[?]: unDemo IBH SOFTPLC SOFTWARE
Pokajy
Post by Pokajy » Fri Sep 03, 2010 10:24 am
HI
I hope everyone is ok.
I used Ibh softplc software.
http://www.ibhsoftec-sps.de/english/PLC_S7.htm
It was good But it was demo version. Someone have cracked version? can u share?
I did not try but can we use Winac or Winlc for same work?
I want to make s7 programming without plc hardwares. I'll test my scada programs etc.
Pokajy
Re: [?]: unDemo IBH SOFTPLC SOFTWARE
Post by Pokajy » Mon Sep 13, 2010 6:30 pm
can I install rtx and make wincc project with that?
Post by sania » Mon Sep 13, 2010 6:34 pm
yes , but for s7-plc & wincc you can use plcsim too
Link
Post by Link » Sun Oct 10, 2010 7:21 pm
Pokajy
Post by Pokajy » Fri Oct 15, 2010 3:24 am
(clap) (clap) (clap) (clap) (clap) (clap)
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
(tyou) (tyou) (tyou) (tyou) (tyou) (tyou)
Thanks alot Link.
Link have you any idea about where we can find cracked SoftPLC S5-943 / S5-945 ?
suiram
Post by suiram » Fri Dec 24, 2010 12:14 pm
Do you also have the IBH OPC Server? (thnx)
Nedjeljko
Post by Nedjeljko » Wed Jan 19, 2011 11:39 am
Is it possible to connect I/O cards to the SoftPLC and how configure HW to the SoftPLC?
Thanks for link - Link (dlink)
(tyou)
Pokajy
Post by Pokajy » Thu Jan 20, 2011 2:28 pm
Zdravo
yeah it's possible. if u use profibus card like cp5611 u can communicate ur soft plc with real plcs with profibus. or u can use ethernet too. :haha:
There are also PCI cards for pc which can read 4-20mA or 0-10V analog values and u can use this informations in ur soft plc
( pci cards usually needs converters)
Nedjeljko
Post by Nedjeljko » Thu Jan 20, 2011 2:40 pm
...thats greath...I can connect ET200M to the CP5512 (have this one in my notebook) and put some cards to the ET200M. (oo) (suc)
Nedjeljko
Post by Nedjeljko » Fri Jan 21, 2011 12:21 pm
Hi Pokajy,
After instalation of softPLC, in Step7 stePG/PC interface I dont have profibus comunication for IGH, there is only MPI.
How to configure for example comunication between PC(softPLC) and Et200M with I/O cards (digital Inputs, Outputs...)?
Pokajy
Post by Pokajy » Tue Jan 25, 2011 10:13 pm
Nedjeljko u just need to install driver.
add/remove driver , CIF profibus configuration with PU
u can find guide in manual.
http://ibhsoftec-sps.com/downloads/engl ... Manual.pdf
But I learnt that as a Profibus hardware ibhsoftplc does not support siemens cp5611 pci card but it supports Hilscher or Beckhoff cards.
If u have cp5611 or similar card u can use winlc rtx.
I've a project with winlc rtx with cp5611 card, I made communication with real plc with using dp/dp coupler via profibus.
as u know ET200M is working with profibus but there is a newer product "IM 153-4 PN" softplc may work with profinet. I'm not sure. We must spend some time on it.
I'm generally using ibhsoftplc for function block tests (boom)
TaaviM8
Post by TaaviM8 » Wed Aug 03, 2011 9:50 pm
has anyone tested this also with Braumat/Sistar?
recipeserver is working with this?
Regards,
Taavi
chelina63
Post by chelina63 » Sat Sep 13, 2014 3:47 am
Dear Link,
can you upload :
"IBH Soft PLC / SPS V.4.04
S7-300 and S7-400
with Key"
because download links not working,
igormf
Post by igormf » Tue Aug 08, 2017 8:03 pm
Anybody has this link and is able to share?
Anybody have the serial number? Thanks!
