It is currently Wed Jan 23, 2019 4:26 am
Post new topic Reply to topic  [ 2 posts ]
PostPosted: Sun Nov 04, 2018 5:59 pm
I installed EPLAN P8 1.9 and I can't open an "zw1" file. I can make a new project but I can't open a backup project with zw1 extension.
When I try to open I receive S332001 error " The function "Restore project" cannot be performed because of the settings defined in the rights management module" and error S336001 "Error running the command line action RstRestoreDialogShow /RESTORE: (the location of the file project.zw1) /Open:YES".
I try to open in beginner mode and in expert mode. The same result.
Please help me with an advice because I need to open the file to make a few modification and I won't to make the project from the beginning.
Thank you in advance!
PostPosted: Tue Nov 06, 2018 5:30 pm
do you open it or revert it ?
witch zw1 you must revert it
trey to change direktory of revert project
or sen the zw1 i will revert the project and comperes it to 7zip
Users browsing this forum: sbcwb and 6 guests
