Page 3 of 4
Re: 2016-01-12 EPLAN 2.1 2.3 2.4 2.5 patch x64(Final versi
Posted: Wed Feb 24, 2016 2:41 pm
by andreasv
Pls Help.
i cannot decompress
SN29627.exe
its just Shows one file -
SN-U29627.EGF
I cannot install it right without the other files
like install.xml, SN-U29627.REG and so on
thx
Posted: Fri Mar 18, 2016 8:07 am
by chakotay
Who is the creator of version.dll ?
First I want to thank you for this patch/hook or whatever it is.
Two questions:
1. Can you tell us more about your solution? What is the issue with 2.5 ?
2. Is it possible to remove this link and the Chinese Popup window?
Cheers,
chakotay
Posted: Sun Mar 20, 2016 8:52 pm
by Bachir Khiati
used link :
Eplan 2.5.4 link +all the tools needed.:https://cloud.mail.ru/public/48mt/2iE4wGocb
crack :http://eplan-eb2.ys168.com/
i'm new here and i wanted to try EPlan cause i read about it all so i tried looked abit and i made worked finally, i had a problem with the multikey driver whatever i open eplan 2.5 it ask for activation
what i did was :
after the instalation go to file that you download it and install HASPUserSetup path for it is:"\Electric P8 2.5.4.9380\ELM\Services (x64)\Drivers\
then you need to use the command promp and go to the same directory (cd C:\your path\Electric P8 2.5.4.9380\ELM\Services (x64)\Drivers\" and execute this command
command :"haspdinst.exe -install"
then turn off digital signature Open the Command Prompt window by right click in the Start button, Command Prompt(Administrator)
2. On the Command Prompt type in the command :
bcdedit.exe -set loadoptions DDISABLE_INTEGRITY_CHECKS
bcdedit /set nointegritychecks ON
then install the multikey64 (crack folder the first link )
go to Device manager and check if the driver is installed and showing "Virual USB Multikey" skip this :
if you find "unknown Driver" then right click and select update then select manual install and point to Crack\release\multikey64 or 32 depend on what you have.
you will have a problem even with that cause you need to add a signature to the driver by using dseo13b.exe (in the crack folder first link)
Add a digital signature for the driver Multikey. To do this, select the "Sign a System File" and enter the file name, including the full path C:\Windows\System32\Drivers\multikey.sys
after that go to device manager and look for "Virual USB multikey" you will notice it have a yellow sign on it right click on it and disable it then turn it on again you will notice that the yellow sign is gone
after that apply the crack : http://eplan-eb2.ys168.com/
just copy the dll file in Bin and execute EPlane Crack....X64..exe
then even after that it didn't work -_- still ask for activation .
what i did was i went back to device manager and i noticed the yellow sign again i opened dseo13b.exe and repeated "sign a system file...... same path .
disabled the driver and activated again and the sign was gone went and tried to open Eplan 2.5.4 and it worked
no activation no lag no nothing.
hope it help you guys.
Posted: Wed Mar 23, 2016 7:02 pm
by Sprudel1968
F8 activate again to get into Safe Mode
Win + X Press
Prompt (administrator) launch.
bcdedit / set {default} bootmenupolicy legacy Enter, or copy and paste by right-clicking in cmd
Wait until the process is complete.
Restart and F8 function in Windows 10 again.
That was it. Now you have a boot menu with Windows 8 and the safe mode.
Start Now computer without driver signing
Posted: Thu Apr 14, 2016 12:32 am
by George SM
Dear colleagues!
does anybody have detailed instruction + archive with "tools" for activation ePlan P8 2.4 Electric.
I had tried to do this by different instructions and by different "tools" which I could download.
I tried to do it at:
1. Windows 8.1 German version
2. Windows 7 Ultimate Russian version (this Windows is installed in VM Parallels on macbook)
Everywhere instructions are different! Recommendations by users are different.
I am confused! (h)
After all actions made by instruction I got this result:
What I do wrong?
Windows 8.1
Why when I start install.cmd I get answer "devcon failed" ? What is wrong here?
Posted: Mon Apr 18, 2016 4:25 am
by chakotay
Forget Devcon.
If you're using Win7 get this Tool: http://depositfiles.com/files/jzts8axpq
If you're above,
Cheers
Posted: Fri Apr 22, 2016 12:13 pm
by dambre77
dambre77 wrote:New file version.dll work fine with eplan P8 version 2.4 and 2.5 but the lag is present when i work with eplan enhanced version 5.
Anyone have this problem?
It is possibile have a new file version.dll that work also this version?
Thank's a lot for response.
Aanyone has information on this topic?
Bye
Posted: Wed May 04, 2016 4:02 pm
by Burned Electrician
I noticed that the patch was renewed. Could anyone tell me how to apply? Because the instructions is in Chinese.
Posted: Fri May 06, 2016 2:23 pm
I tried something but it didn't work out. The problem remains the same.
Posted: Wed May 11, 2016 6:33 am
by ewil_qido
Hi.. There is my guide how instal Eplan P8 2.5 on W10. Its translated in Google translator so sorry for english (suc)
Instructions for commissioning Eplan 2.5 for Windows 10 (rr)
1. Disconnect your Internet connection
2. Install Eplan
3. Switch off UAC - (not necessary)
a. Search "UAC" (User Account Control settings)
b. Slider all the way down.
c. OK
4. Run Test mode
a. Run Command Prompt as administrator
b. Enter - "bcdedit.exe -set TESTSIGNING ON"
- With the message "The operation completed successfully.
5. Disable the driver signing enforcement
a. Settings -> Update and Security -> Restore -> Restart
b. Troubleshoot -> Advanced Options -> Startup Settings -> Restart
- A menu with nine options, all represented by its own function key
c. Push F7 (Disable driver signature enforcement)
6. Install Crack
a. From the "15.01.2016 EPLAN 2.1 2.3 2.4 2.5 X64 crack" to start EPLAN ??? 2.1 2.3 2.4 2.5 X64 crack.exe (instead of the 3 ??? scribbles)
- Will see red window
b. select "Install"
7. Install HASPUserSetup.exe http://sentinelcustomer.safenet-inc.com ... =all&t=all
8. copy the file "version.dll" from the "EPLAN 15/01/2016 2.1 2.3 2.4 2.5 X64 crack / EPLAN Electric P8 2.5 60 ?????" in C: \ Program Files \ EPLAN \ Platform \ 2.5.4 \ Bin
9. Restart
10. Enable Internet Connection
11. Run Eplan and enjoying Artistic cycling (if you have installed 64-bit MS Office)
Posted: Wed May 18, 2016 7:59 pm
by dambre77
The new version of file version.dll into the zip archive with date 2016-04-29 disable disables opening of the web page but the software eplan show up again the lags.
someone else to control this thing?
Thak's
Bye
Posted: Mon May 23, 2016 5:00 pm
by ioannistsi
I didnt understand....did the lagging stopped???
I have 2.4 version, i also tested the 2.5....but the same...!
Is there any solution for the lang to stop?
Posted: Tue May 24, 2016 9:17 pm
by Buxexas
Hello friends, (pgood)
I just finished the installation of EPLAN Electric P8 2.5.4.9380 on Windows 10 64Bits !
The Eplan works great but the lag continues.... Any solution ???
I install the crack "version.dll" (2016-4-12 EPLAN Electric P8 2.5 60)....
Thanks Bachir Khiati and ewil_qido for your posts!
Regards,
Posted: Sat May 28, 2016 3:56 pm
by krepac
Here is available a new addition to latest medicine for Eplan:
http://eplan-eb2.ys168.com/zy/b_old/not ... %B6%A1.rar
Can anybody explain what is it for, as well is there a fully functional receipt for using a medicine for Eplan Pro Panel 2.5 under Windows 10?
Posted: Sun May 29, 2016 8:52 am
by ioannistsi
It isn't working....when i click the link it only show somethin on Chinese!
Posted: Sun May 29, 2016 9:18 am
by krepac
In archive is what I used to crack Pro Panel 2.5 (medicine, description working HASP) under Windows 10 x64.
As well you have a snap of Eplan Panel Pro.
http://www65.zippyshare.com/v/hdj3waHp/file.html
http://www65.zippyshare.com/v/XiiwOAC0/file.html
Posted: Sat Jun 04, 2016 4:28 pm
by ioannistsi
How does it work????
Posted: Sat Jun 04, 2016 5:24 pm
by krepac
I'm not sure is it fully functional (lack of experience). Why don't you download snap? I have problem with part database, EPLAN denies that I'm using Office x64 (I'm getting "microsoft office 64 bits is required for 64-bit version of the eplan platform" when it tries to open ESS_part001). Can anybody help with this?
Posted: Sat Jun 04, 2016 9:36 pm
by ioannistsi
Just install windows office x64
Posted: Sun Jun 05, 2016 6:35 am
by krepac
You misunderstood me, I have it installed, Eplan just denies it.
Posted: Sun Jun 05, 2016 1:10 pm
by djto
I have the same problem
Posted: Sun Jun 05, 2016 4:39 pm
by ioannistsi
Sorry i didnt understand.I had the same problem at first but i installed Microsoft Office Professional 2013 Plus and it works perfect
Posted: Sun Jun 05, 2016 5:04 pm
by krepac
In a meantime I was experimenting with it and made a mess. Does anybody know how to re-install Eplan?
I tried without success, during installation it says that some files are missing (.cab , .lic or something alike).
Does anybody know how to remove traces of previous successful installation?
Posted: Sun Jun 05, 2016 5:35 pm
by ioannistsi
Why dont you restore your system to a past date that worked?
Posted: Sun Jun 05, 2016 5:46 pm
by krepac
System works, Eplan is removed as well as HASP and related files but it doesn't help.
I cant restore it because in a meantime I made some significant changes within.
Posted: Sun Jun 05, 2016 10:13 pm
by ioannistsi
Be sure that when you install Eplan check all of the installations at "customized installation" because you might have not uninstalled Licence Client before and the missing files are from this exe and not Eplan! So if the installation "see" that you already have Licence client it doesn't installs the exe but the missing files remains missing
Posted: Mon Jun 06, 2016 8:15 am
by krepac
OK, after I removed Eplan's tail from C disc, HASP and crack which I supposed was visible in device manager (USBkey - something alike) I succeed to install it back - but only from the desktop?! While it was located on the other partition I couldn't do it, how that's possible dunno. Still there is a problem with recognizing Office 2016 x64 as 64-bit program.
Did anybody succeed to resolve this problem?
Posted: Tue Jun 07, 2016 11:23 am
by Lyzhy
djto wrote:I have the same problem
Install MS Access x64
Posted: Wed Jun 08, 2016 9:11 pm
by krepac
I replaced old version of Office 2016 x64 with Office 2016 16.0.4229.1006 Pro Plus x64 (before that I removed Eplan and all its tails), after what I installed Eplain again. Now it's not complaining. Is it fully functional I don't know.
P.S. To anybody who's using cracked software I warmly advise to install NetLimiter Enterprise v4.0.13.0 by DVT (this version is cracked by DVT and works definitely, don't experiment with others) at the first place, so you could block all applications trying to reach anything on internet.
Posted: Thu Jun 09, 2016 11:58 pm
by filipecv
For those having problems with MS Office 2016 x64 just need to go to microsoft https://www.microsoft.com/en-us/downloa ... x?id=13255 choose download and instal AccessDatabaseEngine_x64.exe
This is a known problem from EPLAN and it will be fixed on version 2.6 arriving on 08/2016.
Posted: Fri Jun 10, 2016 4:51 am
by krepac
Thanks, somehow this problem with Office disappeared after I re-install latest cracked version.
Posted: Sat Jun 11, 2016 8:59 am
by ioannistsi
OK with the Office.
What about the crack with the spikes?
Will it ever be corrected???
Posted: Sat Jun 11, 2016 10:01 am
by krepac
Spikes? I'm not sure is it fully functional, it's loading without problems at least. I did some elementary things successfully, I'm still beginner so I can't judge it.
Posted: Mon Jun 13, 2016 2:30 pm
by aliuta2000
hello,
I have instaled Eplan 2.5, it run fine for a while, and i did not use-it aboutone month.
Now it ask validation code.i have tried to put again the crack , but nothing new , it is still asking validation code
Image.
can somebody help me to fix this issue ?
It was running about one month with no problem.
Thank you in advance for help me to solve the issue
http://imgur.com/a/qPulb
Posted: Wed Jun 15, 2016 4:20 am
by ioannistsi
Maybe you are using he crack which is valid for one month only. I am using it myself because it is the only one which is not causes these "spikes"!
Try changing your date a month behind, maybe that fixes the problem
Posted: Thu Jun 16, 2016 1:23 pm
by Lyzhy
I installed EPLAN 2.4 and key from eplan 2.5. Everything worked fine, no freezes. Then I installed eplan 2.5. At the start eplan 2.4 and 2.5 become long to load. Then I reinstalled LicenseManager from version 2.4, and EPLAN start faster, but for version 2.5 it is not compatible. Apparently in new version of LicenseManager changed key verification, which is why there so long starts and freezes.
Posted: Thu Jun 16, 2016 1:40 pm
by ioannistsi
I have done the same but the crack will expire in one month time!!!!
The 2.5 crack lasted for ever but had problems during the use of the programm....(it stuck often)
Re: EPLAN P8 2.5 CRACK
Posted: Thu Jun 23, 2016 2:48 pm
by auto_keygen
Rasputingue wrote:It seems they found or might find a solution here: http://tieba.baidu.com/p/4081673932
A guy says (google translated) "The reason is that the software detects the card dongle drivers drive to upgrade my connection always has been reported there is no way to share"
and three replies ask them for the solution by email.
If by any chance someone here knows Chinese better than google translator maybe he give us a hand here.
我的连接总被举报实在没办法分享了 = having nothing to do with the lag about EP8
卡的原因就是软件检测加密狗驱动了升级驱动即可 = (read) the software detects the dongle drivers so that the ep8 lags,all you need to do is upgrate the driver of usb dongle
(suc) electrical engineer from China
Posted: Sat Jun 25, 2016 12:23 am
by ioannistsi
Rasputingue wrote:all you need to do is upgrate the driver of usb dongle
How this can be done?
Any directions?
Posted: Fri Jul 15, 2016 7:52 am
by Yogesh_shelar
antoan wrote:1. NET OFF
2. Install Eplan
3. UAC OFF + (WINDOWS TEST MODE)
4. HASPUserSetup install.
5. Install multikey + copy SN-U29627.EGF C:\Users\Public\EPLAN\Common\ + add reg database: *.reg
6. Copy version.dll C:\Program Files\EPLAN\Platform\2.5.4\Bin\
I don't understand the step 5 - i.e. how to add reg database: *.reg
Posted: Fri Sep 02, 2016 9:03 am
by VBdg458
All above installation instructions are incorrect.
Let's see what it is and how to use it
What it is all about
Starting from Vista/Windows 7 all drivers must have verified by Microsoft digitally signed signature/certificate. This verification is checked twice: when driver is installed and when driver is loaded.
To test drivers in development when still not verified by Microsoft, drivers must have self-verified signature and windows provide two means to test:
1. Boot session with Driver Signature Enforcement disabled in odrder to install driver without signature check.
2. Test Mode. Driver will be loaded without sertificate check.
Boot session with Driver Signature Enforcement disabled should be set manually by:
Win + X > Shut down + Shift > Troubleshoot > Advanced options > Restart > Startup Settings - F7 (Disable driver signature enforcement) > Reboot to Desktop
Win + R > shutdown /r /o > OK > Troubleshoot > Advanced options > Restart > Startup Settings - F7 (Disable driver signature enforcement) > Reboot to Desktop
Command:
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
is deprecated and does not function. There will be Unknown Device in Device Manager and when trying to update there will be error: "The third party INF does not contain digital signature information." which means Driver Signature Enforcement wasn't disabled and driver will not be loaded as it is not installed properly (installation signature check failed).
Command:
bcdedit /set nointegritychecks on
does not function as it requires Secure Boot disabled in BIOS which is not recommended.
Test Mode can be set by cmd commands.
Run cmd as administrator:
Win + X > A
Test Mode On
bcdedit /set testsigning on
Test Mode Off
bcdedit /set testsigning off
Restart
shutdown /r
How to install MultiKey driver.
Do not run install.cmd, no right/left mouse clicks etc. there will be devcon command error.
Install of MultiKey driver by:
1. Set Boot session with Driver Signature Enforcement disabled
2. Open folder where install.cmd is placed and go to:
File Explorer > File menu > Open command prompt > Open command prompt as administrator > install.cmd > Enter
C:\...\MultiKey\64>install.cmd
No devices were removed.
Device node created. Install is complete when drivers are installed...
Updating drivers for root\multikey from C:\...\MultiKey\64\multikey.inf.
Drivers installed successfully.
Press any key to continue . . .
Check driver installation in Device Manager.
Win + X > M > Device Manager > System devices > Virtual USB MultiKey
Device status (in Test Mode + Boot Session Disable Driver signature enforsment)
This device is working properly.
Device status (in Test Mode)
Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
MultiKey driver is installed properly and can be loaded in Test Mode.
Note: MultiKey driver has self-verified signature and use of Driver Signature Enforcement Overrider (DSEO) tool is not needed.
How to use to install EPLAN
1. Disable Internet connection/antivirus/firewall.
2. Disable UAC (option).
3. Install EPLAN.
4. Set Test Mode.
Win + X > A
5. Set Boot session with Driver Signature Enforcement disabled:
6. Install Sentinel Runtime Environment (...\ELM\Services(x64)\Drivers\HASPUserSetup.exe).
7. Install MultiKey.
File Explorer > ...\MultiKey\64\
8. Set EPLAN License:
Copy SN-U10066.EGF to: C:\Users\Public\EPLAN\Common\
Add SN-U10066.reg to registry: SN-U10066.reg > Right-click > Merge
9. Restart.
10. Enable UAC (option).
11. Enable antivirus/firewall.
12. Run EPLAN in Test Mode.
Posted: Thu Sep 08, 2016 7:18 am
by dambre77
With the last update released by Microsoft for OS Windows 10 the Version.dll file not work well and qhen i launch eplan the process is started but the program not open.
If i delete version.dll copied in path C:\Program Files\EPLAN\Platform\2.5.4\Bin\ the eplan starts but the work is impossible because it still lags.
Please Help me!
Posted: Wed Sep 14, 2016 6:20 am
by juanmemo
The web ask for a password!! :shock:
Edit: And now the crack dissapeared... :(
Posted: Mon Sep 19, 2016 7:09 am
by aliuta2000
hello ,
It is possible to get some running files for crack ?
the chinese site is not running / or show the files .
Thank you in advance for .
Posted: Tue Oct 11, 2016 11:22 pm
by fredy_pirineos
Hi there,
I am trying to install the Eplan Electric P8 2.4.4.8366 with the patch for Eplan Electric and license SN-U10066.EGF but after do all steps and try to run the software, the license manager told me that the dongle is not working fine.
I am try to download the Final version from the Vietnamise website but I don't understand anything.
Any idea?
Thank you so much!!
Posted: Thu Dec 01, 2016 10:55 am
by lolcraft
What is the latest version of EPLAN Electric unanimously working with no problems on Windows 10? I don't mind if it's 2.2, 2.3, 2.4 etc, worst case 2.0. Everyone is complaining about something, especially with 2.5, I just want to install a decent version with no lags, no "Test mode" or other nasty things every time I turn the computer on and need to work with EPLAN.
Can you provide with links and instructions?
Posted: Tue Jun 27, 2017 7:47 am
by juanmemo
Link broken again... :(
Posted: Thu Jul 27, 2017 1:20 pm
by theoulis7
hello guys , maybe its not the right place to post , but i am trying to download the eplan P8 v2.4 and i cannot find the link. i have searched the entire forum so far but i cannot find it . if anyone can help by providing it... thanks in advance
Posted: Tue Aug 01, 2017 7:50 am
by Bogilali
https://rutracker.org/forum/viewtopic.php?t=5370583 Win10 X64
works well. But a new USB key is needed. You can download it here:
ftp://ftp.cis-app.com/pub/hasp/Sentinel ... _setup.zip
Patch occurs in the manner described previously.
Posted: Sun Oct 06, 2019 9:33 am
by JosepMedina
(oo) Thank you very much, is works also for version 2.7.
Now for me, it is possible to open the parts and make a new part but still have one problem, the system say "A problem occurred while opening the project manager database ES_part001.mdb" do you know how to solve this problem.
