It is currently Tue Apr 24, 2018 1:47 pm
PostPosted: Sat Mar 11, 2017 4:19 pm
I am having two diffirent eplan problems and i need your help.
Problem 1:
Why sometimes the connection line is blue and not red as the default option?
Problem 2:
When i assign parts for the terminal strips the result is the following. When i import the project in the phoenix contact clip project i am getting the following results. Why is this happening?
Does anyone know how to fix this ?
PostPosted: Wed Oct 25, 2017 11:43 am
Problem 1:
Blue line appears when you have defined or it is been defined the Connection point type as Direct connection point. Double click the symbol, go to Symbol / function data tab, Logic/ Connection point type and select Conductor/Wire
Users browsing this forum: No registered users and 9 guests
