[LINK]: Unlocking protected C-/VB-functions in WinCC
Utilites for Simatic HMI
engineer
Post by engineer » Mon Oct 02, 2006 12:35 pm
How it possible - to unlocked Know_how_protected functions in winCC?
ppp
Post by ppp » Mon Dec 11, 2006 6:44 am
The program for removal of the password from C-scripts Wincc (version 5 and 6).
ppp in Russian wrote:Программа снятия парольной защиты с ВыньСС скрипта
http://s2kkpp.narod.ru/
script_WinCC_without_password
[dead]
See new version 1.6 Jun 30, 2014
viewtopic.php?f=1&t=17844
Всем удачи!
ppp
Post by ppp » Mon Dec 11, 2006 8:19 am
Manual remove password from VB-script
1. Open file in WinHex http://winhex.com/winhex/index-m.html
2. In the end the file has such appearance:
Passworded
00 00 00 01 00 00 00 00 00 00 06 00 00 00 73 5E 52 57 5E 16
UnPassworded
00 00 00 00 00 00 00 00 00 00 06 00 00 00 73 5E 52 57 5E 16
01 - Attribute of presence of the password
06 - Number of symbols in the password
735E52575E16 - The coded password
We change 01 on 00 and the script can be opened
in Russian wrote:Снять пароль с VB-скрипта еще проще.
Открываем файл скрипта любым 16-ричным редактором (например Winhex).
В конце файл имеет примерно такой вид:
где 735E52575E16 - закодированный пароль
06 - число символов в пароле
01 - признак наличия пароля
Меняем 01 на 00 и скрипт можно будет открыть.
Писать оболочку для указанных действий что-то лень.
Post by sania » Mon Dec 11, 2006 8:50 am
великое дело сделал :!:
:D :D :D :D
votuandktd
Post by votuandktd » Mon Mar 17, 2008 2:10 am
ppp wrote:Manual remove password from VB-script
I open file .bmo in Winhex, but it don't look like this. Any advance?
kiran kalburgi
Re:
Post by kiran kalburgi » Wed Jan 13, 2010 9:55 am
Yes you are correct it doenot look li this any other method???
ppp
Re: [LINK]: Unlocking protected C-/VB-functions in WinCC
Post by ppp » Tue Jul 13, 2010 7:21 am
New patcher for un/protection password c-scripts, support WinCC v4.2, 5, 6, 7
program need MS Framework >=1.1
WinccNoProtect
[dead]
See new version
Link
Post by Link » Mon Jul 19, 2010 5:16 am
Update
as not all produced by hand using WinHEX unprotect VB-scripts and added the removal of this protection in the patch.
I recall a program patches only WinCC, the project is no manipulation is not
т.к. не у всех получается вручную с помощью WinHEX снять защиту с VB- скриптов добавил снятие и этой защиты в патч.
Напоминаю программой патчуется только WinCC, с проектом никаких манипуляций не производится.
Support C-script WinCC v4.2, 5, 6, 7
Support VB-Script WinCC v6, 7
https://mega.co.nz/#!GMUXSSKD!5pO7o_OAQ ... qmJp2ZPeDc
aguere
Post by aguere » Tue Aug 17, 2010 6:56 pm
Hi, I try it,s, but I not open protect script, always ask me the password. I try with wincc 7 sp1. I think it´s possible that the file have into folder,etc...Can anyone help me.
Thank you very much
ppp
Post by ppp » Wed Aug 18, 2010 4:35 am
You use C-script or VB-script?
Please give me your script in personal messages.
I try help.
ppp
Post by ppp » Thu Aug 26, 2010 2:36 pm
I check program.
Support only Windows 2000, WindowsXP.
NOT SUPPORT Windows 7
Link
Post by Link » Wed Sep 15, 2010 12:14 pm
New version. Add support Windows7.
need MS Framework >=2.0
WinccNoProtect1.2.exe
[dead]
aguere
Post by aguere » Sat Sep 18, 2010 7:26 pm
Thank you very much, now run ok.
I try in my project, and magic open script. thank again..........
aguere
Post by sania » Wed Dec 12, 2012 5:42 am
check Universal UnProtector for Step7 and WinCC
viewtopic.php?f=1&t=17844&p=57434#p57434
PPP wrote:add password WinCC VB-script
ignat116
Post by ignat116 » Tue Dec 23, 2014 2:03 pm
Оживите ссылки пожалуйста (sos)
oleksandr_ua
Post by oleksandr_ua » Thu Jan 08, 2015 8:07 am
all the links are not working...
give a working link
(not_allow) (close)
xflash
Post by xflash » Mon Jun 22, 2015 12:42 pm
pss cannot make it in all time. Any updates ?
Great thanks~
ppp
Post by ppp » Tue Jun 23, 2015 8:03 am
