EPLAN 2.1 - maximum logic pages reached
Тools, Elcad, Eplan, ...
bjekas
Post by bjekas » Tue Oct 30, 2012 1:16 pm
Hello hello,
Im using Eplan Electric P8 2.1 SP1. In my project I have 10 multifilar pages and when I try to make the 11th it says that it has reached the maximum number of logic pages... :shock:
Anyone had this problem in the past?
Risky73
Re: EPLAN 2.1 - maximum logic pages reached
Post by Risky73 » Wed Oct 31, 2012 9:26 pm
Forget about v2.1, there was never a proper crack for that version (licence on this forum is some sort of demo which allows only up to 10 pages). Use ePlan v2.2, working crack is available ;)
xflash
Post by xflash » Fri Nov 02, 2012 2:06 pm
Thanks for your info. But could you please give me the working 2.2 version link, I searched out the internet, none of them seems well.
Thank you a lot!
Risky73
Post by Risky73 » Fri Nov 02, 2012 5:53 pm
This is topic for ePlan v2.2 : viewtopic.php?f=7&t=18563
And inside topic viewtopic.php?f=7&t=18462 is crack which is working for me (Win32).
xflash
Post by xflash » Sat Nov 03, 2012 3:50 am
Thank you a lot. It is said that edz files cannot be imported in crack version. That only works in data portal, which only genuine users can access.
Is that true?
Risky73
Post by Risky73 » Sat Nov 03, 2012 9:58 pm
I didn't know what edz files are until you mentioned them. Seems interesting, and according to this topic (italian forum) http://automazione.plcforum.it/index.ph ... -file-edz/ it seems that edz is packed file (7z or zip) from which macro's and xml parts file can be extracted.
If you have some interesting edz file maybe you could share it (or link where you got it) with rest of forum members ;)
xflash
Post by xflash » Wed Nov 07, 2012 3:46 am
After I searched the internet, I found that edz import function is built in eplan 2.2 . Have a nice day~
But this function is available in data portal which connects the EPLAN server, so it is only for genius users ........ :o :o :o :o
TienTIA
Post by TienTIA » Tue Jul 09, 2013 6:40 am
Here is a work around for import .edz files to EPLAN 2.2.
Rename the edz file to zip.
Use winrar to unzip it.
In EPLAN,
+ open part management dialog: Utilities -> Parts -> Management
+ open import records diaglog: Extras -> Import
+ Select file type: XML
+ Select file name: look for xml file in subfolder "items\partxml\" in extracted folder
+ Press OK to import.
Hope this help
Checked with EPLAN 2.2 and edz file downloaded from Siemens support site.
Draco Malfoy
Post by Draco Malfoy » Thu Apr 30, 2015 11:20 pm
Its doesn't work. WHY it was possible with EDZ without any problems in the 2.1 Version and absolutley not, now ???
