[LINK]: Flow Calc32 and Festo Fluid
Hye All,
Did any body have Flow calc32 software with serial key or crack ?
Regards
AJC
Regards
AJC
Crack Fcalc32
Link_is_Dead :(/Flowcalc.exe.html
Please replace crack in folder ce.
Good Luck!in Russian wrote:Есть русская программа Расходометр_СТ. Может кому надо.
Crack Fcalc32
Thank you very much vlad for this post.
zenchek
zenchek
Flowcalc
For activation in Flowcalc compensation please
open Flowcalc.exe in hex editor (winhex),
get offset 15FDC0 and replace:
old- 007562A11CB557008B008B10FF92EC00
new- 007462A11CB557008B008B10FF92EC00
Good luck!
Good luck!
Re: [LINK]: Flow Calc32 and Festo Fluid
link dead.
i used hex editor and cant find the hex numbers for the latest version of flowcalc32.
anybody has crack for the flowcalc32 v5.30?
or flowcalc v4.05 installaion software so that i can use hex editor and i can get offset 15FDC0 and replace:
thank you for all who will contribute in...
I need Key for Flowcalc32 Version 5.33 key needed. please hlep us in this regards
Or some one please share the Licensed version 5.30 which Key is given Above.
Regards
Rafi
Regards
Rafi
Hex Modification is not working please help
Thanks In advance
Thanks In advance
