[?]: Quality codes Domino A series non-impact printers
другие контроллеры
indian
Post by indian » Mon Dec 10, 2007 10:17 am
dekor wrote:this codes are "unique" for ink resevoir used in industrial printers.
Each reservoir have only 600 hours life time.
Even if the printer is just started and no job to print the life time is counting down.
After 600 hors you must change this reservoir and enter the new "unique" code.
Each code have a maximum date for use (ex.: 04/2009).
In fact the ink is still in good conditions, but you need a new code,
valid until.... and which has not been used in that printer.
The price of this ink reservoir is very high : 600 GBP for 1.2 liters.
And at least is never used full (empty reservoir).......
All the best,
dekor
The quality codes is printed on certain type of tanks with ink.
This type of ink is more expensive than without the quality code.
Without an actual quality code the printer does not work.
Quality code is actual during 2000 hours.
Due to a trick with general clock the expired quality code is working 2000 hours too.
Quality code that had been entered is not accepting again.
Perhaps it wiil be usefull for somebody.
302-738-5747 expire end 1 2007
992-448-6367 expire end 12 2006
667-260-2148 expire end 12 2006
833-694-8762 expire end 12 2006
764-262-7389 expire end 12 2006
287-953-2477 expire end 1 2007
424-809-8427 expire end 8 2007
435-035-7821 expire end 5 2007
to be continued...
If anybody has Q-codes pls share with us.
It will be greate to create Q-codes generator.
dekor wrote:For sure some one will find useful that valid codes:
688-607-4238
503-388-8267
468-027-2388
842-308-0687
Just I have received, so that are "fresh". (':lol:')
Laughing
Maybe a code generator will be created ....... (':?:')
Question
dekor
Thanks for fresh codes.
But expired codes sometimes are usefull too due to trick with general clock.
382-728-8747 expired 01 2007
642-369-1876 expired 12 2006
632-863-1670 expired 11 2005
377-238-4372 expired 08 2007
136-937-2722 expired 08 2006
788-615-6427 expired 12 2006
422-806-3337 expired 08 2006
476-812-9614 expired 12 2006
338-572-6912 UNTIL 10.2008
still looking for codes generator....
dekor wrote:Dear friend,
use this code:
806-229-6977
It is valid until 02/2009
dekor.
424-388-2647 valid 04/2009
indian
Post by indian » Tue Sep 30, 2008 6:38 pm
I was late a little... Have already answered.
By the way, I am surprised - 600 hours??? Our printers of 2000 hours!!! What is it? Lucky strike?
dekor
codes
Post by dekor » Tue Sep 30, 2008 6:40 pm
Hi ,
what type of printers you use?
We use DOMNIO A100 and A200
dekor.
indian
Post by indian » Tue Sep 30, 2008 6:50 pm
A200 since 2002Q3
gremlin
Post by gremlin » Tue Sep 30, 2008 7:58 pm
we use a300 printers
does any one want a full domino servive tool kit and service parts ?
i have a whole new set of tools anda whole service kit a300 and nozzles and charge electrodes etc ?
also have acceess to the software for programming the pcmcia cards !! :D
indian
Post by indian » Wed Oct 01, 2008 5:12 am
The printers are very reliable. During six years only one termosensor is out of order from four printers. So we don't need in spareparts urgently.
But I very intersting in service software. I hope the software can:
1. to extend life of quality code
2. to decrease tempetature of printing head
3. to decrease working viscosity
The printers are working fine at decreased viscosity and pressure of ink (ink is spent less, but printed characters are slightly pale - it doesn't matter).
The temperature of head has valuable influence on makeup losses.
The makeup is solute based on 2-butanon (MEK, metilethilketone, CH3COC2H5). ~99% of MEK.
The printers are working fine on pure MEK and on mix 80%-MEK + 20%-alcohol. I had testing it during long time.
All of this are valuable steps for reducing costs of owning.
enrique_gf
Post by enrique_gf » Sun Oct 26, 2008 6:32 pm
383 842 6264 until feb09
683 372 8438 until aug09
982 317 8433 until aug09
When the viscosity fails (viscosity out of range alert) i change the ink cartrige.
The manual says if i let the machine runing the viscosity will rise again but i cant have that much down time, so i change the ink, but i am not sure if i can salvage the old ink.
is there any way to save that ink or i have to trow it away?
indian
Post by indian » Sun Oct 26, 2008 8:04 pm
Rather!
just add a little amount of makeup to this ink
If you unawares added makeup more than it is necessary, and the viscosity become <100, so you have to reduce pressure of ink to 2200-2500 units while viscosity will back into normal value.
gremlin
Post by gremlin » Sun Oct 26, 2008 8:11 pm
stand the ink module i a pan of warm water for about an hour the eccess make up flashes of :D
works a treat dont stan for too long or you go the other way and have to add more make up :oops:
enrique_gf
Re: [?]: Quality codes Domino A series non-impact printers
Post by enrique_gf » Mon Oct 27, 2008 1:21 am
thanks guys.
dekor wrote:The price of this ink reservoir is very high : 600 GBP for 1.2 liters.
All the best,
dekor
What brand of ink do you use? we use GEM it may be cheaper ill investigate and tell you later
dekor
the price
Post by dekor » Mon Oct 27, 2008 9:54 am
Hi friends,
is true, the price is 60GBP.
It was a typing mistake.
dekor.
dekor
Fresh codes
Post by dekor » Thu Feb 26, 2009 11:42 am
I have some new "fresh" codes:
177-312-7095 exp. date 10.09
473-327-2091 exp. date 11.09
Is someone working in code generator?
dekor
bagos34
Post by bagos34 » Wed Mar 18, 2009 1:35 am
Does anybody has codes for ink type 899BK.? This is fast dry ink and for flexible surface material.
All codes available here are not fit. It says "incorrect ink code"
thank you
bagos34
Post by bagos34 » Wed Mar 18, 2009 2:13 am
I have one fresh code for 899BK
878 376 3851
bagos34
Post by bagos34 » Fri Aug 28, 2009 2:58 pm
for make the ink viscosity back to normal, i use to run through dry air bubbles into the ink tank. It works.
Beware of water condensation from air into ink if you are using normal air source.
JAYARAMAN
Post by JAYARAMAN » Tue Jul 13, 2010 12:14 pm
Dear All,
I am having three domino machine and purchasing inks from others.
Quality codes are not working in most of the times.
I want purchase quality code genarator machine/software.
Pl help and send contact details to me.
JAYARAMAN
sj35ram@yahoo.co.in
bacano
Post by bacano » Thu Dec 23, 2010 4:22 am
I have some Domino A100 Ink quality codes
292 333 9689
113 313 9010
These are recent codes so they should work fine ;)
How about the codes generator anyone has any update?
dekor
Post by dekor » Mon Dec 27, 2010 4:48 pm
Dear bacano,
please can you put close to the codes also the expiry date.
That can be useful to create code generator.
For sure the quality code is related to date when thy expire.
I think on this quality code is a part that mention type of ink.
Maybe good to know also the ink code.
All the best things,
dekor.
rufageo
Post by rufageo » Sat Jun 04, 2011 5:39 am
hi to all, have u got please new code for a100 or a200 ink? production is stop - coz that codes (
indian
Post by indian » Sat Jun 04, 2011 6:17 am
what about "time machine"?
(trick with general clock)
I changed my job a few years ago, so I can't help you pithily.
ovoono
Post by ovoono » Fri Jul 22, 2011 9:01 am
I have three valid codes for Domino A100.
If someone wants to exchange let others contact me on email.
jcamb
Post by jcamb » Fri Nov 11, 2011 5:47 pm
I’m very interested on this situation and also on the code generator!
I’ve some questions and I’ll place also some codes!
First the codes:
For ink 270 – 5493406207, Expires end: 04/2012
For ink 236 - 2315603932, Expires end: 08/2011
For ink 291 - 9957279109, Expires end: 08/2011
Now the questions:
Can someone explain the “trick with general clock” – my questions is because I know how to place the general clock to a date that the code can be accepted, but I need to know first the Expiration date of this code and in these posts normally you don’t place this information.
Second question is related with the ink type used, because I think I can’t place a code of an ink 270 on a machine that is using the 236, and also in most f the codes on these messages you don’t indicate the ink references.
For last and regarding the code generator I think that the 10 numbers codes define the ink type, the expiration date and also other information’s. I already know how to do some codes (in 15 normally I get one that Works – but with the same expiration date) once I know the meaning of one of this numbers. I can change this information with others that can help me to get some more information.
Zuro
Re:
Post by Zuro » Thu Dec 01, 2011 1:55 pm
gremlin wrote:we use a300 printers
Please tell me what type of pcmcia card use in the Domino A300 ? What software is used to work with a memory card?
Code generator a very interesting thing . But maybe there is a possibility to change the program Domino
Zuro
Post by Zuro » Wed Dec 14, 2011 4:04 pm
549-34-06-207
746-914-37-12
490-127-25-35
692-777-81-13
796-505-49-27
605-917-42-53
227-778-22-89
875-791-76-24
jcamb
Post by jcamb » Thu Dec 15, 2011 3:59 pm
zuro,
the first code is one of the one i've placed!
Can you please tell about the others?
Ink type and expiration date?
thanks,
jcamb
Zuro
Post by Zuro » Thu Dec 15, 2011 4:45 pm
nk Type 270
I'm sorry but I do not know expiration date. The label cartridge is unreadable - codes obtained by other means. Approximate dates dipazon - 2010-2011 year. Code number 2 new
mmrb
Post by mmrb » Tue Feb 14, 2012 4:23 pm
Hi all,
I know of some one who can supply codes at $7 each and any needed parts for the A Series printers.
Any body interested please PM me.
stjuuv
Post by stjuuv » Thu Mar 01, 2012 11:25 am
I got a code from here to use an unused ink that had just passed the use by date. Unfortunately I don't have any codes with future dates, but in case someone can use them, I'm gonna post the ones I have that are expired already.
382 765 0384 - 11/2010
179 417 8528 - 04/2011
692 188 9775 - 04/2011
172 200 7049 - 01/2012
Arun Bhatia
Post by Arun Bhatia » Thu Mar 01, 2012 4:04 pm
I NEED QUALITY CODE FOR 207BK ITS URGENT
THANKS
ARUN
ibrahim_hass
Post by ibrahim_hass » Tue May 15, 2012 9:17 am
I am looking for a quality code for the ink type 272BK. If anyone has some codes please lets share them. I will also post some codes for that ink type.
jcamb
Post by jcamb » Mon Jun 18, 2012 12:06 pm
here are the 272 codes you need:
207-674-1845 Expires end: 08/2012
996-890-4571 Expires end: 03/2012
for the one with the expirated you can place the main clock in 01/2012 and after placing the code you place it again in the actual date.
regards to all.
ibrahim_hass
Post by ibrahim_hass » Tue Jul 24, 2012 7:22 am
Here are some codes for the ink type 272
619-514-8990
607-626-9844
484-749-1344
ibrahim_hass
Post by ibrahim_hass » Sun Dec 23, 2012 7:30 am
I am looking for BK272 quality codes...if anyone have codes please post them.
sskkm
Post by sskkm » Wed Jan 23, 2013 12:16 am
572-386-0720
ibrahim_hass
Post by ibrahim_hass » Wed Mar 06, 2013 8:37 am
New codes for IR-272BKA
779-866-6843....expires end 08/2014
583-184-6979....expires end 08/2014
If anyone has more codes for 272 ink type please lets share them.
ibrahim_hass
Post by ibrahim_hass » Thu May 09, 2013 1:31 pm
Hi Guys
I have Domino Macrojet 2, I would like to add a logo to my printer. As far as I know it has to be connected to PC with special software to create and transfer the logo to the machine. Anyone know how to do this? Any got that software?
oldtimer
Post by oldtimer » Wed May 15, 2013 6:41 am
Hi I need 270 BK code urgent :(
here is a valid used code IR 270BK code 918 7072 374
bill-2006
Post by bill-2006 » Fri May 17, 2013 10:41 pm
here is one:
497 265 0221 for 270BK exp: 02/2014
Could you please send us more codes guys
curly2012
Post by curly2012 » Tue Jun 04, 2013 6:53 pm
Do you have a code for Domino A200pinpoint ? I need quality code for IR223-BK.
Ink arrives too late and I need the code sooner than that.
Galesz
Re: [?]: I need 270 BK code urgent
Post by Galesz » Thu Jun 20, 2013 10:25 am
Use this:
292-667-2578
BR
OSBE
Post by OSBE » Tue Jul 23, 2013 3:59 pm
Quality CODE for DOMINO INK BK 270.
549 340 6207
DEC. 2012
OSBE
Post by OSBE » Mon Jul 29, 2013 7:17 pm
Hi I need Quality Codes for INK 236 and Ink 291
I could exchange Codes
Domino Guru
Post by Domino Guru » Mon Aug 12, 2013 6:56 pm
Hi All
Firstly I need a code for 899 urgently.
I have worked on Domino printers for 14 years and am willing to answer any questions and help where ever I can.
As far as I know the quality code on the reservoir gives the printer the type of ink the manufacture date and the expiry date.
I have not found anyone as yet that can help with a code generator but I would gladly work with someone that can write computer code and try to solve this generator software issue.
As for some of the questions asked earlier in these posts.
1) Head tempreture is easy to change without the use of the PCMCIA card.
2) Changing viscousity range or reservoir life with the PCMCIA card and the software is not possible.
3) Macrojet logos need to be designed in a special software package and burnt onto the EPROM inside the printer.
Thanks all and looking forward to helping where and if I can.
nobee
Post by nobee » Tue Sep 03, 2013 11:04 am
Can anyone post codes for ink 291 BK
standart
Post by standart » Thu Sep 05, 2013 8:09 am
Hi;
Domino A series 291 BK Quality Code : 467 055 1091 / year 2011
: 206 307 9511 /year 2011
I hope so You will use codes.
Regards
Domino Guru
Post by Domino Guru » Fri Sep 06, 2013 6:21 am
Hi All
Does anyone have codes for 899BK ink reservoir?
oldtimer
Post by oldtimer » Tue Sep 17, 2013 6:58 am
Hi, IR 270 BK code 4973628261 06. 2014.
Huyen Lam
Post by Huyen Lam » Fri Oct 04, 2013 8:00 am
I have a fresh code for 299BK: 6400609098 299BK Exp 04/2015.
If anyone have more code, please share
Huyen Lam
Post by Huyen Lam » Mon Nov 04, 2013 10:44 am
Hi all,
Any new code for 299BK and 234BK, please share.
I need them in urgent case.
Thanks,
sneg
Post by sneg » Sat Feb 01, 2014 4:34 pm
hi all ! Quality codes of reservoirs that i have:
IR-064RG printing ink (RED COLOUR!)
Quality code 245-103-2296 Expires End 9/2014
IR-295BK printing ink, Expires end 7/2015:
153-896-7094
864-356-0969
324-905-5693
539-369-6045
269-153-0495
IR-270BK printing ink, Expires end 4/2014:
342-527-4892
254-109-2227
322-420-7529
It need to have a program - generate Q.codes , i think
