[?+]: Crack of IGE-XAO SEE ELECTRICAL CAD
I am in search of crack for the program SEE ELECTRICAL IGE-XAO
In company have original software with USB key version of "See Electrical Expert 2005 - R3 Service Pack 3B"
I like to find the crack in order to make tests at home,
if anyone has the link even earlier version (not too),
I would a big favour
Thanks x Any information
SEE Electrical Expert is protected by HASP, but the protection algorithm is very simple. I don't use this software anymore (Eplan is much better) but the last version i used (cracked by me) was 2005 SP4E (only one file must be replaced - C:\Program Files\See Electrical Expert 2005\see_soft\Exe\SeeStencil.dll). I don't know is it works with never versions of SEE.
I uploaded patched version of SeeStencil.dll on rapidshare:
Link_is_Dead :(/Se ... l.dll.html
It's problem with your version of SEE (2002). This patch was build for 2005 V3R3 SP4E polish version (i didn't tested this in another language version of SEE because only version i have is polish). If language isn't problem for you i can upload 2005 V3R3 SP4E polish version on rapidshare (about 350MBytes packed)
Re: See Electrical V4R1
this is the patch but only for 30 days, in the end of this time run again and the program functions well.Gene wrote:Hello guys,
does somebody have medicine for See Electrical V4R1?
This last version I've downloaded from ige-xao site.
ftp://ftp.ige-xao.dk/caddy++/
http://www.ige-xao.com/icons/ige/anglai ... l_v4r1.exe
by _Legolas
Link_is_Dead :(/s ... -patch.rar
http://narod.ru/disk/2451462000/see.ele ... h.Link_is_Dead :(
I have a trial version cd of caddy electrical v4r1.I put run the program in my desktop(win xp), and it works well, then i try to put run in my laptop(win vista),but during the install process an error apear(can make the registry of C:\windows\system\CADdyX.ocx),and the program is blocked.Does anyone can help me ?
SEE Electrical v4r1
for testing...
Download: http://www.ige-xao.com/icons/ige/anglai ... l_v4r1.exe
- install it
-make a Backup of the CAEManager.exe
-open the CAEManager.exe with a Hex-Editor and change the Offset 00089877h from 74 to 75
-check that the value in the offset is 74 before you change !!!
-save the File
-change the Software License to "Hardware Key"
- install it
-save the File
Re: [?+]: Crack of IGE-XAO SEE ELECTRICAL CAD
See Electrical 3.83 - 4R1 crack keygen.
Link_is_Dead :(/Key.Link_is_Dead :(
(click *Advanced* -for Electrical 3.83 Define custom unlock level – set 159
-for Electrical 4R1 Define custom unlock level – set 6856
thanks.
thanks.
i cant edit this offset because that hex editor cant find this number : 00089877hbsod wrote:for testing...
- install it
-save the File
ive made exactly what you said but in HEX numbers i didnt find ...
what can i do?
Thank you very much!Gogi66 wrote:Hi,
thanks.
How do you obtain the custom unlock level from the software so we can get it for future versions?
