Post
by Update » Thu Nov 20, 2008 4:28 pm
– OP 73
– OP 73micro
– OP 77A
– TP 177A
– TP 177micro
– Basic Panels
WinCC flexible 2008.
● Errors during compilation
● Problems with DEMO mode
● Error installing MSDE
● Canceling "Save as version"
● Internal error
– Mobile Panel 277
– MP 277
– Mobile Panel 177 DP
– Mobile Panel 177 PN
– Mobile Panel 277
– OP 177B
– TP 277
– OP 277
– MP 177
– TP170A
– TP170micro
All CE devices are affected
Note
● Error converting project.
may fail.
