code:
4. Change character set back to your own code page (e.g. we use in system Windows:Western)
5. Find character with same ASCII code in western character set:
6. Replace Cyrillic characters in password with character set selected in your operating system (in our example - Western).
As I mentioned before the CCB library consist on file with .lbr extension + folder (L_MecProfABBLib1p1-1-0-0): viewtopic.php?f=3&t=14434#p41037
Please upload MecProfABBLib1p1-1-0-0.lbr file.
You have right, my fault.
http://www.megaupload.com/?d=0AT0IURW
One question. Is there any way to unpassword project to Wago PLC?
I don't know. I've never worked with WAGO PLC. Even don't know which software needed for PLC project...s_macia wrote:Is there any way to unpassword project to Wago PLC?
Password: mormecs_macia wrote:http://www.megaupload.com/?d=0AT0IURW
I have trouble with DI+SOE modules related to alarm lib. It seems that when downloading the project for the first time the time stamps for the event and alarm are working, but if you download it again it's not keeping the values in the list.Could be possible to decript the Alarm lib to check why like that? (probably statuses or other relevant data is not cold retain?) The system is ver.5.1. I will check the Alarm lib code number tomorrow. Thanks in advance
I think it must be like that.st_e_fan wrote:Could be possible to decript the Alarm lib to check why like that? (probably statuses or other relevant data is not cold retain?) The system is ver.5.1.
Password for AlarmEventlib 1.5-8 already been found: viewtopic.php?f=3&t=14434#p46438
Yes you're right...before one week there's a rollup with bug fixes and now most of libs are changed. I have included a export of several libs..It would be great if you could check them. Thaks a LOT in advance
Here is the link : https://rapidshare.com/files/733935110/Libs.afw
and
and
These libraries are for AC 800M Connect 5.1.0/1 and can be unpassworded only with Control Builder M 5.1.0/1.st_e_fan wrote:before one week there's a rollup with bug fixes and now most of libs are changed. I have included a export of several libs..
At the moment I don't have neither Compact nor Professional release of Control Builder version 5.1.0/1.
When I obtain a new version I will research and publish passwords (if it is still possible).
I'll try to upload but it will take a lot of time...if i remember right it's about 5-6G..I hope it will be finished after the end of the next week. regards to all
I've got Compact Control Builder 5.1-0/1.
Worst expectations came true - ABB has changed protection.
I will research how to decrypt now, but it will take some time...
Hello.
I need your help. I need to unpassword library.
http://www.4shared.com/archive/DuVr1XnN/Libraries.html
