[?]: version for S7-200 crack password
Hello everybody!
I found new program for S7-200 crack password in china website but I don't know how to use it. Anyone help me!
Link:
http://www.tf168.cn/p/l/plc/atfile/S7-200.rar
http://www.tf168.cn/p/l/plc/atfile/s7200.rar
Link:
Read password command CPU 226 V2?
hi,
I found how PC read S7-200 V1 password:
- connect with PLC address 2
10 02 00 49 4B 16
- Read password command
68 1B 1B 68 02 00 6C 32 01 00 00 00 00 00 0E 00 00 04 01 12 0A 10 02 00 08 00 00 03 00 05 E0 D2 16 10 02 00 5C 5E 16
- PLC answer
68 1D 1D 68 00 02 08 32 03 00 00 00 00 00 02 00 0C 00 00 04 01 FF 04 00 40 93 92 0E 0D 84 87 0E 0D FB 16
=> Password: 93 92 0E 0D 84 87 0E 0D
=> 93 92 9D 9F
=> 9 8 7 5
Anyone know "Read password command" of S7-200 CPU 226 V2?
10 02 00 49 4B 16
- PLC answer
=> 93 92 9D 9F
=> 9 8 7 5
possible this is swindle version
viewtopic.php?t=9415возможно это мошенники обувают лохов на деньги
I want to give the register program to you
I want to give the register program to you,how to upload?
The crack program cannot crack s7200 china verson. who can crack?
http://plcforum.uz.ua//s7200cr.rar
Re: [?]: New version for S7-200 crack password!
I download it ,but I try more times,it can not read the password! why ???
It is not necessary to enter 18077463, it is necessary to download
http://plcforum.uz.ua//s7200cr.rar (keygen), the inquiry about registration will be gone. But in work the program did not try
Re: Read password command CPU 226 V2?
I do not understand that the procedure used to decode password
someone could read the password using this program or another method better
Cable of S7-200 Crack
Dear All
I've downloaded the KeyGen & also registered No Problem
Now,Which cable will be connected to the CPU,is it the PC/PPI cable from Siemens or RS-232 cable?
I need to know the answer from you urgently as I face a problem in my Machine
Thanks in Advanced
Thanks in Advanced
Dear Site Admins,
I want to read application program from PLC which is protected. Althought i have examined your web pages but couldn't find any crack program which is worked. If there is worked crack password program Could you pls post the link?
Many thanks,
Many thanks,
Hi votuandktd,
let me know how PLC password is 9875 ? (98 i know):
- PLC answer
=> 93 92 9D 9F
=> 9 8 7 5
- PLC answer
=> 93 92 9D 9F
=> 9 8 7 5
Follow votuandktd, u can using to give commands by VB6 :
And viewing PLC response.
If password is 22222222 then PLC response: 68 1d 1d 68 00 02 08 32 03 00 00 00 00 00 02 00 0c 00 00 04 01 ff 04 00 40 98 98 00 00 98 98 00 00 f5 16
If password is 22222222 then PLC response: 68 1d 1d 68 00 02 08 32 03 00 00 00 00 00 02 00 0c 00 00 04 01 ff 04 00 40 93 92 0e 0e 91 90 08 08 07 16
remark:
9A hex = 0
9B hex = 1
98 hex = 2
99 hex = 3
9E hex = 4
9F hex = 5
9C hex = 6
9D hex = 7
92 hex = 8
93 hex = 9
Hi votuandktd
Can you answer my question:
if password : 9875
- PLC answer
I only understand and find password 98**
Many Thanks
remark:
9A hex = 0
9B hex = 1
98 hex = 2
99 hex = 3
9E hex = 4
9F hex = 5
9C hex = 6
9D hex = 7
92 hex = 8
93 hex = 9
Hi votuandktd
if password : 9875
- PLC answer
Many Thanks
9D = 0E XOR 93
9F = 0D XOR 92
Good luck
9F = 0D XOR 92
Good luck
Thank you very muchvotuandktd wrote:9D = 0E XOR 93
9F = 0D XOR 92
Good luck
You can use this program, you need modify it to suitable with your purpose
Private Sub Form_Load()
With MSComm1
.CommPort = 1
.Settings = "9600,e,8,1"
.InputLen = 0
.RThreshold = 1
.InputMode = comInputModeBinary
End With
If MSComm1.PortOpen = False Then
MSComm1.PortOpen = True
End If
End Sub
Private Sub Form_Unload(Cancel As Integer)
If MSComm1.PortOpen = True Then
End If
End Sub
Function ppird(readaddress As String)
Dim i As Integer, temp As Integer
Dim sendbyte(32) As Byte
sendbyte(0) = &H68
sendbyte(1) = &H1B
sendbyte(2) = &H1B
sendbyte(3) = &H68
sendbyte(4) = &H2
sendbyte(5) = &H0
sendbyte(6) = &H6C
sendbyte(7) = &H32
sendbyte(8) = &H1
sendbyte(9) = &H0
sendbyte(10) = &H0
sendbyte(11) = &H0
sendbyte(12) = &H0
sendbyte(13) = &H0
sendbyte(14) = &HE
sendbyte(15) = &H0
sendbyte(16) = &H0
sendbyte(17) = &H4
sendbyte(18) = &H1
sendbyte(19) = &H12
sendbyte(20) = &HA
sendbyte(21) = &H10
sendbyte(22) = &H4
sendbyte(23) = &H0
sendbyte(24) = &H1
sendbyte(25) = &H0
sendbyte(26) = &H1
sendbyte(27) = &H84
sendbyte(28) = &H0
sendbyte(29) = (readaddress * 8) \ 256
sendbyte(30) = (readaddress * 8) Mod 256
sendbyte(31) = &H0
sendbyte(32) = &H16
For i = 4 To 30
temp = temp + sendbyte(i)
Next
sendbyte(31) = temp Mod 256
ppird = sendbyte
End Function
Function ppiww(adressx As Integer, datax As Integer)
Dim sendbyte(38) As Byte
sendbyte(0) = &H68
sendbyte(1) = &H21
sendbyte(2) = &H21
sendbyte(3) = &H68
sendbyte(4) = &H2
sendbyte(5) = &H0
sendbyte(6) = &H6C
sendbyte(7) = &H32
sendbyte(8) = &H1
sendbyte(9) = &H0
sendbyte(10) = &H0
sendbyte(11) = &H0
sendbyte(12) = &H0
sendbyte(13) = &H0
sendbyte(14) = &HE
sendbyte(15) = &H0
sendbyte(16) = &H6
sendbyte(17) = &H5
sendbyte(18) = &H1
sendbyte(19) = &H12
sendbyte(20) = &HA
sendbyte(21) = &H10
sendbyte(22) = &H4
sendbyte(23) = &H0
sendbyte(24) = &H1
sendbyte(25) = &H0
sendbyte(26) = &H1
sendbyte(27) = &H84
sendbyte(28) = &H0
sendbyte(29) = (adressx * 8) \ 256
sendbyte(30) = (adressx * 8) Mod 256
sendbyte(31) = &H0
sendbyte(32) = &H4
sendbyte(33) = &H0
sendbyte(34) = &H10
sendbyte(35) = datax \ 256
sendbyte(36) = datax Mod 256
sendbyte(37) = &H0
sendbyte(38) = &H16
For i = 4 To 36
Next
sendbyte(37) = temp Mod 256
ppiww = sendbyte
End Function
Private Sub MSComm1_OnComm()
Dim rcvtemp(5) As Byte
Dim rcv_array() As Byte
Dim yy As Long
Select Case MSComm1.CommEvent
Case comEvReceive
rcv_array = MSComm1.Input
If rcv_array(0) = &HE5 Then
MSComm1.RThreshold = 25
rcvtemp(0) = &H10
rcvtemp(1) = &H2
rcvtemp(2) = &H0
rcvtemp(3) = &H5C
rcvtemp(4) = &H5E
rcvtemp(5) = &H16
MSComm1.Output = rcvtemp
ElseIf rcv_array(0) = &H68 And rcv_array(1) = &H17 Then
yy = Val(rcv_array(25)) * 256 + Val(rcv_array(26))
Text1 = yy
Else
MSComm1.RThreshold = 1
End If
End Select
watchtimer.Enabled = False
End Sub
Hi votuandktd,
Please help me !
I send command : (connect with PLC address 2)
then PLC S7-200 CPU224 answer :
But I send command : then PLC no response.
Can you help me to explain why PLC no response?
Sorry my knowledge about VB6 no good.
This is my program, can you help me to show wrong points ?
Hoanhnghiep
Please help me !
I send command :
10 02 00 49 4B 16
10 00 02 00 02 16
With MSComm1
.InputLen = 0
.RThreshold = 1
End With
Timer1.Enabled = False
Timer2.Enabled = False
End Sub
Private Sub Command1_Click()
MSComm1.Output = Chr(16) & Chr(2) & Chr(0) & Chr(73) & Chr(75) & Chr(22)
Timer1.Enabled = True
End Sub
Private Sub Timer1_Timer()
Text1.Text = MSComm1.Input
Call Command2_Click
End Sub
Private Sub Command2_Click()
MSComm1.Output = Chr(104) & Chr(27) & Chr(27) & Chr(104) & Chr(2) & Chr(0) & Chr(108) & Chr(50) & Chr(1) & Chr(0) & Chr(0) & Chr(0) & Chr(0) & Chr(0) & Chr(14) & Chr(0) & Chr(0) & Chr(4) & Chr(1) & Chr(18) & Chr(10) & Chr(16) & Chr(2) & Chr(0) & Chr(8) & Chr(0) & Chr(0) & Chr(3) & Chr(0) & Chr(5) & Chr(224) & Chr(210) & Chr(22) & Chr(16) & Chr(2) & Chr(0) & Chr(92) & Chr(94) & Chr(22)
Timer2.Enabled = True
End Sub
Private Sub Timer2_Timer()
End Sub
Hoanhnghiep
Hi Hoanhnghiep,
You should modify my program and use
Good luck,
"Private Sub MSComm1_OnComm()"
This password read command (68 1B 1B 68 02 00 6C 32 01 00 00 00 00 00 0E 00 00 04 01 12 0A 10 02 00 08 00 00 03 00 05 E0 D2 16 10 02 00 5C 5E 16 ) work corectly with S7 200 V1 ,but with V2 plc response (68 1D 1D 68 00 02 08 32 03 00 00 00 00 00 02 00 0C 00 00 04 01 FF 04 00 40 00 00 00 00 00 00 00 FB 16
Maybe somebody know how read password new version S7 200 plc
Re: S7 200 CRACK
I steel cannot running the reading PLCvotuandktd wrote:I can't worked. Please share program worked. many thanks
Dear, Please let me know how you have sent the command (software) and which was the cable?
Gaurav H.
Gaurav H.
Re: [?]: version for S7-200 crack password
Hi, anybody help me my plc password;CPU224XP
pls request : 68 1D 1D 68 00 02 08 32 07 00 00 00 16 00 0C 00 04 00 01 12 08 12 85 01 00 00 00 D6 02 0A 00 00 00 FE 16
thank u.
thank u.
dear sir please send updated link s7200.exe
Hello
Thanks For This Great Sharing Jamie
How about LETTER Uppercase and Lowercase Do You Have This List ?
For example :
?? hex = A
?? hex = B
?? hex = C
?? hex = D
Thanks..
For example :
?? hex = A
?? hex = B
?? hex = C
?? hex = D
Thanks..
I am looking for a program to remove the password to the project of a plc s7 200 smart, also for the HMI.
Please share file.. Link has dead..
