It is currently Fri Apr 20, 2018 5:51 pm
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Mon Jul 03, 2006 10:40 am
have you ever used S5/S7 Doctor from IBH Softec?
I had a demo version and I used it for S5 programmes. I think that it is great for reversed engineering. Unfortunatelly, it has only 14 days trial period and there is no way to connect to PLC online. So I am looking for S5/S7 Doctor in full version. Do yu know where can I find it?
Or maybe you know other similar programs?
Thanks in advance!
http://www.ibhsoftec-sps.de/english/first.htm
PostPosted: Tue Jul 04, 2006 2:00 am
Hello Kazzuro, am sending this link with the program, leaning that is this that you seek.
this works without code, I tested with CPU S7-314-2DP and he/she works in online.
happiness.
http://rapidshare.com/files/41511808/S7_Doctor_v2.23_with_crack.rar
include Ibh_Softec_s5W_v5-06_Full_Eng_.rar with crack
 Post subject: S7-Doctor v1.10 Full
PostPosted: Tue Aug 01, 2006 8:18 am
http://rapidshare.com/files/141090350/S ... nglish.exe
http://narod.ru/disk/2303642000/S7-Doct ... h.exe.html
http://rapidshare.com/files/141090640/S ... ussian.exe
http://narod.ru/disk/2303650000/S7-Doct ... n.exe.html
http://rapidshare.com/files/141090817/S ... _v2.23.rar
http://narod.ru/disk/2303684000/S7_Doct ... 3.rar.html
 Post subject:
PostPosted: Thu Nov 23, 2006 11:03 pm
I installed S5/S7 Doctor v2.23 that was downloaded your link.
Afterthat I made everything in the readme file. But, program is still in demo mode.
Because I use the help->info about S5/S7 doctor toolbar, then It gives the demo information.
Is it in demo mode or not?
 Post subject:
PostPosted: Thu Nov 23, 2006 11:46 pm
from README
Only english version is cracked!
During installation choose english language.
Install "S7-Doctor" as "DEMO".
After installation copy "Run S7-Doctor.exe" to program folder.
For using S7-Doctor without any limitations start "Run S7-Doctor.exe".
I try. Only diference - no registration window when Start.
Единственное отличие - нет окна регистрации при запуске.
But / Ho
Инсталлируйте "S7-Doctor" как "ДЕМО". После инсталляции скопируйте файл "Run S7-Doctor.exe" в каталог установки. Для использования S7-Doctor без всяких ограничений запускайте "Run S7-Doctor.exe".
Крякнута только английская версия! При инсталляции выберите английский язык.
 Post subject:
PostPosted: Fri Nov 24, 2006 1:17 am
IT WORKS!!!!!! :D :D :D
Henk
 Post subject:
PostPosted: Mon Nov 27, 2006 8:34 pm
CoMod,
I apoligize from you. You are right. It works on my other pc. But, this pc still has problem. Of course this is my problem. Thanks...
 Post subject:
PostPosted: Thu Nov 08, 2007 4:01 pm
I need help!!!!!
S5 S7 Docrot under runing generated ERROR:
<Instruction at adress 0x00404a79 call to memory at adres 0x00000018
Memory cannot written>
OS - Widows XP SP2 with Microsoft. NET Framework 1.1
:?: :?: What is problem. :?: :?:
 Post subject:
PostPosted: Fri Aug 29, 2008 7:44 pm
Scowl wrote:
I cann't download these files
 Post subject: S5 S7 Docrot V2.25
PostPosted: Mon Mar 02, 2009 5:02 am
S5 S7 Docrot V2.25
English // German
[dead]
rapidshare S7_Doctor_225.zip
 Post subject:
PostPosted: Wed Mar 04, 2009 11:28 pm
Does anybody succeded to connect online with this software?
I tried and with no succes.I am using a USB-Serial adapter.
With S5/S7 for Windows I had no problem,also with PG2000.
Best regards,
Venix
PostPosted: Thu Mar 05, 2009 10:32 am
I use for connection a USB-RS232 adapter. I use this soft also with this adapter.
Check on manufacturer web site.
Check on this link : http://apple.clickandbuild.com/cnb/shop ... tle=UC232R
The manufacturer has a local distributor also in your country.
dekor
PostPosted: Sat Jan 16, 2010 2:04 pm
kazzuro wrote:
Thanks in advance!
http://www.ibhsoftec-sps.de/german/Doctor_1.htm
http://www.ibhsoftec-sps.de/english/Doctor_1.htm
Hello can u tell me how can i add a new GSD file to this S5/S7 Doctor :cry:
PostPosted: Mon Oct 27, 2014 1:07 am
Dear Link,
All rapidshare link are dead. and i can't download from narod.ru, because i don't know download procedure from this site. Please tell me how can i do this? or another link.
Thanks in Advance
PostPosted: Fri Mar 03, 2017 5:40 pm
links not work please update
PostPosted: Sun Apr 16, 2017 12:23 pm
If someone can serve here is the active link (suc)
http://www.easybytez.com/uofkmru5y1tq
PostPosted: Tue Jan 09, 2018 8:36 pm
download link is corrupt, please upload file again. thanks
PostPosted: Wed Mar 14, 2018 12:59 pm
Can someoen reupload somwhere this tool?
Thank you in advance.
PostPosted: Thu Apr 05, 2018 4:34 pm
Please update the download link. Thank you!
