Тools, Elcad, Eplan, ...
metl83
Post by metl83 » Wed Jan 27, 2021 2:29 am
tonyjordan wrote:
Tue Jan 26, 2021 7:42 pm
Works on both Vmware and Virtualbox. Thank you Chaos for this great work. Please let me know how i can make a donation to you.
COOL!!! Thank you! how donate? ), please send way )
juanmemo
Post by juanmemo » Wed Jan 27, 2021 6:36 am
chaos363 wrote:
Tue Jan 26, 2021 4:49 pm
And there is the good piece. I hope you can do something with it.
### Crack ###
The file vcruntime140.dll must be in the main directory of the corresponding product. This is automatically loaded into the application process when it is started and ensures that the license you have created yourself is checked successfully.
For eplan eletric 2.7 this is: C:\Program Files\EPLAN\Platform\2.7.3\Bin.
For eplan eletric 2.8 this is: C:\Program Files\EPLAN\Platform\2.8.3\Bin.
For eplan eletric 2.9 this is: C:\Program Files\EPLAN\Platform\2.9.3\Bin.
### Keygen ###
The keygen can generate a license for all current products, but only with the correct license information. There are the following 3 types of license information.
- System
- Module
- Option
To license a product, System_ and Module_ (with the addition "Release:") must be available. Everything else is optional and will only be used if the product is intended to. Option_ cannot currently be saved because I have not yet seen the benefits.
I have implemented a template function so that not everyone has to assemble the license themselves. This consists of a simple text file which contains the id and the text per line. The text and the "=" can be omitted, as only the id (e.g. System_150) is relevant. If the line is invalid, it will not be added.
EplanCommon.lit is read in so that the existing licenses are known. It is checked whether the file is in the current directory. If not, there is a backup in keygen.
The keygen was built in a short time, which is why it is certain that not all problems will be intercepted, but it should work.
### Requirements ###
- Microsoft Visual C++ Redistributable 2019
### Install ###
1. Open C:\Windows\System32\drivers\etc\hosts
-> insert the following lines
0.0.0.0 eplan.prod.sentinelcloud.com
0.0.0.0 licensingservice.epulse.cloud
2. Copy Crack\vcruntime140.dll into install dir
-> e.g. C:\Program Files\EPLAN\Platform\2.7.3\Bin
-> e.g. C:\Program Files\EPLAN\Platform\2.8.3\Bin
-> e.g. C:\Program Files\EPLAN\Platform\2.9.3\Bin
3. Generate license with Keygen\EPlanKeygen.exe and save it into lic dir
-> C:\Users\Public\EPLAN\Common
4. Run EPlan
Download: https://anonymousfiles.io/AUW3Cy8f/
You are the beast!! You save the day!! Thank you very much!!!!!
marexx
Post by marexx » Wed Jan 27, 2021 7:50 am
chaos363 all respect for your work !!!
Works on WM Win 10. :D
Best regards.
Centurio
Post by Centurio » Wed Jan 27, 2021 2:59 pm
Working!
Great job!
can someone provide links for Propanel 2.9 / API and the others Eplan - Apps?
rogerg85
Post by rogerg85 » Wed Jan 27, 2021 3:03 pm
chaos363 respect and many, many thanks...
Could someone re-upload EPLAN Pro Panel Professional 2.9?
Thanks in advance.
chaos363
Post by chaos363 » Wed Jan 27, 2021 5:37 pm
If you want to support me, you can use the following bitcoin address.
========== edited by Admin =========
thank for your support (thnx)
but our rules
:anon: all bitcoin addresses will be deleted
scammers will use your utility to get money from users
use private messages (pm)
спасибо за работу (thnx)
НО наши правила
:anon: все адреса кошельков будут удаляться
аферисты будут использовать твою утилиту для получения денег от пользователей
используйте личные сообщения (pm)
TheDuke
Post by TheDuke » Wed Jan 27, 2021 6:14 pm
Thank you very much for this great work.
It works perfectly and you can also choose your license scope yourself.
My respect for that and thanks again for sharing.
Brodie1201
Post by Brodie1201 » Thu Jan 28, 2021 12:56 am
How do you edit these lines? What program specifically?
### Install ###
Post by CoMod » Thu Jan 28, 2021 8:14 am
### Install ###
Copy file "hosts" to "hosts.txt"
edit text file "hosts.txt"
Copy file "hosts.txt" to "hosts"
https://yandex.ru/search/?lr=2&text=how ... =suggest_T
Stefan_TS
Post by Stefan_TS » Thu Jan 28, 2021 9:30 am
Thank you a lot for this Crack.
But for EEC ONE this license doesn't work( Maybe I do something wrong
How I can Active EEC ONE?
chaos363
Post by chaos363 » Thu Jan 28, 2021 9:56 am
but our rules
НО наши правила
That's not a problem, I should have read through it again in advance.
Since I saw the challenge and not the money, I don't really care :).
Whoever wants can send me a message.
jukuo
Post by jukuo » Thu Jan 28, 2021 11:54 am
Add text to host, Using Bluelife hosts editor is a Portable Freeware
Download: https://www.sordum.org/8266/bluelifehosts-editor-v1-3/
mojtaba
Post by mojtaba » Fri Jan 29, 2021 4:56 am
(gpost)
veeeeeeeeeeeeeeeery goooooooooood (oo)
chaos363
Post by chaos363 » Fri Jan 29, 2021 7:33 am
I am not very familiar with EPLAN and all the additional applications, but to me eplan eec one looks like an excel integration of projects. Should it be a separate application, could you provide me with the installation?
Centurio
Post by Centurio » Fri Jan 29, 2021 10:02 am
Hi chaos363,
EPLAN 2.7-2.9 is working, but i can confirm, that the other EPLAN apps (Propannel EECone Coengineer etc.) won't work.
Working links for EPLAN 2.8 apps are here in the forum:
viewtopic.php?f=7&t=26689
chaos363
Post by chaos363 » Fri Jan 29, 2021 6:04 pm
ok, i have now tested the following applications, which all worked.
CPM
Engineering configration
Fluid
Fluid Hose Configurator
Preplanning
Pro Panel
Please note the following points so that the activation works.
- In the main folder where the .exe file of the application is, the file vcruntime140.dll must be added
- The license template that I made available does not contain everything necessary. The product must be in the system list (e.g. "Eplan Engineering Configuration: Develop") and in the module list (e.g. "Release: EEC 2.8").
- A current License Client must be installed. With EPLAN 2.7, for example, the current license system could not be installed, which is why the activation does not work.
API I didn't know how to test it, the principle of the activation should still work.
rogerg85
Post by rogerg85 » Fri Jan 29, 2021 7:37 pm
Would someone be so nice and upload Eplan Pro Panel 2.9?
machineer
Post by machineer » Fri Jan 29, 2021 11:38 pm
Everything I have tried so far works as well. I'm truly impressed by your work chaos363, thanks a lot!
Here's a link for Pro Panel 2.9.4 SP1:
https://gofile.io/d/Z6P5Wd
Works perfectly with the licensing system from chaos363. If you have also the Electric P8 2.9.4, as shared by popi (also thanks btw):
popi wrote:
Wed Jan 20, 2021 12:09 pm
Hi. Here is the link for latest version Eplan P8 2.9 SP1 with Update 4
https://fastshare.cz/15529328/eplan-p8- ... pdate4.zip
they both share the Eplan.exe at \EPLAN\Platform\2.9.4\Bin\ so having the dll file there is enough. At least the licenses "System_153 EPLAN Pro Panel. Professional" and "System_162 EPLAN Component Manufacturer" (includes both Electric P8 & Pro Panel Professional) worked for me.
Donjore
Post by Donjore » Sat Jan 30, 2021 10:16 am
Can anyone tell me how to use the keygen? thanks.
debugman
Post by debugman » Sat Jan 30, 2021 11:52 am
I installed EPLAN 2.9 Sp1 Update4. But I can only choose the professional version at the most. I can't choose the higher version, such as professional+ version, ultimate version and enterprise version.
Spoiler
chaos363
Post by chaos363 » Sat Jan 30, 2021 3:28 pm
I'm not an expert on possible licenses, but for me it looks like that with version 2.9, EPLAN has reduced the number of possible variants. If you look at the texts, you will notice that the possible licenses are separated by a dot and the ones that are not possible with a hyphen. The texts are taken from EplanCommon.lit, i.e. directly from eplan. With version 2.8 only the old ones can be selected.
In any case template is not perfect, here I have put in all items that make sense for me so that at least eplan 2.7 / 2.8 / 2.9 runs.
elektron0x90
Post by elektron0x90 » Sat Jan 30, 2021 5:29 pm
It´s because EPLAN is changing the licensing system from "with hardlock" to "dongleless". By doing this are changing the "pakets" that are included when you buying a Sytem. So the useres with dongle will get a "upgrade" (means more functionality) if they are changing from the dongle-lincence to hardware-id-licence. You can find the new pakets by looking at the lit-file and seeing the new "Elements" entrys.
I think it is to prevent the dongle-swaping. With the old licence you could install on desktop-pc and notebook and switching your workstation by swapping the dongle. Therefore you should now by a "Network Licence" which is about 10-20% more expansive than the single-user-licence.
Also they are changing the network-licenses so you can only use them in 1 domais and only in the country it was bought. Now more traveling and using it for on-side working.
greetz e0x90
Centurio
Post by Centurio » Sun Jan 31, 2021 10:22 am
@ elektron0x90:
not correct - EPlan - user with dongle have to use the new licensing system with the dongle; they can use older versions incl. Eplan 5 (if licensed), but only on a second system, Vmware or a second pc.
I think that's not effected the functionality.
Version 2.8, new licensing supported version 2.4 - 2.8; version 2.9 supported 2.5 - 2.9.
Since V. 2.9 it should be possible for dongle user to use 3 installations with dongle swapping (source: EPlan.de).
@ chaos363:
All apps working now, incl. EEC one 2.7.
My fault, didn't know that i have to add the system entries - had only removed the "education" entries first.
I'm curious how the manufacturer will react to block the crack. With the previous licensing, a timer was integrated, which also often paralyzed legal users.
elektron0x90
Post by elektron0x90 » Sun Jan 31, 2021 3:08 pm
Not complete. The new licence manager only supports Eplan P8 2.4 and above.
Eplan changes the License Agreement that it is from now on forbiden to use the dongle on more than one system. You should swich between the older and new License-Manager to use P8 v2.8 and above ore the older System like Eplan5. Also they permitted the installation of the software on a second system. (But they can´t check that).
I asked Eplan directly how they will handle it because i´m have to use EPLAN 21 in a VM because it only supports WindowsXP
But so far no problem, if they can´t check i can use my dongle in VM with old and on HOST with new license manager.
Also right but not complete...
You now can get dongle-less licenses if you give your dongle back to eplan.
They than switch your licenses to the new-new-licensesystem (with Elements).
Than you dont need a dongle it´s all hardwarebased (that by the way is how the crack work - it uses the new dongless-mode)
But you always have to revoke the licenses. If you are switching to often (the spoken 3 times from EPlan) they will offer you the network-license (no need to aggree, but they try ;))
xflash
Re: Eplan P8 NEW VERSION 2.8
Post by xflash » Sun Jan 31, 2021 3:54 pm
chaos363 wrote:
Thu Jan 21, 2021 4:55 pm
Spoiler
EPLSG wrote:
Thu Jan 21, 2021 3:07 pm
I think that:You are the magician. It would be great a report for installation. I want to ask you: Eplan normally have an online activation,inserting EID directly whwn open P8 for the first time. Is patched too?
With full patch that I hope arriving soon is possible works with Eplan with internet connected or not?
The following steps must be carried out to install the activation. This information is also contained in the Readme.txt, which is available in download file.
	-> C:\Program Files\EPLAN\Platform\2.9.3\Bin
3. Copy License\lservrc into lic dir
4. Run EPlan
In the end, the online activation only downloads the license that I have made available to you and pushes it into the following folder. When the application starts, it is checked whether this file is there. If not, the popup for entering the license appears. The license itself is an exact replica of the original, where only the PKCS#1 check is not valid. This is what vcruntime140.dll is for.
The change in the hosts file means that EPLAN can no longer correctly resolve the dns addresses for licensing and thus cannot make calls home. Of course, the possible addresses could be expanded by updates from the manufacturer.
The activation that I have sent is in a final state. There could only be problems with an incorrect calculation of the hardware id. Now the possible users must be adjusted or network licenses generated.
At the moment I don't think that the manufacturer expects this activation, which is why everything should work.
Wow, this is exciting!
It is well told this is working well.
There is a little problem, I use proxy very often, this make hosts file block meaningless, is there any alternative way to not block eplan connect to internet?
Even with firewall, the block may failed, if one time fails,it may be blocked (only in technology), if possible, please find a way to unblock and to use with internet. :D
Thank a lot for this, it is really good news for 2021, the world is needing good news. :D
chaos363
Post by chaos363 » Sun Jan 31, 2021 6:54 pm
From a practical point of view, blocking the activation is easy to implement, but I can easily bypass this block. Since the license corresponds to the original, the manufacturer cannot just change everything, since the entire license system would have to be converted. I've already seen one or the other form of implementing an online compulsion, but that can't stop me.
I'm also not an expert on redirecting and blocking network traffic. The changes to the hosts file are a common way to block the dns addresses, but there are certainly various alternatives. Others can certainly help you better.
If one assumes that the eplan files have been manipulated, I have already implemented such a solution. Here a special dll file is loaded into the process, which hooks windows network functions and acts like an internal firewall. However, since the eplan product range contains a large number of files where each individual can make a call, it is not possible for me to monitor everything.
It would be nice if anyone could present keygen better in the forum. I want to build such solutions, but not market them :). Since there are still people who send me their hardware id, keygen is not always found.
xflash
Post by xflash » Mon Feb 01, 2021 3:39 am
Thank again for the reply.
I mean let the eplan the connect to internet and unblock the license manually, it is an era of Internet, it is always used without the Internet and with Internet. If this is possible and takes no trouble.
Please start a new topic and the Site Admins may set some notifications, they are nice.
davidsk2001
Post by davidsk2001 » Mon Feb 01, 2021 5:25 am
Anyone can share the installer for Eplan P8 2.9 SP1? Thank you (oo)
popi
Post by popi » Mon Feb 01, 2021 6:27 am
Here is the link Eplan P8 2.9 SP1 with Update 4
https://fastshare.cz/15529328/eplan-p8- ... Bee5ehKhaQ
childplay
Post by childplay » Mon Feb 01, 2021 12:47 pm
Hello!
I downloaded the application EPLAN Electric P8 2.9 SP1 (x64) and defined my hardware id:
*1S4SE5R7TK2EVNL2004,*1PNSH44VQQ59MDP001C,*1LU7USPHTL5G5AX2018
odairrocha-jr
Post by odairrocha-jr » Mon Feb 01, 2021 12:55 pm
chaos363
### Crack ###
### Keygen ###
- System
- Module
- Option
### Install ###
4. Run EPlan
Thank you very much for the solution @chaos363, simple and easy to do, WELL DONE!
(tyou) (gpost)
bars
Post by bars » Mon Feb 01, 2021 1:50 pm
Could someone upload Eplan PrePlanning 2.9? I can't find links on the forum.
amk_
Post by amk_ » Mon Feb 01, 2021 2:58 pm
Succesfully installed and implemented crack.
Thank you chaos.
Does anyone have problem where Eplan suddenly crashes? Without any warning.
I have 2.9 and downloaded it from link provided in this forum.
I assume its not issue with crack..
Best regards,
IVVA
Post by IVVA » Mon Feb 01, 2021 8:30 pm
Eplan Pro Panel 2.9 https://pan.baidu.com/s/1ImR_sZkA74IgNPElIVOZHw.
Password: 9SP1
davidsk2001
Post by davidsk2001 » Tue Feb 02, 2021 8:05 am
Thank you very much. Ongoing download.
keymak
Post by keymak » Tue Feb 02, 2021 1:46 pm
Hallo,
i have a problem with licensing, licensing does not match the version.
I have v2.9 SP1 update 4 installed in a VM
what do I have to set in the keygen, how do I proceed?
thanks for your help
keymak :wink:
tolstal
Post by tolstal » Tue Feb 02, 2021 2:07 pm
Could someone upload EPLAN Harness proD 2.9? I can't find links on the forum.
DanH
Post by DanH » Tue Feb 02, 2021 5:58 pm
Please can someone post a full set of 2.9 installers?
mojtaba
Post by mojtaba » Tue Feb 02, 2021 8:55 pm
I noticed a few things while working with eplan2.9
In the (Utilitise > eplaus ) section, the "eVIEW free" and "eBUILD free" options do not work.
Do you have a solution? Errors are displayed
for "eBUILD free" & "eVIEW free":
Loading of the page https://eview.epulse.com/ has failed
Error code: TimedOut
Try again
chaos363
Post by chaos363 » Tue Feb 02, 2021 10:46 pm
If eplan should be allowed to connect to internet, simply omit entries in hosts file. The activation is not dependent on it.
This is the first time I hear eplan crash. Unfortunately, I can't recreate crash on myself either. Should the reports pile up, I'll take a closer look.
Hallo,
Since I do not have the safenet sentinel rms development kit, I have to calculate hardware id. Problems can arise here due to non-implemented routines. Can you provide me with vm as a download so that I can look at the situation. The generation of the hardware ID in EPLAN is not easy to control, otherwise I would have built something so that everyone can look at original ones calculated by EPLAN.
chaos363
Post by chaos363 » Tue Feb 02, 2021 10:55 pm
Try again
That sounds to me as if the connection to EPLAN is being blocked by hosts entries. Activations usually do not go hand in hand with online services from manufacturer :). Since activation does not necessarily need entries in the hosts file, you can start testing here.
vanquish
Post by vanquish » Wed Feb 03, 2021 2:00 pm
Hallo,
keymak :wink:
I had the same problem when trying to connect to VM using remote desktop. It seems that only network licenses work with remote desktop.
chaos363
Post by chaos363 » Wed Feb 03, 2021 2:55 pm
This is a known limitation with a single user license. The manufacturer requires a network license for this function, which I have not yet been able to build.
As a workaround, you could build a batch file, which EPLAN starts with a slight delay (e.g. 5 seconds). Interrupt the remote desktop connection when executing the batch. After 5 seconds have expired, reconnect the remote desktop and eplan can be started.
djcatalyst
Post by djcatalyst » Wed Feb 03, 2021 7:28 pm
chaos363
awesome work !!
now you're a famous dude :
https://rutracker.net/forum/viewtopic.php?t=6003232
:mrgreen:
redline147
Post by redline147 » Wed Feb 03, 2021 7:30 pm
Hi, I'm redline.
I would like to learn how I can license my own API application.
They could teach me.
In this link I show an example of the application.
https://youtu.be/juXqIELSp6c
In eplan 2.7 the api works, but now in 2.9 show me this message:
Imported toolbar action 'MEG-sql-bbdd-schneider-electric' is unregistered or unlicensed at this time.
I couldn't spend a lot of time trying to fix it. But if you can guide me, it would be of great help.
keymak
Post by keymak » Thu Feb 04, 2021 6:28 pm
Thanks to everyone for the tips.
I have now installed without VM and it works
best regards
keymak :wink: :wink:
chaos363
Post by chaos363 » Fri Feb 05, 2021 11:21 am
As information for everyone, I'm currently trying to optimize the activation and actively looking for errors. The keygen does not load template properly. Here he has problems with very long names, which has now been fixed. The license term is now also set to unlimited.
I have built a new template which should start the application directly (only 1 valid license), so no selection anymore. Modules are also all activated.
Next I try to find errors in calculation of hardware id.
cobra919
Post by cobra919 » Fri Feb 05, 2021 11:49 am
Chaos I want to thank you that worked straight away, thank you.
I have a few general security questions.
Can Eplan find out somehow that I have worked with a cracked version if I continue to send the Eplan files?
Does anyone know by chance whether Eplan does anything to detect cracked licenses when I send the Eplan P8 files?
I only need the version because I want to work from home. We have an original license at work.
djcatalyst
Post by djcatalyst » Fri Feb 05, 2021 3:59 pm
You're a savior (oo)
chaos363
Post by chaos363 » Fri Feb 05, 2021 8:07 pm
I've now tried to look at your problem, but I don't get to the point of testing it. To be able to help, you have to guide me with appropriate extensions and a (would be good) video of EPLAN 2.9. In general, I would recommend you to pack all modules into the license and just test whether it works.
But don't be surprised at start time of EPLAN, it has to evaluate this block of licenses first. If there are too many, eplan also runs into an error because the text document (lservrc) is too big.
Edit: try module "ABB Industrial IT Interface"
Short version:
Yes, there is definitely a possibility.
Long version:
I can't tell you exactly. Even if I debugged all applications, there are just too many ways to hide such information.
Imagine a file made up of x blocks, where block numbers 20 & 21 contain your license ID, which EPLAN calculates and writes into it. If this ID is not displayed anywhere, you cannot do anything with it in binary and believe in some sort of header garbage. But at the end of day EPLAN has a table in cloud where this id is checked. This description is of course fictitious.
I spontaneously think of the IDA pro program, which writes license information into files created.
At the moment I do not believe in such an implementation, as the newly implemented licensing system is quite extensive and "is secured" (lol .. :-)), among other things, by a private / public key. Since it is now apparently open, such an implementation could be submitted later. Here it mostly depends on the manufacturer's load limit, if economic damage becomes too great, measures are taken to prevent access or to deter people.
