It is currently Fri Dec 14, 2018 1:38 pm
PostPosted: Mon Oct 02, 2017 5:47 pm
Hello people....
I start to have problems with my Eplan 2.5 and i have to struggle again to install it in Windows 10.
So to you don't spend so much time like i did where the links and forms to install.
WIN 7 X64 Patch Instructions:
7: Reboot.
WIN 10 X64 Patch Instructions:
2: Copy the license file SN-U10066.EGF to folder C:\User\Public\Eplan\Common\
3: Turn off the antivirus software, turn off the UAC system, this isnot really necessary, but you need to allow the system/antivirus alerts.
4: Run as administrator HASPUserSetup.exe.
5: If you want you can run EPLAN 2.1-2.7 X64 crack.exe with administrator rights instead of following the next steps 6 and 7:
6: Add to registry EPLAN 2.7 1-2.reg and EPLAN 2.7 2-2.reg
7: Copy files on patch to C:\Eplan.
8: Start a command console with administrator rights and run.
9:Go to C:\Eplan
10: Type install
If you don't want to use the install.cmd just copy multikey.cat , multikey.inf , MultiKey.sys to C:\Windows\System32
And update the Driver of virtual usb in Device Manager.
11: Use the version.dll creator (You can find the instructions inside Version.Dll Creator Steps.Docx)
12: Copy version.dll to: C:\Program Files\EPLAN\Platform\2.7.3\Bin. Solve the lags problem.
13: Reboot.
LINK
https://mega.nz/#F!GU9RxQZb!xlkOjBdHrMoVEwiT70srmQ
PostPosted: Mon Oct 02, 2017 10:21 pm
The first thing you have to do is to say thank to Mr Sprudel1968 and Mr PDLFFALF (usearch) !
PostPosted: Tue Sep 04, 2018 8:56 am
Hi.
I have followed your instructions and successfully installed EPlan. However, I can't create a new project. I need to have a template to select in order to work on a project. What should I do?
