Request: Eurotherm/Parker DSD
Does anyone have link to Eurotherm/Parker DSD - (Drives System Designer Software)
I have a Eurotherm Link system that will not transfer the drive setup to a new 690 drive.
I need to tell the Link system to update the configration in the drive.
Re: Request: Eurotherm/Parker DSD
Hi.
You can download DSD Lite from http://www.ssddrives.com/usa/doc/Main%20Software.php
You must be a user registered. Don´t worry is free.
Best Regards
Best Regards
Re: [LINK]: Eurotherm/Parker DSD
Thanks Julio,
The free download is DSE, I use this for drive configuration but it does not allow access to the SSD Link communication module
Here is a link for you:
Link_is_Dead :(/DSD.Link_is_Dead :(
This file is neither allocated to a Premium Account, or a Collector's Account, and can therefore only be downloaded 10 times.
This limit is reached.
The link is no longer active...
Please if someone still have the file, urgently need...
Anyone....
Anyone....
Can anybody help to find "Eurotherm/Parker DSD".
I have to backup 620Link settings, but I havn't needed software...
Please, help.
Please, help.
Who has "Eurotherm/Parker DSD". Please!!!!!!!!!!!
Hi!
What's the problem?
Download the configuration program 690 drive?
Use the program ConfigEd Lite 6.10
link to the website where you download given above.
What's the problem?
Привет!
В чём проблема?
Загрузить программу конфигурирования в 690 драйв?
Для этого используйте программу ConfigEd Lite 6.10
ссылку на сайт где скачать вам давали выше.
ConfigEd Lite 6.10 не поддерживает те функциональные блоки в 620-ых приводах, которые мне нужны. В частости "Diameter Calculator". Поэтому ищу DSD. Хотя я так понял, "кто не успел, тот опоздал"
HELLO
igor-drive if you find parker DSD software please share.
Hi , I wonder if anyone has this parker DSD software.
necessarily need to set five 620L and it is impossible to access the links.
I tried with all lite versions but it is impossible. please help me
and then,i have a problem with an message error "self test halted by co-pro"
I have 5 inverters with the same crash. Because of defective switching power supply and due to the fact that they remained too long in this state ,i believe that something is happened. Now the switching power supplies are ok .. I was able to change the defective capacitors and everything is fine but the link project is lost .. I think
please ... please .. someone needs to know
Anybody with DSD?
