It is currently Thu Jan 17, 2019 3:41 am
 Post subject: data portal
PostPosted: Fri Feb 09, 2018 11:42 pm
Hi dears, I've got a EPlan 2.7v (with crack) at Internet and it's work well, but I can't get material ou devices by data portal eplan .
Someone give tips how can I do it , please ?
 Post subject: Re: data portal
PostPosted: Sun Feb 25, 2018 2:15 pm
Dear Friend.
You should first read a little bit in the forum (sbutton) , because it is easy to find the answer to your question.
Without a legal copy of Eplan, including maintenance contract, there is no way to access Data Portal.
Searching a little bit more in the forum, there is a post where you can find a still version of the data portal as individual edz files to be imported. It is not comfortable, but it's the best you will get...
Good luck...
