[?]: License DEMO in WinCC 4.02 but they are in AUTHORSW
Hi dears,
I'm having a problem with WinCC 4..
The Windows 98 of the WinCC machine had a problem and I move the license from the hard disk with problem to another by Automation License Manager in other machine with windows XP.
I recovered the old windows 98 system and tried to put the license again by Automation License Manager in other machine with windows XP(hard disk as slave).
So, when I tried to execute the WinCC again it appeared as DEMO.
But the 2 licenses are there, I can see using the AUTHORSW.
I have already tried to generate another license by Simatic_EKB_Install_2007_08_23 but the license DEMO still there.
I have already tried generate a yellow disk, but when I try to transfer from A: to C: by Authorsw it appear a error message saying that my license is faulty.
I don't know what to do..
Some print screens:
What must I do? Please, help me!
Thank you very much!
Some print screens:
You use only 2 keys for WinCC ?
Need info from Autoinformation.inf
Try old Siemens.exe with required keys from Simatic_Short_keys_EKB_2006_11_14
Sim_EKB_Install Folder https://mega.nz/#F!DsNy1DqR!p751JvORlgTeWsGSiTuWLQ
and see topic About WinCC keys viewtopic.php?f=4&t=11415
Please help me,
i have the same problem with wincc 4.02 ,
i send you the Autoinformation.inf here with rapidshare,
Authorinformation.rar
i was very happy if you help me.
Licence installed really needed to install Product
A9WRC330 no YES YES WinCC Runtime+Configuration 1024 Tags
A9WC2440 YES no no Channel PROFIBUS DP
A9WSPA40 YES no no ProAgent WinCC
A1WPC312 no no no Storage
A1WPC412 no no no Chipcard
A1WPC512 no no no Video
Try to install one tags WRC key A9WRC430Takis_s wrote: Please help me,
best regards from germany.
and others from this list
A9PR* and A9WRT* is not required
It worked!
I tried the old Siemens.exe with required keys and it worked!!
Thank you very very much !!
Please help,,,
now my Autoinformation.inf is :
A9WRC330 YES YES no WinCC Runtime+Configuration 1024 Tags
A1WPC312 YES no no Storage
A1WPC412 YES no no Chipcard
A1WPC512 YES no no Video
A9WARC12 YES no no User Archives
A9WC1912 YES no no Channel SIMATIC TI Ethernet Layer 4
A9WC2540 YES no no Channel SIMATIC 505 TCPIP
A9WRC130 YES no no WinCC Runtime+Configuration 128 Tags
A9WRC230 YES no no WinCC Runtime+Configuration 256 Tags
A9WRC430 YES no no WinCC Runtime+Configuration 64K Tags
A9WRT130 YES no no WinCC Runtime 128 Tags
A9WRT230 YES no no WinCC Runtime 256 Tags
A9WRT330 YES no no WinCC Runtime 1024 Tags
A9WRT430 YES no no WinCC Runtime 64K Tags
A9WSEC30 YES no no Server
A9WSRD40 YES no no Redundancy
A1WPC112 YES no no Basic Process Ctrl (ex.: Split Screen Wizard, Picture Tree Manager)
A1WPC230 YES no no Advanced Process Ctrl
A3WCL112 no no no Channel SIPART
A7TMCS30 no no no Channel TELEPERM M,0, CS275
A7TML230 no no no Channel TELEPERM M,0, PROFIBUS
A9PRC130 no no no Upgrade WinCC Runtime+Configuration 128-256 Powerpack
A9PRC230 no no no Upgrade WinCC Runtime+Configuration 128-1024 Powerpack
A9PRC330 no no no Upgrade WinCC Runtime+Configuration 128-64K Powerpack
A9PRC430 no no no Upgrade WinCC Runtime+Configuration 256-1024 Powerpack
A9PRC530 no no no Upgrade WinCC Runtime+Configuration 256-64K Powerpack
A9PRC630 no no no Upgrade WinCC Runtime+Configuration 1024-64K Powerpack
A9PRT130 no no no Upgrade WinCC Runtime 128-256 Powerpack
A9PRT230 no no no Upgrade WinCC Runtime 128-1024 Powerpack
A9PRT330 no no no Upgrade WinCC Runtime 128-64K Powerpack
A9PRT430 no no no Upgrade WinCC Runtime 256-1024 Powerpack
A9PRT530 no no no Upgrade WinCC Runtime 256-64K Powerpack
A9PRT630 no no no Upgrade WinCC Runtime 1024-64K Powerpack
A9WCL512 no no no Channel Allen Bradley Serial DF1
A9WCL612 no no no Channel PROFIBUS FMS
A9WCL730 no no no Channel SIMATIC S7-PMC
A9WCL812 no no no Channel Modbus Serial
A9WCL912 no no no Channel SIMATIC S5-PMCL2
A9WC1012 no no no Channel SIMATIC S5-PMCH1
A9WC1112 no no no Channel Applicom Multi Protocol Interface
A9WC1212 no no no Channel GE Fanuc SNP SNPX
A9WC1312 no no no Channel GE Fanuc Ethernet
A9WC1412 no no no Channel Allen Bradley DH DH+ DH485
A9WC1512 no no no Channel Modbus Network Protocol Suite
A9WC1712 no no no Channel SIMATIC S5 Ethernet TF
A9WC1812 no no no Channel SIMATIC S5 Ethernet Layer 4
A9WC2030 no no no Channel Mitsubishi FX
A9WC2130 no no no Channel Mitsubishi MELSEC A
A9WC2230 no no no Channel SIMADYN D PMC Ethernet Layer 4
A9WC2340 no no no Channel Omron C-Series HostLink
A9WOIC40 no no no Internet Connection
delete it
open folder AX NF ZZ & delete.how find it?
see viewtopic.php?t=218
thank you sania,sania wrote:open folder AX NF ZZ & delete.how find it?
i have delete it ,
but in the Autoinformation.inf it appear again the keys .
give it a solution for that ?
best regards, Takis
Re: [?]: License DEMO in WinCC 4.02 but they are in AUTHORSW
Sorry I have the same problem, and the links of this forum are down
Can they help me?
Thanks!
Can they help me?
Thanks!
Hi, i need the next licenses, but they aren't in the short Keys.
Can they help me?
SIPPA9WRT406021 Upgrade wincc Runtime 128-64k Powerpack
SIPPA9WRC406021 Upgrade wincc Runtime + Configuration 128-64k Powerpack
Can they help me?
Delete ALL ***A9WRT4***dsamosc wrote:Hi, i need the next licenses, but they aren't in the short Keys.
Can they help me?
Install only 1 key with 64k tags
See viewtopic.php?f=4&t=11415
Thanks, it Works!
