[REQUEST] ZenOn 6.50 Sp 0 Build 1 crack
Hello, anyone has a crack for this version of ZenOn 6.50 Sp 0 Build 1 ? In the version 6.2 was the possibility to due modification in HEX editor in the ZENONE32 which disable the time limit and lets only the Demo message. Is anyway to do this in this version.
Re: [REQUEST] ZenOn 6.50 Sp 0 Build 1 crack
Hi Hi
You said In the version 6.2 was the possibility to due modification in HEX editor in the ZENONE32 which disable the time limit and lets only the Demo message
can you explain this way please .
because I have zenon6.2 demo and I want to cracked it
best regards
best regards
If you're able to change the version 6.2, you can also easily change the version 6.50.Realitatea wrote:Hello, anyone has a crack for this version of ZenOn 6.50 Sp 0 Build 1 ? In the version 6.2 was the possibility to due modification in HEX editor in the ZENONE32 which disable the time limit and lets only the Demo message. Is anyway to do this in this version.
Just to refresh you ideas the protection is not in zenon32,but we must modify three .dll files.
In addition we must inject a few lines of code in a .dll OK??
Do not write unnecessary things when you do not know what you speak.
Send me please the byte to change and the offset for hex editor.
Hi SHKODRAN
I have zenon 6.2 demo version and I'd like to crack it . can you help me and explain how can I do that . please
best regards
best regards
Does anybody crack the ZenOn 6.50 Sp 0 Build 1 crack now?
I need it ugret!
I need it ugret!
Hello anbody Do you have zenon 6.21 or higher for Post link.
I have project file but I can not opent this file because i dont zenon software
someone can help me please..
Thank in advance..
Thank in advance..
Here are links to download Zenon 6.21
http://www.mediafire.com/?vd7l3a2xc8bksg2
http://www.mediafire.com/?a2g7jfafwnzlr82
http://www.mediafire.com/?73vo7hqjkodvzo5
http://www.mediafire.com/?dcdcjh4gjd3j16d
http://www.mediafire.com/?3304p7m3e86z61t
http://www.mediafire.com/?aiybsq38hc3ggd1
You can try it but I have not got any medicine for it.
Brdgs
Brdgs
please help me!!!
i need crack ZENON 6.2...
help me...thanks so much...
hi garibaldik , thank you, but the link does not work.
"The file you are trying to access is temporarily unavailable."
any other link ?
any other link ?
friend,have you zenon 6.51 SP0 crack?
Sorry but I don't have Zenon 6.51 SP0 medicine.
https://rapidshare.com/files/893816540/ ... 2_S1B0.rar
I uploaded zenon 6.2 medicine also on rapidshare :hi garibaldik , thank you, but the link does not work.
any other link ?
i installed zenOn620 Sp4 and copied zenon32.dll from https://rapidshare.com/files/893816540/ ... 2_S1B0.rar. But when i run ZENONE32.exe i got error "The procedure entry point ??0CD_CObList@@QAE@H@Z could not be located in the dynamic link libary CD_TOO32.dll".
Pls help me solve it.
Thanks for milion
Thanks for milion
The "zenon32.dll" works only with Zenon 6.22 SP1 BUILT 0.
HI all.
I need te Keygen for activation Zenon 6.50 RUNTIME .
Tnks all.
Tnks all.
[LINK] zenon Science Package (zenon 6.51 SP0)
ftp://copadata.at/203390_5020/intsales/ ... ackage.iso
Incudes:
- zenon 6.51 SP0
- straton workbench
- Installation Tutorial and other documentation
- USB Driver
- straton Firmware for the Mindstorms NXT 2.0 Controller
Incudes:
- zenon 6.51 SP0
- straton workbench
- USB Driver
- Forum Community
Could somebody reupload crack for 6.22sp1 build 0
thanks in advance.
thanks in advance.
Download from here: http://www.mediafire.com/?42ycsr6m5cm1o23
Hello!
Is there a crack or keygen for 7.00 SP0?
Thanks in advance!
Thanks in advance!
Hello
I removed the time limit for the 6.51 version,I want to try with version 7.0, Im having trouble downloading it from the link posted by "Link"
So Can anyone split the Zenon_7.0_SP0 file posted by Link into several files and upload to rapidshare
ZeRon
ZeRon
Hi all
thanks svoicum for uploading the files
I upload the 2 modified files ,
backup and replace old files to remove the time limitation
https://rapidshare.com/files/3742889166 ... %20SP0.rar
note that this crack only removes the time limit ,u will always have "start demo.." message
Ill try soon with V7
ZeRon
Always Ready to Learn...
ZeRon
Hello Zeron.
Thanks for the archive and good luck with v7.0, please, feel free to update us on your status
Only the time limit is the real bugger, as I am trying to test some functionalities.
hi all
have anyone tried to install the v7 version posted by svoicum , im having error "reading package..." when trying to install.
ZeRon.
Always ready to learn...
ZeRon.
This link appears broken, could somebody upload this file again? Thank you.ZeRon wrote:Hi all
ZeRon
For those who need zenon 7.0 license, you may contact this person.
The solution is not free, but working at 100%.
I just bought it, I'd say it works properly.
who wants his contact, con contact me.
Best Regards.
Best Regards.
I need,
,think you...
,think you...
I need,
think you!
think you!
Hi, everyone!
Who can give me a update patch from zenon 6.50_SP0_Build1 to 6.51_SP0_Build5?
Thanks so much!
And i am also focus on how to crack zenon, it seems not so hard!
Thanks so much!
ZeRon
I need,
think you!
think you!
Could sombody reupload medicine for ZenOn 6.50 or 6.51 ???
Thanks in advance!
Thanks in advance!
I need too...mike1976 wrote:This link appears broken, could somebody upload this file again? Thank you.
Link dead!
Re-upload please!
Tank You!
Ariel.
Re-upload please!
Tank You!
Ariel.
i need too, pei163pei@163.com,thank you very much!
Can somebody upload the crack to version 6.20 or 6.5x?
For vesion 6.22 you have:
Zenon_6.22_sp1_build_0_TEAM_UARE_medicine.rar
http://www.mediafire.com/?cw3g3y1b83ai5ws
Zenon622_sp0_build6_update_and_medicine.rar
http://www.mediafire.com/?qcfnn6mfifjt4xg
somebody have medicine for version 6.5 ??? please upload ....
@mytom123 do you use this medicine for version 6.51 sp0 ???
I try your medicine for version 6.51 sp0 build9 and NOT working ...
If you use this medicine and it's working, could you tell me your build version ???
Thank you!
Thank you!
Not my crack. Thanks to reZon about this
Now I use zenon 7.00 demo but last time I used for zenon 6.51 SP0 build 1 and it worked
You can read read.txt inside for some notice warning after software start up.
Brgds.
Brgds.
Thank you about this information ... i must find build 1 of 6.51 sp0 .... on build 9 it's not working ...
Thank you!
Have a nice day!!!
Update....
It's working on version 6.51 sp0 build0 ... everything is ok now ...
You can get version 6.51 sp0 build0 from here:
ftp://ftp.copadata.at/203390_5020/htdoc ... 51_SP0.iso
Thank you!
Have a nice day!!!
Update....
Update....
working on version 6.51 sp0 build5
Anybody has zenon 6.51 sp0 build 9. Could you share it?
Thanks and regards.
Thanks and regards.
I need,SHKODRAN wrote:For those who need zenon 7.0 license, you may contact this person.
Best Regards.
Hi! I need the crack for zenon 7.0 .
contact me if is possible, please.
thank you!
thank you!
Hi! I need the crack for zenon 7.0.
Thank you!
Thank you!
Hi, everybody!
The help with v6.51 treatment is necessary. Whether there is at whom a solution of this problem?
