It is currently Wed Oct 17, 2018 3:16 pm
Russian
Clear Registry LNK tools
Start>Run>Regedit
Stop and Disable WebClient
Stop + Disable + Apply
Restart PC :(
Russia wrote:
Профилактическое лекарство
Обнулить LNK
Пуск>Выполнить>Regedit
апрет WebClient
Стоп+ Отключена + Применить
Перезапуск компа
RESULT :(
New info from Siemens wrote:
Update from Siemens
sysclean.zip
Correct: India.
It features:
s7db_open s7db_open
s7blk_write s7blk_write
s7blk_findnext s7blk_findnext
s7blk_read s7blk_read
s7_event s7_event
s7ag_test s7ag_test
s7ag_read_szl s7ag_read_szl
s7blk_delete s7blk_delete
s7ag_link_in s7ag_link_in
s7db_close s7db_close
Russian wrote:
Александр Гостев
Это функции:
s7db_open
s7blk_write
s7blk_findfirst
s7blk_findnext
s7blk_read
s7_event
s7ag_test
s7ag_read_szl
s7blk_delete
s7ag_link_in
s7db_close
s7ag_bub_read_var
s7ag_bub_write_var
Siemens wrote:
==== Russian ========
greg2008 wrote:
Take a look here:
& here:
for more info on the virus...
symantec wrote:
It checks:
2. Method of infection
w32_stuxnet_dossier.pdf
see video:
symantec, 11/13/2010 wrote:
Video
The PLC is infected.
• Normal operation resumes.
Who's lying?
(boom)
No one can believe :(
To Langner
Russian wrote:
Никому нельзя верить.
Отповедь руссофобу Лангнеру.
Update:
KIS2011 detect all.
КИС 2011 задетектил.
About Gas Centrifuge
and
Updated: Jan. 15, 2011
Siemens security test
2008 Automation Summit
A Users Conference
How to crack PCS7
Russian
Symantec W32.Stuxnet Dossier
Version 1.4 (February 2011)
Russian wrote:
Oldman wrote:
June 3, 2002
3 июня 2002 года
Symantec in RUSSIAN
July 5, 2011
Russian wrote:
One year later
This is not our Cyber
but it exist
Cyber wrote:
Posted: April 11, 2008 19:27
Russian wrote:
Год спустя.
из статьи wrote:
Наш Кибер, не тот Кибер 2008.
Maybe it's a reaction:
Russian wrote:
Возможно это реакция:
Symantec
Russian wrote:
Then they come to you (boom)
Тогда они придут к вам (boom)
See the Results
Russian
Virus Stuxnet
WITHOUT BACKDOOR
Our project is not commercial
наш проект не коммерческий
Stuxnet live anew (boom)
Pucket Putin WinCC Server :)
 Post subject: Fake news
Global attack (boom)
Сайты антивирусов молчат.
