It's a old version .... can anyone help me ?
Thank-you in advance foe your HELP
Where i can find EPLAN 5.75 + Crack
dekor
Umbi
Re: Where i can find EPLAN 5.75 + Crack
Thank-you for your HELP
... It's cracked or I must find a Crack ? At the moment I use 5.5 and don't have a possibility to make a separate database ..... I hope 5.7 yes
dekor
You dont need a crack.
Just folow instuctions from text.
Umbi
OK ... I have try to execute .exe file but not install .... what I can do to install ? If I launch file EPL6000.EXE or eplX01.EXE I have a warning : Impossible find a specified file
dekor
is solved your problem?
Tell us what windows do you use?
I use XP an is working fine.
dekor
dekor
Umbi
Windows 7 64 bit .... Eplan 5.5 running
