It is currently Mon Jan 21, 2019 5:39 pm
Post new topic Reply to topic  [ 43 posts ]
PostPosted: Thu Jul 17, 2008 1:58 pm
Hi, I am looking for the program Drive window for parametrization of ABB drives. Any help :) ???
 Post subject:
PostPosted: Fri Jul 18, 2008 4:34 pm
DriveWindow v2.2
I never tested this program and I do not know if it is necessary lic
57030 KB
http://rapidshare.com/files/130639872/ABB_DriveWindow_v2.2.rar
 Post subject:
PostPosted: Wed Jul 23, 2008 9:58 pm
And what about drive window light 2
maybe this one:
http://rapidshare.com/files/131916688/DriveWindowLight.rar
never used it but the readme shows 2003 as release date...
Please, is there anybody here that knows the pinout for the DB9->RJ45 cable ???
 Post subject: Thx
PostPosted: Thu Jul 24, 2008 12:54 pm
Thank you rack123.
This is what I need it :)
 Post subject:
PostPosted: Sat Sep 20, 2008 12:45 pm
I found the cable and draw the pinout:
http://rapidshare.com/files/146811604/abb_rj_2_db9.rar
Tested on ACH550 with drivewindow 2.6, works fine!
 Post subject:
PostPosted: Thu Sep 25, 2008 8:26 pm
I don't remeber where saved the original link, so I've compressed the setup folder and reupped here:
DriveWindow 2.6
http://rapishare.com/files/148332125/DWL26.rar
http://www.megaupload.com/?d=YTISOI3D
about 20Mb (85Mb uncompressed).
No password, please remove all the "*" for the correct links ( I don't like the web spiders).
If the setup not works correctly from a hd folder try to burn a cdrom with all the files/folders that are in rar.
 Post subject: Acs800
PostPosted: Fri Dec 05, 2008 9:19 pm
Does any one have a pinout for the ABB ACS800 rj12 to DB9
PostPosted: Fri Jan 09, 2009 6:18 pm
I have tryed DWL 2.6 but a ASC800 is'nt recognized. Max ACS550 is supported.
Anyone can help me ?
 Post subject:
PostPosted: Sat Jan 10, 2009 6:52 am
Did you try with DriveWindow v2.2? From most's link. Works without lic. I use this for ASC600 and ASC800. Connection by PCMCI card (NDPA-02 DDCS/PC card adapter) + NDPC-12 card cable (10Mb optical transmitter/receiver) + FO cable.
reagrds
PostPosted: Thu Feb 05, 2009 6:30 am
DriveWindow Light 2.7
DriveWindow Light is a commissioning and maintaining tool
for ACS140, ACS160, ACS350, ACS400, ACH400, ACS550,
ACH550 DCS400 and DCS800 drives. Also following ASC600 and ACS800
applications are supported: standard, spinning control and
pump control. DriveWindow Light is designed to run under the
Microsoft Windows NT4.0 (SP6), Windows 2000, Windows XP or
Windows Vista operating systems on IBM -compatible PCs.
 Post subject:
PostPosted: Fri Jul 10, 2009 11:01 pm
Does any one have a pinout for the ABB ACS800 rj12 to DB9 ?
Is possible to configure any serial port COM to communicate with ACS800 ?
 Post subject: Re:
PostPosted: Tue Nov 10, 2009 7:16 am
the link of DWL26 on Rapidshare is broken !
Please, Re-Upload again ?
PostPosted: Thu Feb 11, 2010 10:35 am
I have ACS-CP-A control panel, but it is not working http://www.abb.com/product/us/9AAC113396.aspx
I have found in user manual that I need some OPCA-02 adapter cable for this drive.
Is this correct cable: http://rapidshare.com/files/146811604/abb_rj_2_db9.rar ?
So I downloaded Drivewindow Light. Is it possible to connect to drive over 8-pin RJ45 connector.
Does anyone have cable pinout for ACS350 drive?
PostPosted: Thu Feb 11, 2010 10:39 am
The DWL 2.92 had already released
PostPosted: Sun Feb 21, 2010 10:34 pm
Can someone uplad 2.7?
Because 2.92 is upgrade for Drivewindow light 2.7
PostPosted: Mon Mar 08, 2010 1:33 pm
I found DWL 2.8 You can download it from http://rapidshare.com/files/360563073/dwl_2.8.rar
You can use service pack to upgrade to 2.93. It's downloadable from ABB
Regards.
PostPosted: Mon Sep 13, 2010 1:01 am
hi any one can upload DriveWindow 2.30
PostPosted: Wed Oct 05, 2011 10:13 pm
I have DWL 2.92. Can I communication with ACS-800 this program. I have DB9->RJ45 cable ABB?
PostPosted: Thu Oct 06, 2011 9:35 am
You need NPCU-1 adapter and cable for RS485. Then you can. But only for reading/writing parameters of standard software and basic control (start/stop/fwd/rev), due to link speed via RS232 is too slow.
Can anyone upload DriveWindow 2.3 here?
PostPosted: Tue Dec 27, 2011 5:03 pm
Hello all
How to activate "Loading packages" in DriveWindow?
I have checked in help file info is that "special license..." need "...to be entered into DriveWindow".
Where can I find this license and how to enter it?
PostPosted: Tue Jan 08, 2013 2:14 am
DriveWindow Light 2.7 here :
http://rapidshare.com/files/2000229200/DWL2.7.RAR
PostPosted: Wed Jan 16, 2013 11:36 pm
I found how to make the RJ45 to DB9 cable. Is the comunication faster using this cable than using the RS232?
PostPosted: Thu Jan 17, 2013 12:25 pm
1. http://www.4shared.com/rar/CpRDWGM7/dri ... t_293.html
2. The same. The difference is only in connector type.
PostPosted: Thu Jan 17, 2013 7:10 pm
PostPosted: Wed Mar 06, 2013 10:08 pm
Linkinx64,
Please... Can you upload again the DriveWindow 2.2 or 2.3 on another server? Rapidshare is broken (exceed daily limit)....
Thanks a lot!
Best regards,
Edsan
PostPosted: Sun Mar 10, 2013 8:01 pm
http://www.filefactory.com/file/ooit37bpvbn/n/DriveWindow_v2.30.zip
Inform when you're done with the download - I will delete it.
PostPosted: Mon Jul 01, 2013 9:49 pm
rosco87 wrote:
Thanks for this buddy :-)
Just looking for this link...
PostPosted: Thu Aug 29, 2013 11:28 am
Mr. Linkinx64,
Could you please repost?
Paul Mall
PostPosted: Tue Sep 23, 2014 11:52 am
Someone has DriveWindow Light v2.94?
I have DWL v2.93 and such problem:
Error Message
Error occurred while uploading parameters. Check the connection and try again.
Cause
The connected drive’s application software is not supported by DWL.
Frequency converter ACS550 firmware (parameter 3301) = 313dh
Test Date (parameter 3303) = 11.27
DWL v2.93 release date 2010
On the ABB site not files for upgrade. If I right understand software for all FC released after 2010 can buy only. :(
PostPosted: Fri Nov 07, 2014 6:05 am
I alread have a fault like this before...
I'm solved after update the parameters file of the ACS350/550.
Download link:
http://library.abb.com/global/scot/scot ... 0c003a0305
(thnx)
This update for DWL 2.63 (2007-07-02). I have DWL 2.93 and my files of parameters is newer (2009-2010).
PostPosted: Fri Jan 09, 2015 3:42 pm
This update for DWL 2.63 (2007-07-02). I have DWL 2.93 and my files of parameters is newer (2009-2010).[/quote]
Yes its true,but someday this fault occur to me,and my DWL is 2.93 to...
But I try to change this library in that link,and after that its works...
"In electronics is proven that there is not an exact science.
If we do not try we will never know if it works."
Ramomkosta
PostPosted: Sat Feb 21, 2015 9:29 pm
Hi, can someone upload ABB drivewindow? Links here are dead.
Thank you.
PostPosted: Thu Feb 26, 2015 1:52 pm
viewtopic.php?f=16&t=22084
viewtopic.php?f=16&t=22070
PostPosted: Thu Nov 05, 2015 9:41 am
DriveWindow Light 2.93:
http://my-files.ru/opx7zh.DriveWindow%20Light%202.93.rar
Cable pinout:
http://my-files.ru/1vy4ce.OPCA-02.rar
Anybody have DWL 2.94?
On the ABB site available update from DWL 2.94 to 2.95:
http://search-ext.abb.com/library/Download.aspx?DocumentID=9AAK10103A2830&LanguageCode=en&DocumentPartId=&Action=Launch
PostPosted: Fri Nov 06, 2015 9:46 am
Old links (in before message) is not good.
Cable pinout:
PostPosted: Fri Nov 06, 2015 9:52 am
If somebody have DWL 2.94, give link please. (sos)
PostPosted: Thu May 19, 2016 8:59 pm
PostPosted: Fri Nov 04, 2016 11:05 am
Hi all,
i have drive windows light 2.3 and also 2.93.
Can anyone upload links to all the versions again in between
ie 2.4 2.5 2.6 2.7 2.8
and the cable pinout as all the rapidshare links etc are broken.
PostPosted: Sun Nov 20, 2016 12:56 pm
Hi All,
Any update or good link to be shared about ACS drivers software?
Regards
PostPosted: Fri Jun 01, 2018 10:52 pm
Lemajd wrote:
Hi All,
Regards
I have them working up to 2.93. I have the 2.94 to 2.95 updater but not the version 2.94
I haven't shared for a while but can provide dropbox. let me know if required
PostPosted: Wed Dec 05, 2018 6:06 pm
need dwl 2.94 pl.help
PostPosted: Sat Dec 08, 2018 11:22 pm
Create a reg file with such content and run it.
Code:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\DWL2.exe]
@="C:\\Program Files (x86)\\ABB\\DriveWindow Light\\DWL2.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\DriveWindow Light]
"DisplayVersion"="2.94"
Download and install update from DWL 2.94 to 2.95
http://search-ext.abb.com/library/Downl ... ion=Launch
Reg file for Windows 7. For Win XP, you need to edit a little. I think you figure it out.
PostPosted: Sat Dec 15, 2018 7:34 pm
After adding registry (windows 10), i am able to install dwl 2.95 through file upgrade 2.94 to 2.95.
https://search-ext.abb.com/library/Down ... ion=Launch
