[LINK] Eplan P8 Professional 2.7 + Crack V2.1_2.7
Тools, Elcad, Eplan, ...
Alexandre_Onofre
Post by Alexandre_Onofre » Mon Oct 02, 2017 2:47 pm
Hello people....
I start to have problems with my Eplan 2.5 and i have to struggle again to install it in Windows 10.
So to you don't spend so much time like i did where the links and forms to install.
WIN 7 X64 Patch Instructions:
7: Reboot.
WIN 10 X64 Patch Instructions:
2: Copy the license file SN-U10066.EGF to folder C:\User\Public\Eplan\Common\
3: Turn off the antivirus software, turn off the UAC system, this isnot really necessary, but you need to allow the system/antivirus alerts.
4: Run as administrator HASPUserSetup.exe.
5: If you want you can run EPLAN 2.1-2.7 X64 crack.exe with administrator rights instead of following the next steps 6 and 7:
6: Add to registry EPLAN 2.7 1-2.reg and EPLAN 2.7 2-2.reg
7: Copy files on patch to C:\Eplan.
8: Start a command console with administrator rights and run.
9:Go to C:\Eplan
10: Type install
If you don't want to use the install.cmd just copy multikey.cat , multikey.inf , MultiKey.sys to C:\Windows\System32
And update the Driver of virtual usb in Device Manager.
11: Use the version.dll creator (You can find the instructions inside Version.Dll Creator Steps.Docx)
12: Copy version.dll to: C:\Program Files\EPLAN\Platform\2.7.3\Bin. Solve the lags problem.
13: Reboot.
LINK
https://mega.nz/#F!GU9RxQZb!xlkOjBdHrMoVEwiT70srmQ
van8x10
Re: [LINK] Eplan P8 Professional 2.7 + Crack V2.1_2.7
Post by van8x10 » Mon Oct 02, 2017 7:21 pm
The first thing you have to do is to say thank to Mr Sprudel1968 and Mr PDLFFALF (usearch) !
rafn97
Post by rafn97 » Tue Sep 04, 2018 5:56 am
Hi.
I have followed your instructions and successfully installed EPlan. However, I can't create a new project. I need to have a template to select in order to work on a project. What should I do?
adatum
Post by adatum » Mon Jan 28, 2019 7:07 pm
Hi all
Maybe someone can help with these issue
error screen
P.S. OS Win8.1 x64
michelkoers
Post by michelkoers » Sat Apr 06, 2019 5:42 pm
Hi.
I have the same problem. What should i do?
sd-electro
Post by sd-electro » Mon Apr 22, 2019 7:56 pm
I'm trying to install this version of E-Plan to my new portable that is running Win 10 Pro Build 1809.
I have followed the instructions to install the patch and virtual usb dongle but when i run eplan it keeps saying that the dongle or device driver is missing.
Can someone help me please?
Edit: I tried to install this on another pc running Windows 7 and there it works great. But i also like to run this software on my new pc in Windows 10...
Eli77e
Post by Eli77e » Sun May 05, 2019 2:24 pm
Hello everyone i`m also trying to run 2.7 on win 10. But there is driver problem witch is causing the doungle not to run. If somebody have the drivers for the multikey, please give a link.
Spoiler
EDIT: The fix is to isntall the latest driver from safenet website. Now works great.
PS. Does anyone have .EDZ files for the internal database ?
bizdah
Post by bizdah » Sat Jun 01, 2019 6:13 am
I have a problem.
I installed the program successfully. and all functions working properly.
but when I want to add cable definition/shield/phase busbar/connection definition point/potential definition point/potential connection point,
I receive an error
Unable to gain access to the project.
and in the system message:
The XEGActionInsertSymRef_internal action with the /fctdeftag:401.1.1 /_cmdline:XEGActionInsertSymRef_Cable /FctDefTag:401.1.1 parameters of the EGedLog module has failed.
Would you please explain me whats the problem?
Regards
GenderGeek
Post by GenderGeek » Mon Nov 25, 2019 7:38 am
You have an error in the project database. The FctDefLib.fdb file is corrupted. Replace.
omarhilal
Post by omarhilal » Wed Jan 15, 2020 2:11 pm
I installed it correctly and everything is fine, but the performance is not as good as v2.4 anyone knows why ? pls help :(
pruebaautis
Post by pruebaautis » Fri Jan 31, 2020 8:00 am
Please, anyone have all links of Eplan? Eplan pro panel, fluid, smart wiring...
