[?]: License DEMO in WinCC 4.02 but they are in AUTHORSW
nicknamebr
Post by nicknamebr » Sat Feb 28, 2009 9:01 pm
Hi dears,
I'm having a problem with WinCC 4..
The Windows 98 of the WinCC machine had a problem and I move the license from the hard disk with problem to another by Automation License Manager in other machine with windows XP.
I recovered the old windows 98 system and tried to put the license again by Automation License Manager in other machine with windows XP(hard disk as slave).
So, when I tried to execute the WinCC again it appeared as DEMO.
But the 2 licenses are there, I can see using the AUTHORSW.
I have already tried to generate another license by Simatic_EKB_Install_2007_08_23 but the license DEMO still there.
I have already tried generate a yellow disk, but when I try to transfer from A: to C: by Authorsw it appear a error message saying that my license is faulty.
I don't know what to do..
Some print screens:
What must I do? Please, help me!
Thank you very much!
Post by CoMod » Sat Feb 28, 2009 9:27 pm
You use only 2 keys for WinCC ?
Need info from Autoinformation.inf
Try old Siemens.exe with required keys from Simatic_Short_keys_EKB_2006_11_14
Sim_EKB_Install Folder https://mega.nz/#F!DsNy1DqR!p751JvORlgTeWsGSiTuWLQ
and see topic About WinCC keys viewtopic.php?f=4&t=11415
Takis_s
Post by Takis_s » Sun Mar 08, 2009 1:25 pm
:oops: Please help me,
i have the same problem with wincc 4.02 ,
i send you the Autoinformation.inf here with rapidshare,
Authorinformation.rar
i was very happy if you help me.
Licence  	installed	really needed	to install	Product
A9WRC330	no        	YES        	YES        	WinCC Runtime+Configuration 1024 Tags
A9WC2440	YES        	no        	no        	Channel PROFIBUS DP
A9WSPA40	YES        	no        	no        	ProAgent WinCC
A1WPC312	no        	no        	no        	Storage
A1WPC412	no        	no        	no        	Chipcard
A1WPC512	no        	no        	no        	Video
Post by CoMod » Sun Mar 08, 2009 2:39 pm
Takis_s wrote::oops: Please help me,
best regards from germany.
Try to install one tags WRC key A9WRC430
and others from this list
A9PR* and A9WRT* is not required
nicknamebr
It worked!
Post by nicknamebr » Sun Mar 08, 2009 3:30 pm
I tried the old Siemens.exe with required keys and it worked!!
Thank you very very much !!
Takis_s
Post by Takis_s » Sun Mar 08, 2009 6:50 pm
CoMod wrote:Try old Siemens.exe with required keys
CoMod,, :oops: where is this old siemens.exe ?
sorry for the question but i am a beginner.
best regards , Takis.
Post by CoMod » Sun Mar 08, 2009 6:57 pm
Takis_s wrote:CoMod,, :oops: where is this old siemens.exe ?
Inside links ?
Takis_s
Post by Takis_s » Sun Mar 08, 2009 7:17 pm
CoMod wrote: Inside links ?
:wink: :lol: :D Thank you my friend ,,,,
i will trie it in 5 days when i come back from a travel,
i will write here what happen with wincc,
thanks again.
Takis_s
Post by Takis_s » Sat Mar 14, 2009 12:50 am
Please help,,,
now my Autoinformation.inf is :
A9WRC330	YES        	YES        	no        	WinCC Runtime+Configuration 1024 Tags
A1WPC312	YES        	no        	no        	Storage
A1WPC412	YES        	no        	no        	Chipcard
A1WPC512	YES        	no        	no        	Video
A9WARC12	YES        	no        	no        	User Archives
A9WC1912	YES        	no        	no        	Channel SIMATIC TI Ethernet Layer 4
A9WC2540	YES        	no        	no        	Channel SIMATIC 505 TCPIP
A9WRC130	YES        	no        	no        	WinCC Runtime+Configuration 128 Tags
A9WRC230	YES        	no        	no        	WinCC Runtime+Configuration 256 Tags
A9WRC430	YES        	no        	no        	WinCC Runtime+Configuration 64K Tags
A9WRT130	YES        	no        	no        	WinCC Runtime 128 Tags
A9WRT230	YES        	no        	no        	WinCC Runtime 256 Tags
A9WRT330	YES        	no        	no        	WinCC Runtime 1024 Tags
A9WRT430	YES        	no        	no        	WinCC Runtime 64K Tags
A9WSEC30	YES        	no        	no        	Server
A9WSRD40	YES        	no        	no        	Redundancy
A1WPC112	YES        	no        	no        	Basic Process Ctrl (ex.: Split Screen Wizard, Picture Tree Manager)
A1WPC230	YES        	no        	no        	Advanced Process Ctrl
A3WCL112	no        	no        	no        	Channel SIPART
A7TMCS30	no        	no        	no        	Channel TELEPERM M,0, CS275
A7TML230	no        	no        	no        	Channel TELEPERM M,0, PROFIBUS
A9PRC130	no        	no        	no        	Upgrade WinCC Runtime+Configuration 128-256 Powerpack
A9PRC230	no        	no        	no        	Upgrade WinCC Runtime+Configuration 128-1024 Powerpack
A9PRC330	no        	no        	no        	Upgrade WinCC Runtime+Configuration 128-64K Powerpack
A9PRC430	no        	no        	no        	Upgrade WinCC Runtime+Configuration 256-1024 Powerpack
A9PRC530	no        	no        	no        	Upgrade WinCC Runtime+Configuration 256-64K Powerpack
A9PRC630	no        	no        	no        	Upgrade WinCC Runtime+Configuration 1024-64K Powerpack
A9PRT130	no        	no        	no        	Upgrade WinCC Runtime 128-256 Powerpack
A9PRT230	no        	no        	no        	Upgrade WinCC Runtime 128-1024 Powerpack
A9PRT330	no        	no        	no        	Upgrade WinCC Runtime 128-64K Powerpack
A9PRT430	no        	no        	no        	Upgrade WinCC Runtime 256-1024 Powerpack
A9PRT530	no        	no        	no        	Upgrade WinCC Runtime 256-64K Powerpack
A9PRT630	no        	no        	no        	Upgrade WinCC Runtime 1024-64K Powerpack
A9WCL512	no        	no        	no        	Channel Allen Bradley Serial DF1
A9WCL612	no        	no        	no        	Channel PROFIBUS FMS
A9WCL730	no        	no        	no        	Channel SIMATIC S7-PMC
A9WCL812	no        	no        	no        	Channel Modbus Serial
A9WCL912	no        	no        	no        	Channel SIMATIC S5-PMCL2
A9WC1012	no        	no        	no        	Channel SIMATIC S5-PMCH1
A9WC1112	no        	no        	no        	Channel Applicom Multi Protocol Interface
A9WC1212	no        	no        	no        	Channel GE Fanuc SNP SNPX
A9WC1312	no        	no        	no        	Channel GE Fanuc Ethernet
A9WC1412	no        	no        	no        	Channel Allen Bradley DH DH+ DH485
A9WC1512	no        	no        	no        	Channel Modbus Network Protocol Suite
A9WC1712	no        	no        	no        	Channel SIMATIC S5 Ethernet TF
A9WC1812	no        	no        	no        	Channel SIMATIC S5 Ethernet Layer 4
A9WC2030	no        	no        	no        	Channel Mitsubishi FX
A9WC2130	no        	no        	no        	Channel Mitsubishi MELSEC A
A9WC2230	no        	no        	no        	Channel SIMADYN D PMC Ethernet Layer 4
A9WC2340	no        	no        	no        	Channel Omron C-Series HostLink
A9WOIC40	no        	no        	no        	Internet Connection
Post by sania » Sat Mar 14, 2009 7:54 am
delete it
Takis_s
Post by Takis_s » Sat Mar 14, 2009 11:42 pm
hello sania + CoMod, the codes that you have write me,
can you tell me how to delete the codes ?
:lol: :D
The DEMO is going away,now it appear :
:arrow: External Tags: 373 / License: 64K
is it ok :?:
Post by CoMod » Sun Mar 15, 2009 8:55 am
Takis_s wrote: External Tags: 373 / License: 64K
is it ok :?:
You already have no demo mode - is it ok :?:
or you need Demo :lol:
Takis_s
Post by Takis_s » Sun Mar 15, 2009 3:48 pm
Thanksssssss CoMod :D ,
my friend i am very happy for this solution with the winncc 4.02,
again thankssssss for the solution to all admins .
Please (for future solution) can you write me how i can delete if i will some codes ?
Thanks thanks thanks my friends
Post by sania » Sun Mar 15, 2009 4:30 pm
open folder AX NF ZZ & delete.how find it?
see viewtopic.php?t=218
Takis_s
Post by Takis_s » Sun Mar 15, 2009 4:39 pm
sania wrote:open folder AX NF ZZ & delete.how find it?
thank you sania,
i have delete it ,
but in the Autoinformation.inf it appear again the keys .
give it a solution for that ?
best regards, Takis
Takis_s
Post by Takis_s » Sun Mar 15, 2009 9:03 pm
After 1 day :oops: it present this :
what should i do now ??
I thank in advance
Post by sania » Sun Mar 15, 2009 9:32 pm
you need license of simatic_net dp
find it in folder simatic_net with simatic.exe
Takis_s
Post by Takis_s » Sun Mar 15, 2009 11:09 pm
sania wrote:you need license of simatic_net dp
hello sania,
forgive me :oops: but i can't find this file :cry: ,
i don't have any simatic_net folder, i have WinCC 4.02 ,
can you tell me where it is ?
thankssssss
Post by CoMod » Mon Mar 16, 2009 5:17 am
EKB_Install
Read, Search, Read, and again Search
learn, learn, learn
as we were taught in school
Takis_s
Post by Takis_s » Mon Mar 16, 2009 5:34 am
CoMod wrote:EKB_Install
learn, learn, learn
CoMod i read , search and again i read and search as in school,
but it isn't easy to learn , but i learn
thank you again
dsamosc
Re: [?]: License DEMO in WinCC 4.02 but they are in AUTHORSW
Post by dsamosc » Thu Nov 17, 2016 10:52 pm
Sorry I have the same problem, and the links of this forum are down
Can they help me?
Thanks!
Post by CoMod » Fri Nov 18, 2016 6:12 am
dsamosc
Post by dsamosc » Wed Nov 23, 2016 3:13 pm
Hi, i need the next licenses, but they aren't in the short Keys.
Can they help me?
SIPPA9WRT406021 Upgrade wincc Runtime 128-64k Powerpack
SIPPA9WRC406021 Upgrade wincc Runtime + Configuration 128-64k Powerpack
Post by CoMod » Wed Nov 23, 2016 7:54 pm
dsamosc wrote:Hi, i need the next licenses, but they aren't in the short Keys.
Can they help me?
Delete ALL ***A9WRT4***
Install only 1 key with 64k tags
See viewtopic.php?f=4&t=11415
Not use Short keys for new program - delete it.
Select Recommended
and Press "Install LONG KEY" button
dsamosc
Post by dsamosc » Thu Nov 24, 2016 8:45 am
Thanks, it Works!
