[?]: New electrical CAD elecworks
Тools, Elcad, Eplan, ...
silvia
Post by silvia » Wed Jan 28, 2009 8:45 pm
verdis
elecworks
Post by verdis » Mon Feb 09, 2009 12:06 pm
all
does any one has the software and cracks? or any software that can be used with solidworks 2009.
thanks in advance
silvia
Re: [?]: New electrical CAD elecworks
Post by silvia » Tue Feb 16, 2010 10:30 am
djcatalyst
Post by djcatalyst » Thu Feb 25, 2010 7:34 am
do i need to install solidworks to using this program?
most
Post by most » Fri Feb 26, 2010 7:28 pm
djcatalyst wrote:do i need to install solidworks to using this program?
not
it runs alone, it seems to work well but it is not easy to work :?
IBMAcer
Post by IBMAcer » Fri Jan 28, 2011 5:22 pm
Introduction
Software for design of automation projects.
Elecworks™ is a powerful new generation software tool, that enables electrical designers and automation experts to create automation and electrical installation projects. Through Windows standard interfaces, engineers can produce better installation designs and supporting documentation faster.
Elecworks™ lets you enter data project data from the preliminary research stages. A huge part of the project planning can be achieved without having to do any scheme diagrams, this is thanks to the processing tools such as the Line Diagram and Components Management features.
Elecworks™ has been developed as an electrical CAD system for use by design engineering professionals. Scheme diagrams employ intelligent wiring and internationally recognized symbols standards that provides seamless continuity of project data.
There is no learning curve, using elecworks™ is straightforward with self explanatory no jargon commands. Smart tools provide context sensitive help and commands that let you produce small, medium, and large projects with multiple engineers collaborating together.
Features
The user interface
With 20 years experience in the field of electrical and mechanical CAD/CAE, Trace Software has created a uniquely innovative product, bringing all new, faster and more reliable working methods. Elecworks™ is inspired by Windows standards and has multi-level UNDO/REDO facilities available for all functionalities. The product has contextual menus and a ribbon interface that lets you access commands in a natural way as the project develops.
Synoptic
The line diagram gives users the opportunity to describe the installation through a schematic diagram, representing the different equipment and connecting cables. The description via the diagram allows rapid definition of equipment and cables, and can also be used as a project costing tool. The information in the diagram is automatically re-annotated into the detailed scheme drawing.
A database to stock a project data
Elecworks™ stocks all installation information, from symbols and lines, up to the complete description of components and cables in a database representing the digital template of an installation. When you work with elecworks™, you are interacting with this database in real-time.
Knowledge base orientation
Proven designs and company best practises can be embedded into the specific diagrams or projects, to be reused in other projects. Elecworks™ will allow the designer to store this data in minutes and make it available to all users, as a part of, or as a complete functional structure of a project.
The Input/Output I/O database
The management of I/O has been studied in particular in elecworks™. It is one of the principle elements in the sizing of the project: choice of the PLCs, number and types of cards necessary, the interface with the software programs, project cost, choice of cable technology, etc.
The technology
Elecworks™ is the result of an unprecedented technological development. The graphics are stored in a native DWG compatible format that enables data exchange between different software packages. The database uses SQL Server, with configuration data in an XML format, the application is 100% Unicode.
The main functionalities
Elecworks™ contains all the functions and necessary applications in order to prepare documentation and to produce the automation installation:
Schematic design tool, draw multiple lines, insert symbols with an automatic break in the line.
Multi-standard symbol library.
A complete design tool for line diagrams.
Layout library, expert copy of sheets and projects.
Automatic generation of terminal strips and their management.
Management of I/O and PLCs management.
Manufacturer database, multi-catalog search tool, detailed classification of devices base.
Wire Numbering in accordance to different norms, real-time cross-references updates.
Location and functions management accordance with the IEC61346 norm.
Incorporate all project documentation types.
EXCEL interface, PDF printing option, drawings in native DWG format.
Dynamic multi-language translation tool, automatic language change project drawings.
Input of project lists without scheme, ERP interface.
Navigation tool.
Real-time reports, user customizable page-layout, data export possible in different formats: Excel...
Automatic identification of components, cables, wires, sheets, functions, and locations.
Multi-language application interface, multi-lingual project management.
The project can contain and display many languages at a time in the interfaces and schemes.
Automatic translation of the projects in all languages using an intelligent glossary based translation tool.
Import/Export of Excel of PLC inputs/outputs, project models creation.
Multi-user working environment that allows users to work in parallel on the same project.
Mirror
http://letitbit.net/download/63578.605c ... 4.rar.html
http://letitbit.net/download/43833.4829 ... 6.rar.html
http://letitbit.net/download/71306.7756 ... 5.rar.html
http://letitbit.net/download/52487.58ec ... 2.rar.html
http://letitbit.net/download/69495.681f ... 7.rar.html
http://letitbit.net/download/28847.2465 ... 3.rar.html
http://letitbit.net/download/67051.65d3 ... 1.rar.html
http://letitbit.net/download/49407.4acd ... G.rar.html
