[LINK]: Step 7 V5.4 SP3 (Vista compatible) and others SP
Masta2002
Post by Masta2002 » Wed Oct 10, 2007 5:33 am
maybe redownloading helps!!
Cant try it now cause the server is really slow!! But i guess this is a siemens BETA version!
Operating systems
STEP 7 V5.4 including SP3 is a 32-bit application that is released for the following operating systems:
Operating System Service Pack
MS Windows XP Professional SP2
You can find information about the operating systems on the Internet at Microsoft.
STEP 7 V5.4 including SP3 will not run in:
• MS Windows 3.1
• MS Windows for Workgroups 3.11
• MS Windows XP Home
• MS Windows Vista
Galli
Post by Galli » Wed Oct 10, 2007 2:06 pm
All files No problem .. I use download manager (DAP)..
I success download, and extract --> produce CD_1 as below .
If save target as, giving problem - try download accelerator plus ..
Masta2002
Post by Masta2002 » Wed Oct 10, 2007 3:49 pm
ok downloading and extracting works fine here!
But i am still thinking it is a beta can anyone confirm this?
Cause i heard the final version of SR3 is running under Vista and comes out Jan/Feb 2008
Post by CoMod » Wed Oct 10, 2007 4:20 pm
Possible this is not BETA.
See Readme of PCS7 v7.0 SP1 included STEP 7 Basic V5.4 + SP3
http://support.automation.siemens.com/W ... d=26588478
PCS 7 Toolset DVD wrote: SW components PCS 7 V7.0 including Service Pack 1
_Manuals
_Product Information
Acrobat Reader V8.0
Automation License Manager V3.0 + SP1
DotNetFramework V1.1
CFC V7.0 + SP1
S7 SCL V5.3 + SP2 + HF1
SFC V7.0 + SP1
TH V7.0 + SP1
IEA-PO V7.0 + SP1
PCS 7 library V7.0 + SP2
PCS 7 Advanced Process
Control Library V7.0
VersionCrossManager V7.0 + SP1
Version Trail V7.0 + SP1
PCS 7 PID Tuner V7.0 + SP1
DOCPRO V5.1 + SP2 + HF1
PLCSIM V5.4
SIMATIC WinCC V6.2 + SP2
Web Navigator V6.2 + SP2
StoragePlus V1.2 + SP2
Open PCS 7 V7.0 + SP2
SFC Visualization V7.0 + SP1
AS-OS Engineering V7.0 + SP1
PV InsInfo Server V7.0 + SP1
@PCS7 -
PCS 7 Faceplates V7.0 + SP2
Control Faceplates V7.0
SIMATIC NET PCSW V6.4 + HF6
SIMATIC BATCH V7.0 + SP1
SIMATIC BATCH BLOCKS V7.0 + SP1
SIMATIC BATCH WinCC Options Integrated in SIMATIC BATCH
SIMATIC Logon V1.4 + SP1
SIMATIC Logon Service STEP 7 Integrated in SIMATIC LOGON
SIMATIC Logon Admin Tool Integrated in SIMATIC LOGON
SIMATIC Electronic Signature Integrated in SIMATIC LOGON
SIMATIC PDM V6.0 + SP3
SIMATIC PDM Devices Separate CD 02/2007
SIMATIC Route Control V7.0 + SP1
PCS 7 System Documentation V7.0 + SP1
PCS 7 Tools V7.0 + SP1
Additional_Products:
BATCH Report V7.0 + SP1
DCF77Client V1.22
DiagnosticsMonitor V3.1
Drivers
Smart card \ CardMan 3121 USB
DISPLAY \ Matrox_G450_MMS
NETWORK \ Intel
Logfile Compressor
OPC_A&E_Server From PCS 7 V7.0
PCS 7 Driver Blocks -
PCS 7 library -
PCS 7 library -
PCS 7 library -
PKZIP -
SimaticRights
Web Navigator V6.2 SP2
WinAC SLOT V4.0
WinCC_Fileserver V6.2 SP2
Microsoft
Cause i heard the final version of SR3 is running under vista and comes out Jan/Feb 2008
STEP7 v5.5 or v6.0 ?
Masta2002
Post by Masta2002 » Wed Oct 10, 2007 5:08 pm
this version is english and chinese only so if you use another lang it will not work!!
I cant install it here!!
Readme wrote:STEP 7 V5.4 SP3 Chinese Programming Software for SIMATIC S7 / M7 / C7
Notes on Installation and Usage
These notes should be considered more up-to-date than the information in other documents. Read the notes carefully, because they contain information on installing and using STEP 7 V5.4 with Service Pack 3.
it looks like a final version but i am still not shure about it
Garog
Post by Garog » Wed Oct 10, 2007 6:14 pm
oh nice.. i think somebody gets many trouble for this...
this is only a beta.
Masta2002
Post by Masta2002 » Fri Oct 12, 2007 1:01 pm
These links is a final release of Multilanguage Service Packs
you can found now the new final versions on german siemens hp
SP3 for STEP 7 V5.4
http://support.automation.siemens.com/W ... e/26578452
http://support.automation.siemens.com/W ... 54_SP3.zip ( 748.3 MB )
SP4 for S7-GRAPH V5.3
http://support.automation.siemens.com/W ... e/26452561
http://support.automation.siemens.com/W ... 53_SP4.exe ( 105.7 MB )
SP3 for iMap STEP 7 AddOn V3.0
http://support.automation.siemens.com/W ... e/26574438
http://support.automation.siemens.com/W ... 30_SP3.exe ( 113.3 MB )
SP3 for S7-SCL V5.3
http://support.automation.siemens.com/W ... e/26577639
http://support.automation.siemens.com/W ... 53_SP3.exe ( 39.9 MB )
SIMATIC Logon V1.4 with SP1
http://support.automation.siemens.com/W ... e/26653132
http://support.automation.siemens.com/W ... _00_08.zip ( 248.6 MB )
These releases should be VISTA Ready now but you need full version of STEP 7 V5.4 SP3 or Professional 2006 SR3 for installing it on WinVista so it would be nice if someone can upload this DVD for us!!
Readme.rtf wrote:3 Software Requirements
3.1 Operating Environment
Operating systems
MS Windows 2000 Professional SP4
• MS Windows Server 2003 SP2 Standard Edition with or without R2 as workstation
computer (exception: SIMATIC M7, see also, instructions in Section 6.18 )
MS Windows Vista 32 Bit Ultimate and Business
Galli
Post by Galli » Sat Oct 13, 2007 1:55 pm
Hi Masta2002,
Just to confirm, the link you given is it for German only or
Multilanguage..
And the following, as post no.1 (silvia) for Chineese only or with English..
Masta2002
Post by Masta2002 » Sat Oct 13, 2007 2:59 pm
Galli wrote:Hi Masta2002,
Multilanguage..
The first link ist chinese and english only
my links are multilingual but they are only on german siemens site!
Marco_Polo
STEP 7 V5.4 SP3 work on vista
Post by Marco_Polo » Sat Oct 13, 2007 7:26 pm
It's working on Vista.
No need of other software
Masta2002
Post by Masta2002 » Mon Oct 15, 2007 7:29 pm
found on siemens hp that this component versions come with Step7 pro SR3 DVD
This is the full DVD. Step 7 including SR3
Step 7 Professional Edition 2006 Service Release 3
- STEP 7 V5.4 incl. SP3
- S7-GRAPH V5.3 incl. SP4
- S7-SCL V5.3 incl. SP3
- S7-PLCSIM V5.4
STEP 7 Professional s a 32-bit application that is released for the following operating systems:
MS Windows Server 2003 standard edition as workstation
(Exception: SIMATIC M7, see the release notes for STEP 7 V5.4 SP3, chapter 2.18) SP2
MS Windows VISTA 32 Bit Ultimate, and Business
http://rapidshare.com/files/63122251/S7 ... part01.rar
http://rapidshare.com/files/63130699/S7 ... part02.rar
http://rapidshare.com/files/63139205/S7 ... part03.rar
http://rapidshare.com/files/63148799/S7 ... part04.rar
http://rapidshare.com/files/63158917/S7 ... part05.rar
http://rapidshare.com/files/63169374/S7 ... part06.rar
http://rapidshare.com/files/63180293/S7 ... part07.rar
http://rapidshare.com/files/63192593/S7 ... part08.rar
http://rapidshare.com/files/63194381/S7 ... part09.rar
