It is currently Sat Apr 21, 2018 3:02 am
PostPosted: Sat Oct 14, 2017 4:56 am
Zuken E3 Series 2016 Version v17.00 | 3.5 GB
Zuken, a global provider of leading-edge software and consulting services for electrical and electronic design and manufacturing, announced a major new release of E3.series is a scalable, easy-to-learn system for the design of wiring and control systems, hydraulics and pneumatics.
The out-of-the-box solution includes schematic (for circuit and fluid diagrams), cable (for advanced electrical and fluid design), panel (for cabinet and panel layout), and formboard (for 1:1 wiring harness manufacturing drawings). Integrated with MCAD, E3.series is a complete design engineering solution from concept through physical realization and manufacturing output.
New Features 2016 Build 17.00:
Assemblies
– Assemblies Can Now be Displayed Independently as Folders within Tree View
Blocks
– Devices Can Now Be Assigned to Block Devices
– Enhancement to DeviceInterface for Creating and Returning Non-Block Connector Devices
– Models Can Now Be Assigned to Block Components in Database Editor
COM
– Enhancement to DeviceInterface for Returning and Setting the Reference Type of a Device
– Enhancement to PinInterface regarding the Return Values of SetColour, SetCrossSection, SetColourByDescription and – SetCrossSectionByDescription
– Enhancement to DeviceInterface for Generating New 2D View on Existing 2D View Sheet
– New Triggers ‘BeforeCreateStructureNode’ and ‘BeforeMoveStructureNode’
– Enhancement in TreeInterface for Getting and Setting Formboard Views
– Enhancement to ExternalDocumentInterface for Displaying Entire Original File Name with Path and Extension
– Enhancement to JobInterface for Enabling Options to Be Assigned to Several Objects
– New Trigger ‘BeforePaste’
– Enhancement to DeviceInterface for Returning Length of Mounting Rail
Connections/Buses
– Functionality ‘Auto Routing’
– New Settings Category ‘Auto Routing’
– Auto Route by Conductor/Wire
– Auto Route by Signal
– Connections / Buses – Misc
– Now Possible to Control whether All Conductors of Connection Net Shall Be Assigned to New Cable when Inserting Inline Connectors
Connectors
– Enhanced Functionality when Placing Inline Connectors at Connected Net Segments
Formboard
– Unused Formboard Views Can Now Be Hidden in Tree View
Graphics
– New Graphic and Symbol Graphic Type ‘Cloud’
– Enhancement to the GraphInterface for Generating and Recognizing Clouds
Multi-User
– Sheets No Longer Have to Be Checked Out/In to Be Edited by Other Users in Multi-User
Panel
– A Second Run Can Now Be Performed to Find a Suitable Connector Pin Terminal for the Automatic Routing
– All Unplaced Devices in a Folder in the ‘Panel – Not Placed’ Tree Can Now Be Placed All at Once
– Adjacent Models Can Now Be Moved Automatically to Close Gap between Them when Performing Certain Actions
Project
– Revision Marks Can Now Be Searched
References / Connection Targets
– Procedure Changed for Handling Connection Target Texts on Equivalent Pins
Terminals
– Terminal Table
– Displaying the Terminal Table
– Adding/Deleting Column
– Configuring the Terminal Table
– Global Search in the Terminal Table
– ‘Jump to’ Functionality in the Terminal Table
– Terminal Table Settings
– Adding Terminals to the Terminal Table
– Moving Terminals in the Terminal Table
– Placing Conductors in the Terminal Table
– Context Menu Commands in the Terminal Table
– Setting/Resetting the Preselection
– Terminals – Misc
– Terminals Can Now Be Sorted in Predefined Order in Terminal Strip
User Interface
– New Sheet Overview Window in Project Mode
– Generate New Sheet Overview / Open Sheet Overview Windows / Delete Sheet Overview Windows
– Configure Sheet Overview Properties
Variants / Options
– Elements without Assigned Variants/Options Can Now Be Hidden or Displayed in Another Color
– Extended Variant Information for Existing Variant Instances Can Now Be Displayed in Tree Views
– Type Can Now Also Be Displayed for Variant/Option Names
– New Variant States ‘Does not exist’ and ‘Only exists’
– New ‘Variant Overview’ Tab in Device Properties
Name: Zuken E3.series
Version: 2016 version 17.00
Interface: multilanguage
OS: Windows 7even / 8 / Server 2008/2012.
http://turbobit.net/wdfqbblfj7d9/Zuken. ... 0.rar.html
