Internal error Messages at opening and updating *zw1 backups
Тools, Elcad, Eplan, ...
Hypnos82
Post by Hypnos82 » Tue Oct 04, 2016 1:21 am
Hi Partners!
I'm having some troubles at opening my *zw1 back up projects with Eplan 2.4 (cracked)
My *zw1 were made on Eplan P8's plattforms' 1.8, 1.9 and 2.0 . However, when restoring and updating to 2.4 version, 2 of 3 projects sends me a pop-up with the message "An internal error ocurred" and my Eplan hangs and I have to restart it without the update task done.
(fback)
Is it an usual problem?
If so, How can I solve it? is there any hotfix?
If not, What should I do? Reinstall it? Change to 2.5 version? I can not downgrade right now because I started doing projects on 2.4 version, and - as you know - you can't open newer projects backwards versions.
All my projects had been saved in older versions...
(tyou)
