[?]: Step 5 Keys
mogz
[?]: Step 5 Keys
Post by mogz » Sun May 13, 2007 8:13 am
Anyone help withkeys for Step5/graph5?
The Keys in EKB do not work?
Post by CoMod » Sun May 13, 2007 8:34 am
Key work, but you need use identical number ID KHE when install Step5 and key EKB.
mogz
Post by mogz » Tue Jun 05, 2007 5:40 pm
I try and install the S5/Graph 5 keys with same ID: KHE number but S5 say authorisation not found?
Can anybody help?
ztom
Post by ztom » Mon Jul 09, 2007 8:17 pm
The authorisation must be in drive C:
or You can modify the uathdrive in S5@@@@CF.INI
mogz
Post by mogz » Tue Jul 10, 2007 2:37 pm
I tried this and it does not work.
If I use EKBBackup to change number of keys on original yellow authors disk then use ALM to transfer key, all works ok.
