It is currently Fri Jul 20, 2018 1:43 pm
PostPosted: Sat Nov 13, 2010 11:39 am
How to download from letitbit for free?
PostPosted: Sat Nov 13, 2010 12:35 pm
Scowl wrote:
How to upload from letitbit for free?
u choice *regular download* after click speed slow download, wait 60s and download. goodluck
PostPosted: Sat Nov 13, 2010 1:02 pm
May be in russian there isn't free download?
PostPosted: Sat Nov 13, 2010 2:29 pm
u can copy links ru,i check, i think u can stick free on pay-ment title goodluck
Press FREE button and then No Thanks button and wait timer end
Russian wrote:
Нажми кнопку Бесплатно, затем кнопку Нет спасибо и жди таймер
PostPosted: Sat Nov 13, 2010 11:22 pm
Damn, three days watching - never seen! :))
And in Russian and English.
Thank you!
Russian wrote:
Блин, три дня смотрел - не видел! :))
И на русском и на английском.
Спасибо! :D
Thanks a lot!!!
PostPosted: Fri Dec 21, 2012 10:31 am
Get free premium code at letitbit
Dear partners.
From 20th till 31st of December New year campaign passes. Every day you can get 1 FREE premium code, that you can use as you want: download your favorite files, present it to friends or sell.
Terms of the campaign:
You must have at least 1 download http://letitbit.net/download/67742.6b63600012a2584fb15126199127/Vijeo_Designer_V5.1_EN_InClass_EP.pdf.html in the day of getting premium code
You can get only 1 premium code per day
All premium codes are valid till 1st of February
Amount of trafic at premium code depends on the date of getting it. Every day it increases by 2013 megabytes. So premium code received on the 20th of December contains 8 gigabytes of traffic,
21st of December - 10,013 Gb
22nd of December - 12,026 Gb
30th of December - 28,13 Gb
31st of December - 31 Gb
Premium code are activated
Usage of premium code is limited only by your imagination
This campaign will have no impact to your earnings. However, if you are sure in the opposite, we guarantee recalculation of your statistic in the case of reducing your earnings during the campaign. All questions related to recounting will be reviewed after the 1st of February only if the quantity of downloads will be permanent during the campaign.
