[INFO]: Simatic RoadMap - Step7 v5.6, TIA v15, PCS7 v9.0
Janosch07
Post by Janosch07 » Thu Feb 11, 2010 2:32 am
Does anyone knows whats new in Step7 5.5 ?
If it supports W7 maybe ??
Regards
7 year after
2017 wrote: https://support.industry.siemens.com/cs ... nance-v5-6
Compatibility with other products
STEP 7 V5.4 SP4 or higher is required.
STEP 7 V5.6 or higher for Windows 10
STEP 7 V5.6 for Windows 10
Does anyone know any information and when will it will be released ?
Info
Re: [?]: whats new in Step7 5.5 ?
Post by Info » Thu Feb 11, 2010 8:44 am
Step7 V5.5 support Windows 7 32-bit
Link_is_Dead :(/S ... _s_New.zip
24 KB
Slides
https://support.automation.siemens.com/ ... ews_en.pdf
STEP 7 V5.5
„ Betriebssysteme
„ XP Professional
-> Keine Freigaben mehr für Windows Vista!
Windows 7 32-bit
„ Support neuer Hardware
„ Support PROFINET V2.2
„ Shared device
„ iDevice
„ Media redundancy MRP
„ Taktsynchronität
„ Anwenderdefinierte Webseiten
„ Block Privacy
Profinet 2.2
Produkte
ƒ PN-Controller
ƒ ET200 PN
Feature
ƒ Isochronous mode
ƒ Cl-Cl-reaction-time ca. 750µs
ƒ Shared Device
ƒ iDevice
ƒ Media redundancy (not bumpless)
ƒ Mini IP-Config (only IO-Ctrl)
ƒ PROFIenergy
It comes on april, and on july or august the PLCSim, S7Graph, SCL,... supports Windows 7 32-bit.
WinCC Flexible 2008 SP2 comes Q2/2010 and supports Windows 7 32-bit (Ready: 2010-05-06 http://support.automation.siemens.com/W ... n/38612895 )
Support PC Runtime wide resolutions : 1920x1200, 1920x1080, 1680x1050, 1440x900
End of year TIA Portal Step7 Basic V11 wil come, it integrates full flexible and supports 1200 V2.
Next year, the TIA Portal V11.5 and V12 may come.
Here are Step7 and WinCC then also be integrated.
Firsttime the TIA Portal will be a 32Bit Software.
64Bit Version:
1st 64Bit Version will be Step7 V5.5 SP1. It comes on 01/2011 (sorry).
Middle of 2011 every Software from Siemens will be able to run under Win7 64-Bit.
The future is with Siemens TIA.
This has nothing to do but with PCS7.
Here, the clocks tick differently.
But I think the normal Step7 still remains a long time preserved.
But who knows how it really developed.
I think next year we will have lots of fun
greets,
centi
Schtiel
Re: [?]: whats new in Step7 v5.5 ?
Post by Schtiel » Tue May 25, 2010 7:23 pm
Umencho wrote:I just detected - now info about version 5.5 is missing there. :shock:
But it is available here:
http://support.automation.siemens.com/W ... n/42123315 :wink:
SIMATIC NET CP 343-1 firmware update V2.3, Entry ID:42123315, Date:2010-04-06 wrote:Product improvements
* If no PN IO functionality is used, no check is made for duplicate device names. Therefore, no error LED is activated.
* With the NCM S7 diagnostics (special diagnostics), you can now also read the status of the PNIO device or PNIO controller from STEP7 V5.5.
Some information is also available in this presentation (in German):
http://www.siemens.de/industry/automati ... EWS_RM.pdf
STEP 7 Version 5.5: neue Funktionen
Allgemein
- Unterstützung Windows 7 (32 Bit) Ultimate/Enterprise und Professional
- Abkehr von Windows Vista
- Bausteinschutz (Offline) mittels Tool S7-Block Privacy
- Überarbeitung der Anwender-Dokumentation (Online-Hilfe und Handbücher).
HW-bezogene Funktionalität: HWKonfig / Diagnose / Netpro / SFM:
- Unterstützung einer Reihe neuer Baugruppen (Schwerpunkt PNIO)
- Unterstützung weiterer PROFINET Funktionalität wie:
-- Shared Device
-- I-Device
-- MRP (media redundancy protocol)
-- Mini IP Config
-- Taktsynchronität
-- IRT
Webserver für die CPU4xx V6.0 und CPU31x V3.2 mit Ethernet-Schnittstelle:
- Benutzer-Administration für Webserver
- Zugriff über HTTPS
- Solltopologie im Webserver
Erweiterung der Kommando-Schnittstelle um verschiedene Funktionsaufrufe.
Installation von HSP vom Windows Start-Menü aus (ohne STEP 7 zu starten)
Paketierung und Auslieferung des Tools Web2PLC zur Nutzung anwenderdefinierter Webseiten in der CPU, auf der STEP 7-DVD
Immediately STEP 7 V 5.5 supports the operating systems MS Windows 7 Professional, Ultimate and Enterprise in 32 Bit default installation.
I-Device
One CPU can be set simultaneous as IO-Controller and I-Device.
o Easy and transparent IO-coupling of CPUs
o Coupling of CPUs in various projects
o Integration under external controllers
o Reduction of PN-PN couplers (Transparent Net)
Shared Device
o Simultaneous access for more controllers to the same device
o Flexible allocation of channels and modules to different controllers
o Less cabling
o Less HW-effort
o Combination of standard- and fail-safe modules
User-specific Web pages
o Web2PLC transforms user sides into data block information
o Web pages can be generated with standard HTML-editors and filed on the controller
o Part of the STEP 7-DVD
Know-how protection due to module encryption
The program-code will be encrypted with 128 Bit on the PG, encoded transmitted and decrypted on the controller.
Re-Engineering is not possible.
Comments for the interface-variables in the KOP/FUP/AWL editor
o Immediately comments of the interface-variables can be displayed in the symbol information of the network
Innovations at notify system errors (SFM)
By downloading out of the HW-Config – automatic transmission of SFM-modules
o With the function „Systemfehler Melden“ STEP 7 offers a comfortable way to display diagnostic information
o The messages will be generated automatically by STEP 7
o Immediately modules for the messages of system errors can be transmitted directly to the CPU. This guarantees the consistency
Hardware Updates
Easy run of HW-updates directly via the Windows-start menu
Re: [?]: whats new in Step7 v5.5 (11/2010)?
Post by CoMod » Thu Jun 10, 2010 4:54 am
http://support.automation.siemens.com/W ... n/43184652
Internal version of WinCC Professional v10.0 ?
Info
Post by Info » Tue Jun 15, 2010 4:11 pm
SIMATIC NET CD V8.0 (2010)
http://support.automation.siemens.com/W ... e/43264686
32 Bit Windows 7 Professional, Ultimate...
http://support.automation.siemens.com/W ... e/43021999
2010-07-26 wrote:S7-PDIAG V5.3 SP5 available now
New in S7-PDIAG V5.3 SP5
* Support of the operating systems MS Windows 7 32 Bit Ultimate, Professional and Enterprise (Standard installation). The Windows XP-Mode in Windows 7 is not released.
* S7 PDIAG is released for STEP 7 V5.5
Download
http://support.automation.siemens.com/W ... e/44037110
https://support.automation.siemens.com/ ... _3_SP5.zip
( 21056 KB )
http://support.automation.siemens.com/W ... e/15208817
F-Configuration-Pack V5.5+SP7
The following failsafe modules or features are additionally available:
Support for MS Windows 7 32Bit Professional
Support for new PROFINET functions: Shared Device; iDevice
TIAMAN
Re: Request: whats new in Step7 v5.5 (11/2010)?
Post by TIAMAN » Mon Aug 16, 2010 7:21 pm
Hello
I am a new member and my english is not good but this Forum is very good and i like it
For information STEP7 V5.5 is delivery ......
I am receive today my upgrade with my SUS licence
By
Delivery release 2010-07-26 !
http://support.automation.siemens.com/W ... n/42813614
SIMATIC S7, STEP7 V5.5, DATA MEDIUM
INCL. TRIAL LICENSE FOR 14 DAYS,
E-SW, SW AND DOCU. ON DVD, LICENSE KEY ON DVD, CLASS A,
5 LANGUAGES (GE,EN,FR,IT,SP),
EXECUTABLE UNDER WINXPPROF, WINDOWS 7 ULTIMATE, WINDOWS 7 PROFESSIONAL,
REFERENCE-HW: S7-300/400, C7
Umencho
SIMATIC PCS 7 V8.0
Post by Umencho » Wed Aug 18, 2010 2:06 pm
It's a nice booklet about PCS 7 v7.1 SP2 (08/2010) and SIMATIC PCS 7 V8.0 (12/2011)
Link_is_Dead :(/P ... Req_V1.pdf
https://www.automation.siemens.com/WW/f ... anguage=en
Info
What's New in STEP 7, Version 5.5?
Post by Info » Thu Aug 26, 2010 4:30 pm
The following subject areas have been updated:
Operating systems
As of STEP 7 V5.5, the operating systems MS Windows 7 Professional, Ultimate and Enterprise (standard installation) are supported.
Configuring and Diagnosing Hardware
- As of STEP 7 V5.5, you can create I-devices from numerous IO controllers.
- As of STEP 7 V5.5, you can use the PROFINET shared device function.
- As of STEP 7 V5.5, you can assign the IP addresses and device names dynamically.
- As of STEP 7 V5.5, you can configure media redundancy for multiple domains.
- As of STEP 7 V5.5, you can you can configure the isochronous mode for IO devices.
- As of STEP 7 V5.5, you can install hardware updates directly from the "Windows Start menu".
- As of STEP 7 V5.5, you can manage user rights for the Web server.
- As of STEP 7 V5.5, you can access Web pages of the CPU via a secure HTTPS connection.
- As of STEP 7 V5.5, you can configure keepalive times for TCP connections.
- As of STEP 7 V5.5, you can download I&M data for more than one module at the same time (using multiselection).
Configuration Changes during Ongoing Operation (CiR)
The restrictions in STEP 7 versions up to and including V5.4 regarding hardware configuration in RUN (CiR) for PROFIBUS when upgrading the STEP version no longer apply in V5.5.
Standard Libraries
- As of STEP 7 V5.5, the system functions have been expanded by the addition of SFB104 "IP_CONF" for program-controlled configuration of the integrated PROFINET interface of your CPU.
- As of STEP 7 V5.5, the system functions have been expanded by the addition of SFC99 "WWW" for enabling or synchronizing user Web pages.
- As of STEP 7 V5.5, the system functions have been expanded by the addition of SFB73 "RCVREC" for receiving data records and SFB74 "PRVREC" for making data records available on an I-device. These SFBs are only valid for S7-300 CPUs.
- As of STEP 7 V5.5, the system status list with SSL-ID W#16#xy9C has been expanded. This provides information on the configured tool changer and its tools.
- As of STEP 7 V5.5, the following FBs of S7 communication are included: FB28 "USEND_E", FB29 "URCV_E", FB34 "GET_E", FB35 "PUT_E". These are only for S7-300 CPUs and only on connections via the integrated PN interface.
- As of STEP 7 V5.5, the following two FBs for open communication via Industrial Ethernet have new names: FB 210 (previous name: "S5FW_TCP") is now called "FW_TCP", FB 220 (previous name: "S5FW_IOT") is now called "FW_IOT".
Report System Error
- As of STEP 7 V5.5, you can choose whether or not the status of slaves is evaluated when the CPU starts up.
- As of STEP 7 V5.5, the additional texts of messages are displayed or implemented in the "Message Preview", "Print" and "Print Preview" dialogs.
- As of STEP 7 V5.5, you can also download blocks generated by 'Report System Error' in HW Config
System diagnostics
- As of STEP 7 V5.5, there are two "Diagnostics in Hexadecimal Format" dialogs: one for PROFIBUS slaves and one for PROFINET devices.
Setting the PG/PC Interface
As of STEP 7 V5.5, you can use the USB prommer without needing to install additional software. The required functionality is integrated in STEP 7.
Update
Re: [INFO]: Simatic RoadMap - whats new in Step7 v5.5, PCS7.
Post by Update » Sat Aug 28, 2010 8:26 am
Windows 7 Compatibility List
Link_is_Dead :(/S ... y_list.pdf
Automation License Manager V5.0
STEP 7 V5.5 viewtopic.php?f=30&t=13500
S7-GRAPH V5.3 SP6 ( tested)
S7–PDIAG V5.3 SP5 ( tested) http://support.automation.siemens.com/W ... n/44037110
DOCPRO V5.4 ( tested)
S7–PLCSIM V5.4 SP4 ( tested) http://support.automation.siemens.com/W ... e/44230004
S7-SCL V5.3 SP5 ( tested)
F-Configuration-Pack V5.5+SP7 http://support.automation.siemens.com/W ... n/15208817
iMap V3.0 SP2
Logon V1.4 SP3 http://support.automation.siemens.com/W ... n/44889432
Modular PID Control (Tool) V5.1.2 http://support.automation.siemens.com/W ... e/45792469
Standard PID Control (Tool) V5.2.2 http://support.automation.siemens.com/W ... e/45792505
PID Self–Tuner (FBs) V5.1
SIMATIC NET PC Software V8.0 viewtopic.php?f=30&t=8339
Easy Motion Control V2.1.1
WinCC flexible 2008 SP2 ( tested) viewtopic.php?f=36&t=8650
WinCC v7.0 SP2 http://support.automation.siemens.com/W ... n/44452271
PCS V7.1 SP2
CFC V7.1 SP2
Version Cross Manager (VXM) V7.1 SP2
Version Trail 2) V7.1 SP2
Update
Post by Update » Sun Sep 05, 2010 7:06 pm
S7-GRAPH V5.3 SP6 Released for Windows 7
With immediate effect, the existing old S7-GRAPH V5.3 software incl. Service Pack 6 (S7-GRAPH V5.3 SP6 from Step7 Professional 2006 SR6) may also be used with Windows 7 (32 Bit).
http://support.automation.siemens.com/W ... n/22304138
Update
Post by Update » Fri Sep 17, 2010 7:44 pm
WinCC V7.0 SP2 for Windows 7
viewtopic.php?f=36&t=7825&p=37967#p37967
PCS 7 V7.1 SP2
http://support.automation.siemens.com/W ... e/44263415
https://support.automation.siemens.com/ ... 71_SP2.zip
Requirements for installing and operating PCS 7 software V7.1 SP2
· Windows XP Professional Service Pack 3 and Microsoft Internet Explorer V7.
· With Web Client and Web Diagnostics Client installations, Microsoft Internet Explorer V6 or V7 is permitted.
· Windows Server 2003 (Standard Edition) Service Pack 2 or Windows Server 2003 R2 Service Pack 2 (Standard Edition) and Microsoft Internet Explorer V7.
· Microsoft SQL Server 2005 Service Pack 3 is installed automatically.
Update
Post by Update » Tue Nov 02, 2010 5:36 pm
Compatibility lists regarding DriveES products
DriveES v5.5 for Windows 7 estimated delivery 03/2011 :(
http://support.automation.siemens.com/W ... n/18495518
Update
Post by Update » Fri Nov 19, 2010 6:55 am
http://www.siemens.com/press/en/pressre ... 112513.htm
S7-1200 v2.0 Controllers enhanced by Profibus, Profinet and telecommunication services (pgood)
Nuremberg, Germany, 2010-Nov-16
The Siemens Industry Automation Division has added new Profibus, Profinet and telecommunication services to the communication functions of the Simatic S7-1200 controllers.
New CPU firmware enables communication with Profinet IO devices.
With two new communication modules, the Simatic S7-1200 can be operated as a Profibus master or slave.
Three new telecommunication components are available to users when they want to access the controller remotely from a PC or programming device...
They then have remote access to the controller using a programming device or PC equipped with the Step V11 engineering software and Internet access.
Info
Post by Info » Fri Nov 19, 2010 7:37 pm
The new TIA Portal V11 contains the following programs:
- Step 7 for PLC 300,400 and for future the 1500 STL/FBD/LAD/SCL/GRAPH
- Step 7 Basic for the 1200 V1 and V2 FBD/LAD and SCL
- "WinCC flexible" small to advanced -> new name "WinCC"
- WinCC V7.1 -> new name "WinCC Professional"
The first official look you can make on the SPS/IPC/Drives in Nuremberg from 23.11. to 25.11.2010
I saw it already ;-)
Maybe it will be released this year.
Umencho
Post by Umencho » Sat Nov 20, 2010 7:03 am
centipede wrote:...
Could be WinCC 10.0 proffessional. :wink:
Less then 2 days remaining - https://www.automation.siemens.com/mcms ... fault.aspx
Come witness the launch of the next generation of engineering software for industrial automation.
Starting end of November 2010 you can experience a completely new dimension in engineering software efficiency and how it can increase the performance of your company.
More info at https://www.automation.siemens.com/sale ... TTPS=REDIR
Info
Re: [INFO]: Simatic RoadMap - whats new in Step7 v11, PCS7..
Post by Info » Wed Dec 08, 2010 5:43 pm
https://www.automation.siemens.com/sale ... are_en.pdf
p.25 wrote:The SCL, GRAPH, PLCSim, DocPro, and TeleService option packages familiar from STEP 7 V5.5 are already integrated into STEP 7 Professional V11 and do not require additional licenses.
Purchasers of the STEP 7 Professional Software Update Service automatically receive SIMATIC STEP 7 Professional V11
WinCC v11 wrote:WinCC Basic for configuring SIMATIC HMI Basic Panels
WinCC Comfort for configuring the new Comfort Panels as well as Mobile Panels, Panels of the x70 series and Multi Panels
WinCC Advanced for the engineering of PC-based single-user solutions
WinCC Professional for process visualization and small scale SCADA applications
jenriquez
Post by jenriquez » Fri Jan 14, 2011 5:22 pm
I want to know some news about the siemens software for win7 64 bits, or an alternative to solve this problem.
i apreciate every help, i tried to use WM but i had a lot of conflicts with the network, now i cant use siemens software un my laptop
Thanks for everything.
centipede
Post by centipede » Fri Jan 14, 2011 6:20 pm
Sorry, you must wait to 06 or 07/2011. Than the updates for Win7 64Bit comes with the Service Packs.
Info
Post by Info » Wed Jan 26, 2011 9:20 am
sventek
Post by sventek » Thu Jan 27, 2011 5:51 am
Latest news for TIA Portal V11:
Software will be released 04/2011.
Heard on a Siemens information day.
*HANNOVER MESSE 2011 (Ганноверская ярмарка) 04.04.2011 – 08.04.2011
http://www.industry.siemens.com/topics/ ... fault.aspx
sventek
Info
Post by Info » Tue Feb 22, 2011 6:00 am
Official price in Russia from 04/2011:
6ES7 822-0AA01-0YA0 STEP 7 Basic V11  ....................................................317€
6ES7 822-1AA01-0YA0 STEP 7 Professional V11  .............................................2003€
Upgrade
6ES7 822-0AA01-0YE0 Upgrade from STEP 7 Basic V10.5 to STEP 7 Basic V11 .........................106€
6ES7 822-1AA01-0XE5 Upgrade from STEP 7 Professional 2006/ 2010 to STEP 7 Professional V11 ...689€
6ES7 822-1AA01-0XC5 Upgrade from STEP 7 V5.4 to STEP 7 Professional V11  .........................1325€
6ES7 822-1AA01-0YC5 PowerPack from STEP 7 Basic V11 to STEP 7 Professional V11 ...............1696€
ex WinCC Fleхible
6AV2 100-0AA01-0AA0 WinCC v11 Basic ....................105€
6AV2 101-0AA01-0AA5 WinCC v11 Comfort ....................741€
6AV2 102-0AA01-0AA5 WinCC v11 Advanced....................1855€
ex WinCC
6AV2 103-0DA01-0AA5 WinCC v11 Professional  512 tags .........2120€
6AV2 103-0HA01-0AA5  WinCC v11 Professional  4096 tags ......2650€
6AV2 103-0XA01-0AA5 WinCC v11 Professional  64K tags .........4240€
WinCC Runtime Professional V11
6AV2 105-0BA01-0AA0 128 tags .......2242€
6AV2 105-0MA01-0AA0 65536 tags .........6254€
more info about price in russian pdf
Russian wrote:Полномасштабные поставки продукта начнутся с апреля 2011 года
Цены и заказные номера
http://iadt.siemens.ru/assets/files/inf ... V11_r0.pdf
Info
Post by Info » Fri Mar 04, 2011 10:37 pm
Post by CoMod » Wed Mar 09, 2011 8:16 pm
but what is it x?
http://support.automation.siemens.com/W ... e/48845204
Vertriebs und Lieferfreigabe für neue SIMATIC S7-1x00 Memory Card
Sales and delivery release for new SIMATIC S7-1x00 Memory Card
Продажа и доставка выпуск новых SIMATIC S7-1x00 карт памяти
Интересно - что означает x?
centipede
Post by centipede » Wed Mar 09, 2011 8:48 pm
CoMod wrote:but what is it x?
Now "2", in Future "5" ;-)
Umencho
Post by Umencho » Thu Mar 10, 2011 7:02 am
Do you have any ideas when will this be "the future"? :roll: (pgood) (wait)
Schtiel
Post by Schtiel » Thu Mar 10, 2011 12:53 pm
That's just another puzzle from Siemens :)
(c) Link
Info
Post by Info » Sat Mar 26, 2011 5:17 pm
How can I use Siemens frequency converters and servo drives within a STEP7 V11 project?
http://support.automation.siemens.com/W ... n/49229556
centipede
Post by centipede » Sat Mar 26, 2011 8:35 pm
Now I have the first infos about the S7-1500.
The release is planned for 3/2012.
Its a complete new design and it is placed between the S7-300 and S7-400.
For programming TIA V12 is nessecary.
Info
Post by Info » Wed Apr 20, 2011 7:09 pm
TIA Portal Innovation Tour 2011 (German pdf)
1_TIA_Portal_V11_Einfuehrung
2_TIA_Portal_V11_Einstieg_Erstes Projekt
3_TIA_Portal_V11_HMI
4_TIA_Portal_V11_Bibliotheken
5_TIA_Portal_V11_Geräteübersicht und Migration
6_TIA_Portal_V11_Safety
7_TIA_Portal_V11_SCL
http://www.siemens.de/industry/automati ... ehrung.pdf
http://www.siemens.de/industry/automati ... rojekt.pdf
http://www.siemens.de/industry/automati ... 11_HMI.pdf
http://www.siemens.de/industry/automati ... theken.pdf
http://www.siemens.de/industry/automati ... ration.pdf
http://www.siemens.de/industry/automati ... Safety.pdf
http://www.siemens.de/industry/automati ... 11_SCL.pdf
S7-31*T CPUs are not supported yet.
S7-41*H CPUs are not supported yet.
WinCC Redundanz / WinCC-Client mit Projekt / WinCC CAS are not supported yet.
AS-Interface, PROFINET I-Device (onboard), SIWAREX are not supported yet.
Use this or wait TIA Portal V12, V13,... ?
Info
Post by Info » Thu Apr 21, 2011 4:52 pm
Anounced release SIMATIC STEP 7 Professional V11 and WinCC V11 // заявлено о выходе
Delivery release of next pages (only pages :( ) // но пока доступны только объявы
http://support.automation.siemens.com/W ... n/49639088
http://support.automation.siemens.com/W ... n/49740133
STEP 7 Professional / Basic V11 has been approved for use with the following operating systems (32-bit):
Microsoft Windows XP Home SP3 (STEP 7 Basic only)
Microsoft Windows XP Professional SP3
Microsoft Windows 7 Home Premium (STEP 7 Basic only)
Microsoft Windows 7 Professional
Microsoft Windows 7 Enterprise
Microsoft Windows 7 Ultimate
Microsoft Windows 2003 Server R2 Standard Edition SP2 (STEP 7 Professional only)
Microsoft Windows Server 2008 Standard Edition SP2 (STEP 7 Professional only)
All engineering editions of WinCC V11 have been approved for use with the following operating systems (32-bit):
Microsoft Windows XP Home SP3 (WinCC Basic only)
Microsoft Windows 7 Home Premium (WinCC Basic only)
Microsoft Windows 2003 Server R2 Standard Edition SP2 (WinCC Advanced, WinCC Professional only)
Microsoft Windows Server 2008 Standard Edition SP2 (WinCC Advanced, WinCC Professional only)
Delivery release TIA Poprtal V11 (only with SP1) ~June // возможный срок начала поставки Июнь - только уже с СП1
(f) The delivery release of WinCC Basic, WinCC Comfort and WinCC Advanced, and related upgrades and power packs will follow in a special delivery release on 05/02/2011.
Service Packs for TIA Poprtal V11:
SP1 June - fix some first bugs
SP2 Septembr - add SCL for S7-1200
Russian Siemens wrote:SCL для S7-1200 будет вместе с SP2 для V11.
SP1 будет в июне (возможный срок начала поставки объявленного TIA Poprtal V11 Июнь - только уже с СП1).
SP2 будет в сентябре.
Oldman
Post by Oldman » Fri Apr 22, 2011 6:52 am
Again they are wise.
that it was impossible to directly test the software and do without the service packs.
What's the hurry is unclear.
Russian wrote:опять они чудят.
что нельзя было сразу обкатать софт и обойтись без сервис паков.
к чему такая спешка неясно.
greg2008
Post by greg2008 » Tue Apr 26, 2011 6:01 pm
Report should be though. At Hanover uproar. And the fiscal year ends. Homo sovietico :D - and only
Отчитаться надо однако. На Ганновере шум поднять. Да и финансовый год кончается. Homo sovietico :D - да и только
Update
Post by Update » Tue Apr 26, 2011 7:27 pm
Downloads: Operating system updates for CPU 1211C/1212C/1214C to V2.0 (for Step v11)
http://support.automation.siemens.com/W ... n/38709962
Insert a blank SIMATIC MC 24MB memory card...
You are not yet a memory card (265 Euro) ? :o
*New CPU 1211C v2.0 = 153 Euro :)
Info
Post by Info » Fri Apr 29, 2011 8:09 am
Info
Post by Info » Sat May 07, 2011 3:28 am
Delivery release SIMATIC STEP 7 Professional V10.0 !!! for HW S7-300 (close) - 2008-05-31 !!!
http://support.automation.siemens.com/C ... ion=csopen
Homeroid_BL
Post by Homeroid_BL » Sat May 07, 2011 3:44 pm
Hmmmm...
I am confused.
Noone shared TIA V11 yet.
I just received letter from Siemens that new manulas for S7-1200 V2 are released.
I downloaded manulas, looks OK.
http://support.automation.siemens.com/W ... n/49915587
But I think that is the first time in Siemens that manual is released BEFORE software.
Info
Post by Info » Mon May 09, 2011 5:32 pm
Again bla-bla-bla paper: SIMATIC STEP 7 Engineering with STEP 7 V5.x or with STEP 7 as of V11 (TIA Portal)
Date:2011-05-09
http://support.automation.siemens.com/W ... n/50023392
Russian wrote:Снова пустотрёпная бумажка о том чего нет
Homeroid_BL
Post by Homeroid_BL » Mon May 09, 2011 6:41 pm
On one forum, there is a guy who said today that he received Step7 V11 for learning, but no licence.
Anyone here has it?
http://www.plctalk.net/qanda/showthread.php?t=63008
We received our V11 disk for innovation tour training today, no licence yet.
V11 (SP1) with SUS should be next month. (=June)
Post by CoMod » Mon May 09, 2011 7:00 pm
Homeroid_BL wrote:On one forum, there is a guy who said today that he received Step7 V11 for learning, but no licence. Anyone here has it?
Has it - licence or TIA ?
from Africa, Feb 19, 2011 wrote:I ve got a very recent TIA V11 professional rental license ( to be offically released from Siemens on April 2011).
This lic is valid till June 2011.
To be honest, Unfortunately no installable software.
One friend of mine has a VMware image with V11 pilot vesrion and rentallicense.
Actually I have onli the license files. but don't know which tool is better tomake image of the usb stick:WinImage is better or PowerISO.
I ll send it to you on the following days.
I will get the VMware image file next week. but how to send it to you?
and nothing send :( Nord Africa war
Info
Post by Info » Mon May 09, 2011 8:29 pm
New paper release SIMATIC WinCC Flexible V11 =(Basic, Comfort, Advanced)
http://support.automation.siemens.com/W ... n/49961635
Readme.pdf from SIMATIC WinCC Basic V11, SIMATIC WinCC Comfort V11, SIMATIC WinCC Advanced V11 are now released for delivery... (f)
Update
Post by Update » Thu May 19, 2011 6:48 am
Update 1 for STEP 7 V11 and WinCC V11
http://support.automation.siemens.com/W ... y=47071380
jbastos
Post by jbastos » Tue Jun 07, 2011 11:33 pm
Does TIA support S7-PDIAG diagnostics?
Info
Post by Info » Tue Jul 26, 2011 12:34 pm
W64 ready (clap)
http://support.automation.siemens.com/W ... e/51714010
SIMATIC Logon V1.4 + SP4 is released only for use with STEP 7 V5.5 + SP1 on a 64-bit operating system.
SIMATIC Logon V1.4 + SP4 ist nur für den Betrieb mit STEP 7 V5.5 + SP1 auf einem 64-Bit-Betriebssystem freigegeben.
Russian wrote:SIMATIC Logon V1.4 + SP4 выпускается только для использования с STEP 7 V5.5 + SP1 на 64-разрядных операционных системах.
Voraussetzungen für den Einsatz von SIMATIC Logon V1.4 + SP4
Conditions for the use of SIMATIC Logon V1.4 + SP4
Microsoft Windows Server 2008 R2 (Standard, Enterprise, Datacenter)
Microsoft Windows Server 2008 R2 inkl. Service Pack 1 (Standard, Enterprise, Datacenter)
Microsoft Windows 7 x64 (Professional, Enterprise, Ultimate)
Microsoft Windows 7 inkl. Service Pack 1 x64 (Professional, Enterprise, Ultimate)
F-Konfigurationstool Version V5.5+SP9
Support for MS Windows 7 Ultimate - 64bit (WoW)
Support for MS Windows Server 2008 R2 - 64 (WoW)
Info
Post by Info » Mon Aug 22, 2011 6:43 pm
Link
Post by Link » Tue Oct 11, 2011 6:19 pm
S7-Distributed Safety V5.4 + Service Pack 5 64 bit
http://support.automation.siemens.com/W ... n/37592670
Link
Post by Link » Fri Oct 14, 2011 5:56 pm
Service Pack 3 zu SIMATIC iMap V3.0 64 bit
http://support.automation.siemens.com/W ... e/54759578
Service Pack 2 zu DOCPRO V5.4 64 bit
http://support.automation.siemens.com/W ... e/55109106
Umencho
Post by Umencho » Mon Oct 17, 2011 10:28 am
Drive ES Basic 5.5 SP1on WIndows 7 64 bits - release estmated for april Hannover Messe 2012
WinCC Flex 2008 SP3 release estimated on 12/2011.
I just got information from Siemens that WinCC flexible runs on a 64-bit Windows 7 station as from Service Pack 3. That means that if you want to run WCF2008 on a WIN7 64-bit machine without using any virtual machine you have to wait till the release of SP3. Expected release date could be the first weeks of december 2011.
