[?+]: C200-CPM1- CQM1-CQM1H password recovery
Hi, I test a metod for find password from CQM1H-CPU21(51-61) and share with all.
it's very easy: you must install (Plc Backup Tools V6.0) then select UM option and upload from PLC, after this,
you open UM file with any HEX Editor program.
Now you can see password in 0590h memory address.
this metod tested for C200-CPM1- CQM1-CQM1H.
Re: C200-CPM1- CQM1-CQM1H password recovery
Hi Aliam,aliam wrote:Hi, I'm iranian and sory for bad english but, I test a metod for find password from CQM1H-CPU21(51-61) and share with all.
it's very easy: you must install (Plc Backup Tools V6.0) then select UM option and upload from PLC, after this, you open UM file with any HEX Editor program. Now you can see password in 0590h memory address. this metod tested for C200-CPM1- CQM1-CQM1H.
If You Try To Release The Password More Then 5 Times With The Worng Password from CQM1H-CPU51/61.
You Won't Be Able To Release The Password Any More
Even If You Know The Right Password
Jamie Quach
Re: [?]: C200-CPM1- CQM1-CQM1H password recovery
Hi Viglac
http://mega.1280.com/file/TZVPLO29/
And Hex_Editor
http://mega.1280.com/file/O36GM9PA/
You can see password in 0590h memory address from CQM1H-CPU51/61 , but can not upload program.
Jamie Quach
And Hex_Editor
Jamie Quach
Re: [?+]: C200-CPM1- CQM1-CQM1H password recovery
Thank You very much , you showed me way to recover password CQM1H-51/61 PLC.
Hello, I need "Plc Backup Tools" for CJ1M CPU11.
The PLC have no CF.
The PLC have no CF.
dear everybodyaliam wrote:Hi, I test a metod for find password from CQM1H-CPU21(51-61) and share with all.
please you help me
I when unlock pass plc onrom CPM1A by software XTAL
but I unlock password plc omron CPM1A being errors, i have sent image attach.
there are some steps that , I have made/ done below;
the first time I connect cable RS232 go to PC with plc, after I opening software CX one 9.0
I'm online with plc but plc, has lock password so I can't upload
after I opening software unlock password plc onrom CPM1A by software Xtal but I when unlock password this time software Xtal being errors
i don't know, what is this errors ?
how can I modify error '8005' ?
what is this error run-time error '8005': ?
https://goo.gl/ujs9my
Hello I try to make the video for make the password for PLC C200H
Hope can be helpfull for any one
http://www.youtube.com/watch?v=vhA0fvaXFaY
dear everybody
i have a question for your, please help me
i have a plc omron types: CPM1A it's having plc program protection.
without I releasing the password in the programming tool, but i have only see, into program plc of me it's has many command ------------------------------- [ NOP (00 ) ]
there are many program ladder diagram ------[ NOP (00) ]
but into a plc program. it's having many command ------------------------------- [ NOP (00 ) ]
without releasing the password in the programming, but program of me it's get the partial program back and many 'nop'
even me know password, but I haven't releasing the passord protection,
please you help me checking again
how is releasing the password protection
when I online and upload into plc program , --> go to I'm upload completed
this time, I'm see plc rogram of me, it's has many command -----[ NOP (00) ] , now I don't know , releasing the password protection how .
can you showed me. step by steps releasing the password protection in plc program the how.
this is blow here, I'm doing and upload plc program it's has password protection.
=> go to online with plc and upload, without I releasing passwor and using the passwor protection.
plc => transfer => upload plc program completed
-----------[ p_1s ]---------------------------------------------------------------------------------------------------------------------------------( 10.00 )
-----------[ 00.00 ]---------------------------------------------------------------------------------------------------------------------------------( 10.01 )
-----------[ 10.00 ]---------------------------------------------------------------------------------------------------------------------------------( 10.05 )
-------------------------------------------------------------------------------------------------------------------------------------------- [ NOP (00 ) ] no operation
---------------------------------------------------------------------------------------------------------------------------------------------[ NOP (00 ) ] no operation
can you showed me step by steps unlock password or releasing the passord protection
how is unlock password plc CPM1A ?
how is releasing the passord protection ?
Thank previous
Thank previous
Links are not working![Sad :(](./images/smilies/icon_sad.gif)
Can you plz upload PLC backup tool again??
