It is currently Fri Feb 23, 2018 9:15 am
PostPosted: Thu Aug 03, 2017 6:30 pm
Please,
Could someone explain how to place the same terminal in two different pages, without the terminal showing twice in the terminal diagram page
PostPosted: Sun Sep 03, 2017 3:09 pm
If really neccessary to represent 1 terminal on two pages with the same designation... then uncheck the main terminal function of the second one in property menu/terminal tab right clicked from the symbol.
If you need to use multi level or multi function terminal than modify the the designation or level.
PostPosted: Thu Sep 14, 2017 11:50 am
Thank you for your reply.
I have tested uncheck the main terminal function, but still the terminal shows up twice in the terminal strip report.
Its possible to do it without the terminal shows up twice?
PostPosted: Tue Nov 21, 2017 1:14 am
It doesn't matter if you put a terminal in more of one page, it will show just one page (if it fits in the page).
But in order to know what's going on, I would need more details. Eplan is quite powerful but in order to use the auto functions properly strict rules must be keeped all time.
