[?]: emulator for Spac Automazione 2010
Тools, Elcad, Eplan, ...
Duca99x
Post by Duca99x » Fri Sep 17, 2010 12:32 pm
Hi! someone have this emulated key for Spac Automazione 2010 ?
Mesner74
Re: [?]: emulator for Spac Automazione 2010
Post by Mesner74 » Fri Mar 04, 2011 8:49 pm
please maverik create dump file for spac2010
Please guy426 create emulator for spac2010
guy426
Post by guy426 » Wed Mar 30, 2011 7:31 am
Crack + keygen for Spac Automazione 2011
Enjoy!
http://www.megaupload.com/?d=0W1LUKV0
xblu
Post by xblu » Wed Mar 30, 2011 10:16 am
Thank you Guy, you are very good
djto
Post by djto » Wed Mar 30, 2011 3:28 pm
guy426 wrote:Crack + keygen for Spac Automazione 2011
Enjoy!
Hi guis426
The Crack + keygen is for spac 2010 or spac 2011
many thanks
djto
xblu
Post by xblu » Wed Mar 30, 2011 6:18 pm
Guy426,
Please help me! the installation goes well, but when i run the program, appear a window that say " protection key absent"
How can i do? thank thank you
djto
Post by djto » Thu Mar 31, 2011 3:48 pm
Enjoy!
Dear Guys426
I have installed spac 2011 with success, but when i run the application tells me no hardvare key and the program starts in demo mode you have some suggestion ?
Djto
xblu
Post by xblu » Fri Apr 01, 2011 2:35 pm
Hello Djto, do you have solved the problem?
djto
Post by djto » Fri Apr 01, 2011 5:07 pm
xblu wrote:Hello Djto, do you have solved the problem?
NO
The Sapc program runs only with the commands of autocd.
The commands of spac are not active because hardware key is not present.
We want the hand of the great GUY426
Djto
guy426
Post by guy426 » Mon Apr 04, 2011 7:50 am
djto
Post by djto » Mon Apr 04, 2011 11:31 am
guy426 wrote:Try this new release
http://www.megaupload.com/?d=GBOAFNAZ
Hi Guy426
I copied the dvd of spac on hard disk replaced spac.aut with you
executed (SPACAutomazione2011.exe )
execute install.bat for starting dongle emulator
execute key_2011 and insert code (12 char without "-")
After installation Running spac
Message
Hardare key is not correct error #0#
in this case running only autocad command
many thanks for you job
Djto
Sorry Guy426
I copied spac.aut after installation inside directory
spac automazione cad 2011\program\key
The program running OK
you great
Bay
xblu
Post by xblu » Mon Apr 04, 2011 7:11 pm
Hello Guy426,the program run very well, thank you for your job, you are great! (clap)
fortee
Post by fortee » Wed Apr 06, 2011 5:06 pm
guy426 hello, I'll offer my congratulations, great job you're great.
sakan
Post by sakan » Fri Apr 08, 2011 3:13 pm
the emulator ask me 12 digit....
but i have 18 digit with 2 space.
what can i doooooooooooo? (h)
miacrer
Post by miacrer » Sat Apr 09, 2011 3:42 pm
Hello guy426.
Congratulations for your work.
I want to know if there is the possibility to run the emulator under windows 7 64bit ... I read in web that is possible with the use of the file DevCtrl.exe instead of wdreg.exe...you have any idea about it?
Thanks in advance.
xblu
Post by xblu » Mon May 23, 2011 8:17 pm
hello guy426
can you create the emulator of SPAC AUTOMAZIONE 2011 for Windows 7 64 bit?
thank you
djto
Post by djto » Tue May 24, 2011 3:57 pm
Installing Spac 2010 by inserting the code visualize this error
because
many thanks
djto
djto
Post by djto » Sun May 29, 2011 11:22 am
Hello guy426 or anyone who wants to replicate
You have an idea what generates this error
You have tried the version Spac 2010
Djto
xblu
Post by xblu » Mon May 30, 2011 9:27 pm
Hello Dito, why don't you install 2011 version? you can download it at www.sdproget.it
this one run perfectly
Hi and hi to guy426
djcatalyst
Post by djcatalyst » Wed Aug 10, 2011 6:56 am
PLEASE GUYS
where can i download Spac Automazione 2011
withot request CD from www.sdproget.it
thx
MareBlu
Post by MareBlu » Wed Aug 10, 2011 10:51 am
[url]h++p://w+w.sdproget.it/Download/IsoImage_Download.asp?productID=SPAC%20Automazione%202011[/url]
virbru
Post by virbru » Thu Aug 18, 2011 4:06 pm
Hello
I need the module cables (modulo cavi) Spac2011Automazione
Thank you.
(h)
djto
Post by djto » Wed Aug 24, 2011 2:12 pm
xblu wrote:Hello Dito, why don't you install 2011 version? you can download it at http://www.sdproget.it
Hi and hi to guy426
Dear all,
I don't succeed in installing + spac automation 2011 on the pc with windows 7 32 bits. The procedure of installation is correctly performed, but when I launch the application, it visualizes the message "key hardware not present. You know how to tell me where I am wrong. The file spac.aut I replace him/it at the end of the installation and later execute the program
xblu
Post by xblu » Wed Aug 24, 2011 6:12 pm
Djto Hello, I tried to install it on 64bit windows7 and did not work, I think that the emulator only works with XP
djto
Post by djto » Fri Aug 26, 2011 3:44 pm
xblu wrote:Djto Hello, I tried to install it on 64bit windows7 and did not work, I think that the emulator only works with XP
Hello Xblu
I cannot understand why spac 2009 with windows 7 works while the 2010 no my pc has only 1 GByte ram then 2011 i cannot install it. With windows xp pro i can't install any version of spac; when i put the code generated by Keygen tells me that it is wrong i don't understand + nothing
Help me please
The good guy426 will be on summer holidays
Mesner74
Post by Mesner74 » Fri Sep 16, 2011 5:02 pm
Y have a problem.
the driver "eutron" in the windows 7 x64 don't no install
set the "wdreg" with the administrator, y don't no install
i have a lpt1 installed y working.
please help (sos) (sos)
(tyou)
maverik53
Post by maverik53 » Sat Sep 17, 2011 10:55 am
@ Mesner74
Select Wdreg.exe (C:\Windows\system32\drivers)
With the mouse right button go to Property
Go to TAB Comptibility e select run in Windows Xp SP3 mode.
Install the program.
I have tested on Win 7 32 Bit
(welc) (welc)
Mesner74
Post by Mesner74 » Sun Sep 18, 2011 7:57 pm
in the windows 7 64 bit not work
:( :x
mpautomations
Post by mpautomations » Sun Oct 09, 2011 6:02 pm
I have the same problem, on windows 7 64bit and on windows xp.
p.s. the fisically lpt port is missing.
Please somebody help me!!!!
Paolone
Post by Paolone » Fri Dec 09, 2011 12:41 pm
Hello to All
I'd install Spac 2011 and copy *.aut in the key folder, but when I run spac2011 still the message Key Absent
If I check the Key with the Hardware key program Tell me that the key is good
What's wrong?
Thank all
alex_the_bes
Post by alex_the_bes » Wed Dec 05, 2012 4:27 pm
Please Can You Put the links?
The oldest no more working
Thank You
alex_the_bes
Post by alex_the_bes » Thu Dec 06, 2012 10:56 am
Enjoy!
Can You re-post on another file sharing this Crack and Keygen Please?
I'll appreciate that.
Thank You in advance.
sharp73PC
Post by sharp73PC » Thu Mar 07, 2013 5:05 pm
Enjoy!
hi guy426, the you posted is not running.
can you please tell us where we could find it, posting an update link?
thank you very much.
I have another question: i tried to install spac automazione 2010 in several pc, beu the installation wizard program tells me, at the first step, that ther is an error of the Date of my pc. and the installation aborts. I tried to change the Date of the system , but nothing changes. can You help me?
the OP i tried with are:
W7 ultimate 64 bit
W7 home edition 64 bit
XP SP3 32 bit
Dendoh
Post by Dendoh » Fri Dec 06, 2013 7:37 am
Does anybody have a working cracked spac? 2010 or newer
GAVAMAR
Post by GAVAMAR » Thu Jul 31, 2014 2:26 am
Hello All,
I need the same think for install Spac Automazione 2010 or 2011.
If somebody have this Crack + keygen I will be very happy.
Thanks in advance.
