It is currently Fri Jan 18, 2019 12:26 am
Post new topic Reply to topic  [ 17 posts ]
PostPosted: Sun Sep 21, 2014 1:52 pm
EPLAN P8 2.4 patch Windows x32x64
http://eplan-eb2.ys168.com/
PostPosted: Sun Sep 21, 2014 4:13 pm
Great! Thanks!
PostPosted: Mon Sep 22, 2014 9:57 pm
thank you (clap)
PostPosted: Tue Sep 23, 2014 1:37 pm
Great job!
This EGF file includes all the add-ons.
PostPosted: Wed Sep 24, 2014 9:17 pm
Is this 1 months time limitation?
PostPosted: Sat Sep 27, 2014 9:28 pm
Does anybody has a dng file to eplan 2.4?
PostPosted: Tue Sep 30, 2014 3:11 pm
Did you try to change date to November? I think it's not working after 1 months.
PostPosted: Tue Sep 30, 2014 3:50 pm
When you reach the closing date, you should remove SN-U10066.EGF and put the original downloaded, for one month more. :wink:
PostPosted: Tue Sep 30, 2014 9:51 pm
Finally, I've installed successfully the Electric P8 and Pro Panel v2.4 x64! (clap)
Tip of the day : :lol: You need install Microsoft Access 2013 (64 bit) of re-install Microsoft Office 64 bit first!
PostPosted: Tue Dec 02, 2014 6:35 pm
Can someone be more specific about installation. I read text from HASP Emulator for Eplan P8 Windows x64.txt
then I :
1) Copied SN-U10066.EGF into c:\user\public\eplan\common\
2) UAC set to minimum
3) started HASPUserSetup.exe and finished
4) started 10066.reg and changed register
When I started Eplan, got a message "The program 'EPLAN' cannot be started with this license."
Please, help...
PostPosted: Fri Jan 30, 2015 10:40 am
Eplan X64 patch files doesn't work if PC time is set in 2015. I think that, the evaluation time is over. Any body have new SN-U10066.EFF files which is working in 2015.
PostPosted: Fri Jan 30, 2015 4:34 pm
No problems for me, just delete the file SN-U10066.EGF (C: \ User \ Public \ EPLAN \ Common \) and replace the original one supplied with the crack. I do that one time by month and everything is ok. last time on 07/01/2015. (pgood)
PostPosted: Sat Feb 07, 2015 12:53 pm
Dear plcers,
I am new at this forum and writing this first post asking you some help about installing the patch for the Eplan 2.4.
I am running win 7 64bit pc. I made the installation for EPlan 2.4 and then I tried to install the patch.
My problem was that I could not find the installation of HL Hasp in order to uninstall it. When I am trying to
install the HASPUserSetup.exe it pop ups a message that a newer version is already installed.
Thank you in advance all plaers!!
PostPosted: Sun Mar 15, 2015 12:23 am
Hi there,
Would you be kind to tell us how did u get it?
It would be very appreciated!
PostPosted: Tue May 05, 2015 12:04 pm
Good morning ;
I am not able to activate Eplan . The steps I follow are:
1) Copied SN- U10066.EGF into c: \ user \ public \ eplan \ common \
2) Nose UAC program exactly what to do
3) HASPUserSetup.exe started and finished (This step gives me failure , because it says that the program is old )
Please you can clarify me the steps a little more detail .
Thank you.
PostPosted: Mon Jun 22, 2015 7:53 pm
Does anyone tried the data portal if it is working ? can you download a component to your design ?
PostPosted: Thu Jul 02, 2015 1:47 am
https://tvzil.us/?m=bbs&bid=torrent_uti ... uid=187429
The installation instructions are 32-bit only.
