It is currently Mon Dec 17, 2018 11:38 pm
Post new topic Reply to topic  [ 32 posts ]
PostPosted: Sat Oct 30, 2010 8:02 pm
hello to all
has anybody had software PCM600 Engineer Pro with IEC61850 ?
Could you upload it?
also software tool for ABB CAP505??
i need it :lol:
PostPosted: Tue Nov 02, 2010 9:24 pm
Here you can download CAP 505 V2.3
http://www.mediafire.com/?936622boparrnbl
and upgrade to V2.4
http://www.abb.com/product/db0003db0042 ... country=VN
I need PCM600 pro too. Anyone has it? Could you upload it?
Rdgs.
PostPosted: Wed Nov 03, 2010 10:16 am
thnx buddy...i still cant find pcm600 ...but i'll tell u when i have it..!!!
PostPosted: Sun Nov 21, 2010 11:36 pm
Download the PCM600 from http://rapidshare.com/files/432287980/PCM600.iso
I need ABB Testing Software for IEC61850. There are two software.
ITT600 SA (Commercial)
ITT SA Synchronizer (For ABB Internal Use)
Kindly upload, if you have.
Regards
Leo-Ali
PostPosted: Wed Nov 24, 2010 9:30 pm
i am not able to download it from this link...please post another link asap
thanx in advance
PostPosted: Thu Nov 25, 2010 1:34 pm
Hello
I have a PCM 600 software v2.3 CD - possible latest version at the present day.
I never use it and never install. So if you got errors during install or usage I can't help you. If interesting - linkz be low:
PCM600-23_ver_2.3.part1.rar http://depositfiles.com/files/ab7wb87l1 Size: 200Mb
PCM600-23_ver_2.3.part2.rar http://depositfiles.com/files/s3b8j35lq Size: 200Mb
PCM600-23_ver_2.3.part3.rar http://depositfiles.com/files/7vs8eb8b1 Size: 155Mb
Before install check in the PCM600 installation guide: maybe some setup prerequisites required.. :?:
Regards
PostPosted: Mon Nov 29, 2010 8:56 am
Has anybody had "RE_ 670_IEC Connectivity Package" for PCM600 2.3 and "Communication Configuration Tool (CCT)' ?
Could you upload its?
Rdgs.
PostPosted: Mon Nov 29, 2010 9:02 pm
mytom123 wrote:
Has anybody had "RE_ 670_IEC Connectivity Package" for PCM600 2.3 and "Communication Configuration Tool (CCT)' ??
CCT v4.1.3 you can get here: http://depositfiles.com/files/9723ouigp
I have a Relion 670 Series IED Connectivity Package, not an IEC. Are you sure you looking exactly for RE 670 IEC Connectivity Package?
PostPosted: Sat Dec 04, 2010 4:58 pm
I have seen before with PCM 600 1.5 they have package software call "RE_670 IEC Connectivity package" and "RE_670 ANSI Connectivity package " included "RE_ 670 Connectivity Package Base v.1.5r07" and Transmission IED modules ( RED670, RET670,...) . I do not know that it is same or different with "Relion 670 series IED Connectivity package".
Brgs.
PostPosted: Tue Dec 07, 2010 2:58 pm
I have this software:
If this is what u looking for I can upload and drop the link (Unpacked size - approx. 900 MB).
PostPosted: Wed Dec 08, 2010 4:53 pm
Plz upload it
PostPosted: Thu Dec 09, 2010 10:23 am
Here we go
Relion-670-ConPkg_v.2.1.3.part1.rar http://depositfiles.com/files/se4caied2 Size: 220Mb
Relion-670-ConPkg_v.2.1.3.part2.rar http://depositfiles.com/files/qkoxngifv Size: 220Mb
Relion-670-ConPkg_v.2.1.3.part3.rar http://depositfiles.com/files/fhperv3nl Size: 220Mb
Relion-670-ConPkg_v.2.1.3.part4.rar http://depositfiles.com/files/kcedxigix Size: 204Mb
PostPosted: Thu Dec 09, 2010 6:08 pm
http://www.abb.com/abblibrary/DownloadCenter/?showresultstab=true&categoryid=9AAF400323
PostPosted: Mon Dec 27, 2010 3:59 pm
...I have a PCM 600 software v2.3 CD - possible latest version at the present day.
I never use it and never install. So if you got errors during install or usage I can't help you. If interesting - linkz be low...
Someone can tell me about version of this product
PCM600 or
PCM600 Engineer?
I need graphical application configuration but I didn't find this.
PostPosted: Sat Jan 01, 2011 7:13 pm
Hello evrybody,
I'm looking for some ABB manuals.
Does anybody has Technical Descriptions of Functions (CD-ROM) 1MRS750889-MCD and would like to share it?
PostPosted: Wed Feb 09, 2011 11:19 am
Does anybody have PCM600 Engineer or Pro?
I need graphical application configuration but I didn't find it.
Also I can not find CAP 531.
Is this the same thing?
PostPosted: Tue Mar 22, 2011 11:14 pm
leofarhan wrote:
Regards
Leo-Ali
I have got both ITT600 SA Explorer and ITT SA Synthesizer, but they don't work without licenses.
From user manuals:
ITT600 SA Explorer provides only one way for licensing:
- License bound to a PC (Hard disk ID)
License bound to a PC means you will receive one license per
installation on a PC. To run the ITT600 SA Explorer on another
PC, users will need a new license for that PC (this is also called
node-locked).
ITT SA Synthesizer Licenses are file based and node locked
licenses.
NOTICE:
Licenses are not transferable between PCs! Every installation
needs its own license.
PostPosted: Tue Mar 22, 2011 11:53 pm
Hello Greenman,
Can we run them for demo period, if so can you upload.
Thanks & Best Regards
Leo-Ali
PostPosted: Sat May 07, 2011 6:15 pm
The link of PCM600 http://rapidshare.com/files/432287980/PCM600.iso is no more valid.
Also, I need the ITT600 SA Explorer. Please HELP.
(sos) .
PostPosted: Sun May 15, 2011 3:06 pm
Any updates? Pls. share these 2 tools with me too.
Thanks in advance!
PostPosted: Fri Jun 10, 2011 10:25 am
Anybody has this software?
Plz upload it.
Brgds.
PostPosted: Thu Dec 08, 2011 4:46 pm
I downloaded CCT 4.1.3, patched it. It is working but, when I try to import ICD file, appearing "key not found " message.
Is there another version or another patch.
Best Regards
PostPosted: Sat Jan 21, 2012 8:29 pm
Hi guys
I had to work with ABB stuff several times. PCM600 latest version is 2.4. Even the basic version should be registered via ABB Server. You must create a special key, send it to ABB and they return you a valid license. There is no way to bypass the registration process unless someone is able to crack it.
Worst of all is IET Tool 5.1 and ITT600. Those software comes from ABB Switzerland and is much more protected than PCM600. The software doesn't run on a virtual machine neither via terminal server. Without crack there's no chance. Sorry to say that. Even inside ABB you have to buy a license wich is fixed to a special notebook or PC. If someone has got any news, please post it here. :mrgreen:
Rudi
PostPosted: Tue Jan 24, 2012 7:48 pm
I had imported a couple ICD files for test: no any "key not found" message or other warnings I got.
Could you upload your ICD to let me try?
I have seen cracked internal versions of ITT600 SA Explorer and ITT 600 SA Synthesizer on forum.
PostPosted: Fri Feb 03, 2012 5:39 pm
Dear All,
Could you Please Re upload CCT 4.1.3 because the link already dead
Best Regards
PostPosted: Sat Feb 04, 2012 7:50 pm
Link is alive. Another link is: http://www.4shared.com/zip/kTMdpPxd/CCT-600_413_Communication_Conf.html
PostPosted: Wed Feb 22, 2012 6:13 pm
Has anybody had PCM600 2.4 Engineering ? Could you upload it?
The PCM600 2.4 basic version only support parameter setting, not support application configuration.
Brgds.
PostPosted: Sat Feb 25, 2012 10:55 pm
PCM600 2.4 SP1 doesn't require a license anymore! Basic functionality and Graphical Application Configuration (Engineering) is now free. You don't need any license keys at installation. You only need license for the IET600 Tool (license must be ordered separately). You can download PCM600 here: https://www143.abb.com/SoftwareLibrary You only need to register once to get an account to be able to download.
Use the Update Manager that comes with PCM600 to download Connectivity Packages for relays.
PostPosted: Mon Feb 27, 2012 2:21 pm
Thanks a lot for your support
Brgds.
PostPosted: Sun Dec 30, 2012 3:37 am
Dear All,
Can you please upload CCT600 4.1.3 patch...?
Best Regards
PostPosted: Tue Jun 04, 2013 8:28 pm
I would need ITT 600 SA Explorer. How can I get it? Only for testing the software.
Thanks in advance.
PostPosted: Thu Nov 02, 2017 9:41 pm
Hi Linkinx64
I have smilar problem when i want to upload ICD file. "key not found" mesage appear on the screen.
Could you help. (sos)
https://hizliresim.com/6yNgy9
Best Regards.
