EPlan External Connections List
Тools, Elcad, Eplan, ...
pinecone
Post by pinecone » Mon Aug 05, 2019 3:41 pm
Hi all,
I am working in EPlan with connections lists, and would like to set up a way to automatically create on all mounting locations a connection list consisting only of connections traveling out of that particular mounting location. I have done this successfully by setting the filter scheme to only include connections with one end in a given location and another end anywhere other than that location. This is easy enough to copy to other panels (mounting locations) and change as needed, but may be cumbersome on large projects. Does anyone know how, in the filter settings, I could tell it to use the current mounting location every time instead of me having to create a new filter scheme and specify the mounting location for each case?
