[LINK]: EPLAN ELECTRIC P8 V2.7
Re: [LINK]: EPLAN ELECTRIC P8 V2.7
Hi Sprudel 1968
It is difficult to download from turbobit, the first file is damaged.
There is a torrent
thank you
There is a torrent
thank you
Where could I upload the files?
What is missing here?
I do not have a paid connection with turbobit.
Download file is very slow 2 or 3 hours if everything is ok
The first file when unpack it from this error:
EPLAN_Electric_P8_2.7.zip.001: Unexpected end of the archive.
I downloaded this file already 2 times
any idea
any idea
No ideas. I extracted all files as you has seen above using free of charge access only.djto wrote:I do not have a paid connection with turbobit.
any idea
Rex2701 wrote:No ideas. I extracted all files as you has seen above using free of charge access only.djto wrote:I do not have a paid connection with turbobit.
any idea
When I try to extract files, with winrar says unexpected end of file
With winzip says the file is not a zip archive.
What do you use to extract files?
Join files (.001; .002; ...006) using hjsplit.exe (http://www.hjsplit.org/) first, then WinRar!djto wrote:Rex2701 wrote:No ideas. I extracted all files as you has seen above using free of charge access only.djto wrote:I do not have a paid connection with turbobit.
any idea
van8x10 wrote:Join files using hjsplit.exe (http://www.hjsplit.org/) first!djto wrote:Rex2701 wrote:No ideas. I extracted all files as you has seen above using free of charge access only.djto wrote:I do not have a paid connection with turbobit.
any idea
You will need to combine downloaded zip files (merge them) and then extract the single (merged) file. Best of the Total Commander.
Have to pack 7zip used
I decompressed the same files on another computer with windows 7 (64) and it worked with windows 10 (64) no
For the patch is the same version 2.6 or you have to wait?
Thank you all for your patience
Is apparently a new patch! I have not.
And where the key (license)???
I tried from 2.6, but does not work
For anyone that doesn't like turbobit
I leave you another link
https://mega.nz/#!gYszVJiY!Jc8_XvC7OUqV ... NfO79tgSDQ
viewtopic.php?f=7&t=25375oleksandr_ua wrote:And where the key (license)???![]()
this is a demo version or full release?
