[?]: How to upload file from 2711-B5A8 PV550 Key/Touch?
d4ni_R
Post by d4ni_R » Fri Jun 12, 2009 11:06 am
Hi all,
I have a problem uploading/downloading file from/to 2711-B5A8 PV550 Key/Touch.
I use a down loader cable DB9 Female to female port with connection;
2 ---- 3
3 ---- 2
5 ---- 5
7 ---- 8
8 ---- 7
Is that connection correct?
Does anyone know the correct one?
Please, i really need it asap.
Thank you. :? :(
dehell
electrical connexion
Post by dehell » Sat Jun 13, 2009 12:43 pm
Look at this link:
http://plcforum.uz.ua//PB32.JPG.html
Be careful, your RS linx driver must setup : "startup=manual"
d4ni_R
Post by d4ni_R » Mon Jun 15, 2009 8:03 am
Thanks dehell,
I got message;
http://img190.spamm.us/img190/948/upload1y.jpg
http://img19.spamm.us/img19/3549/upload2n.jpg
Could you suggest me what to do? How to disable printer port?
Ryzhij
Post by Ryzhij » Mon Jun 15, 2009 12:32 pm
Then your PC and Panel are connected via cabel, you can try:
1. Open the RSLinx and sure that the DF1 driver is runing. If it not, to install and start it.
2. In the DF1 driver properties you must to select the device, com-port # and then to press "auto setting" button. Wait for link establish.
After this you can start (or switch to) the PanelBuilder software and to upload/download aplication from/to the PV
