[Request] Switch to Vijeo Designer "S2VD"
If anyone have Switch to Vijeo designer i.e S2VD Please Upload it.
S2VD is Switch To Vijeo Designer
S2VD is Schneider Utility which is used for internal / system integrator application.
This utility / software convert XBTL1000 file (i.e. for XBTF Series) to Vijeo Designer file (i.e. XBTGT Series Application).
The main purpose of this utility is to convert software enviorment. (i.e. XBTL1000 to vijeo Designer)
This utility is free of cost, but not available for downloading. One have to get a training in order to get this utility.
If anyone have utility, please upload it.
Links regarding S2VD are listed below
http://www.schneiderelectric.bg/forum/v ... b592603c51
http://www.schneider-electric.cz/downlo ... _ASRTP.pdf (Page No. 21)[/img]
Re: [Request] Switch to Vijeo Designer "S2VD"
Thanks Schtiel & Dustin
hi, you can upload tje aplication again please? the links dont works
Rapidshare link is work!
Can You upload a new link? Because the link does not exist. And I have to convert an application from the XBT-F on XBT-GT. And i need the S2VD.
Can You upload a new link? Because the link does not exist. And I have to convert an application from the XBl-1000 on XBT-GT. And i need the S2VD.
never tested this program
Hey guys,
Thanks for the uploads.
I installed Vijeo Designer 5.0, then SP1 and XBTL-1000 4.51
I downloaded Switch_to_VJD.rar and from here I installed the "Switch from XBTL1000 2 Vijeo.exe" and after some failed attempts to convert a project, I also installed MBX Driver Suite, from the same archive.
With every attempt I make to Import a dop file in Vijeo Designer, I get the same error message "XBTL1000 has stopped before end of information extraction.
Can you help me with this? Thank you in advance!
Hi gycu,
Are you sure the DOP file is done with XBT-L1000 and not Vijeo Designer Lite ?
What model of HMI is it for ? S2VD is made for XBT-F conversion...
Could you send your DOP file ?
This S2VD is quite old and doesn't always work.
(MBX Driver Suite is not needed for conversion.)
Thanks for your reply and sorry for the late reply, I was out of town for some time.
I'm pretty sure the software is made with XBTL-1000, as it is very old and as I can open it with XBT-L1000.
The HMI is an XBTE016110, are you sure only XBTF's can be converted?
I sent you on pm the .dop
Thank you.
Cheers
Thank you.
Cheers
Hi everyone
Could I ask for re-upload Switch2Vijeo / Swich to Vijeo software ?
Cheers
Cheers
Reupload possible ?
