automation studio 6.0 x64 professional edition
Тools, Elcad, Eplan, ...
zozonon
Post by zozonon » Sat Nov 22, 2014 1:58 pm
i have an automation studio 6.0 x64 professional edition install file.
but, i couldn't find the crack file.
please help me....
fragolan
Re: automation studio 6.0 x64 professional edition
Post by fragolan » Wed Oct 07, 2015 8:07 am
Hi there,
could you post some download link for instalation. There is no crack for the software curently, but I have team which could try to make working version
Torteski
Post by Torteski » Tue Oct 13, 2015 9:05 pm
Version 6 https://torrentz.eu/8ef7c0cf148e0c335d0 ... f01f66fc33
Version 6.1 x32 http://www.jheberg.net/captcha/pas32izfte61020030/
Version 6.1 x64 http://www.jheberg.net/captcha/pas64izfte61020030/
The first one has some "Crack" but directional valves do not work (software crashes when you try to use it). And Directional controll is 95% of the use for the software. I searched the web for a long time and I am pretty sure there is no working crack for this software. If you make one a lot of people would be very grateful.
There is a working 5.6 student version.
Write if you need any more links, information or any type of help.
engmann18
Post by engmann18 » Fri Dec 11, 2015 8:23 pm
the crack for version 6 is ok but direction valve dont work. what you have to do is to download the library of version 5.2 and open it in the library of version 6 and you can get all the valve from there which work correctly
zolanzs
Post by zolanzs » Tue Jul 03, 2018 1:21 pm
V6 doesn't have Libraries folder, what files do I need to replace ?
I tried replacing just Main.xml and i see all the valves but can't change them...
TheoPap
Post by TheoPap » Tue Jul 03, 2018 5:37 pm
Try this solution for not working components. Watch the video from 05:22 minute (it's in Spanish but it doesn't matter), download the files for hydraulic,pneumatic,servo components .prx (links are below the video) and do what exactly show. For me it works.
https://www.youtube.com/watch?v=5E-7NFf5NkA&t=165s
Maybe this help you too (but you need the .prx files (link to download below the video)
Solution for not working components (directional valves & servovalves)
Open A.S -> In Library Explorer hit New Library (give a name) -> New category (give a name) -> Open a new project with standard documents and open the folder with working components -> After open select them all and drag and drop in the Library Explorer empty window under defined category name -> Do the same for all working components files -> Last hit Save Library and save them in Catalogues And Libraries as *.prl* files (C:\ProgramData\Famic Technologies\Automation Studio\6.0\Catalogues and Libraries)
zolanzs
Post by zolanzs » Mon Jul 09, 2018 1:29 pm
Thanks ! (pgood)
Just one more thing, I created and saved *.prl* files but each time I exit Automation Studio and start it again it automatically loads only Main library, and can't load previously created library.
TheoPap
Post by TheoPap » Mon Jul 09, 2018 3:45 pm
For me it's work and every time i re-open A.S.6.0. the main and the new created library for working components loaded. Follow the steps as described above and in the video and i hope you solve your problem. Save it in the correct path (C:\ProgramData\Famic Technologies\Automation Studio\6.0\Catalogues and Libraries) and rename it as .prl.
zdcbetter
Post by zdcbetter » Mon Jul 23, 2018 2:24 am
Could you tell me the files for hydraulic,pneumatic,servo components .prx download links? thx
whalua
Post by whalua » Tue Jul 24, 2018 3:41 pm
It also happens to me that the created library is not automatically reopened when I relaunch the automation studio.
Also if I try to change the characteristics of a component recovered from the library (for example a 3/2 valve) using the builder, when I try to apply the changes a window appears that tells me that the component is unknown or invalid
pakasi
Post by pakasi » Tue Oct 01, 2019 9:57 am
The patch was not programmed well, that is the problem why Directional Valve not appear, if someone wanna try (assumed already patched), look for file named AteHydrcmp.cmp at Automation Studio directory and cut/paste it to anywhere then rename the AteHydrcmp.cmp.BAK (this is the original file) to AteHydrcmp.cmp. unfortunately due to unmatched license between the software and the library it will read as unknown component and make every directional valve symbol as a same symbol. i have been looking for software that could read .cmp file but i not sure i can rewrite it because this is the first time i heard about .cmp, the software name is HotDocs or just google it.
Mpkprabhu
Post by Mpkprabhu » Fri Apr 03, 2020 9:11 am
In website library files link are not available .if anybody have the library files of hydraulic, pneumatic.please upload in Google drive and share the link of the file .please help me
vectoroung
Post by vectoroung » Mon May 11, 2020 4:38 pm
please help to share link all brother.
muftah7676
Post by muftah7676 » Fri Dec 18, 2020 7:03 pm
hi all
Solved problem Directional valves Automation Studio 6
https://www.youtube.com/watch?v=BCz0O-usPps
AUTOMATION STUDIO P6 REPAIR VALVES AND VALVE SPOOL DESIGNER ALL IN ONE
Please anyone have original CD send it to me
automation studio P6.0 OR 5.7 Professional Edition
thanks for all
ibmacer
Post by ibmacer » Tue Mar 23, 2021 2:56 am
kip_88
Post by kip_88 » Sat May 22, 2021 2:01 pm
Иранцы выложили версию 7.0 на сайте downloadly.ir, только забыли написать что пилюля платная :)
andreyit
Post by andreyit » Sun May 23, 2021 3:51 pm
У них же и 6.4 лежит бесплатно, но только x32.
kip_88
Post by kip_88 » Tue May 25, 2021 1:49 pm
7-я версия тоже бесплатно скачивается, цирк начинается при первом запуске )
andreyit
Post by andreyit » Tue May 25, 2021 4:04 pm
Нз. Скачал когда еще отдельно была ссылка на кряк для 6.4. И норм встал. Каталогов\библиотек нет производителей, конечно...
muftah7676
Post by muftah7676 » Mon Aug 02, 2021 10:08 pm
muftah7676
Post by muftah7676 » Mon Sep 20, 2021 3:08 pm
muftah7676
Post by muftah7676 » Wed Feb 23, 2022 10:19 pm
:D :D :D :D :D :D :D :D :D
(pgood) (pgood) (pgood) (pgood)
automation studio p7.0
https://mega.nz/file/4E0wxLiS#aG4_tnDZ6 ... hDR3UqvWFE
Teachware Exercises Catalouge
kostinps
Post by kostinps » Tue Jul 05, 2022 12:48 pm
Hello again Muftah76. share please again libraries
links is dead
csiszek
Post by csiszek » Wed Jul 05, 2023 5:29 pm
nickzamora907
Automation Studio P6.4 (Error while Start-up)
Post by nickzamora907 » Sat Jan 27, 2024 6:32 am
Hi Guys, can I have your spare time. I'm having trouble on running the Automation Studio.
Please, do you have any ideas or experience encountering these one? Thank you..
BTW Here are some of the Images:
Object Reference not to set to an instance of an object:
https://drive.google.com/file/d/1UbBqa_ ... sp=sharing
System Null Reference:
https://drive.google.com/file/d/1jCLWOT ... sp=sharing
csiszek
Re: Automation Studio P6.4 (Error while Start-up)
Post by csiszek » Sun Jan 28, 2024 8:34 am
hello
i did not remember having any problems like on you photos
try 7.0
TheNightshade
Post by TheNightshade » Wed Apr 10, 2024 2:29 pm
Can someone please reupload the P7.0 crack because mega has taken it down? I will be able to upload all P8.0 files I will get from school in exchange. Thank you so much all!
