[LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID & PPE v2.3
Тools, Elcad, Eplan, ...
sadefa
Post by sadefa » Wed Aug 21, 2013 9:10 pm
Hello 2 all
today I have the new EPLAN v2.3
Enjoy ;)
EPLAN ELECTRIC P8 2.3
DESCRIPTION
links turbobit
EPLAN P8 PRO PANEL 2.3
DESCRIPTION
Complete consistency
Manifold possibilities
Added value at a glance
Product videos
System requirements
links turbobit.net
EPLAN P8 FLUID 2.3
DESCRIPTION
turbobit.net
EPLAN P8 PPE 2.3
DESCRIPTION
links turbobit.net
Eplan EEC One 2.3
DESCRIPTION
With the EPLAN Engineering Center (EEC), EPLAN offers its customers a tool that is designed to operate across disciplines: the consistent solution enables mechatronic configuration and automated documentation for sales, engineering and production. This means a reduction in time and cost in engineering as well as optimised documentation quality. Prerequisite for configuration is breaking down the production portfolio in a modular system with mechatronic functional units. By mechatronics in configuration, EPLAN understands both the paradigm as well as the specific technology: the interdisciplinary interaction of all disciplines in the EEC corresponds to the consistent workflow of modern product development processes.
links turbobit
Eplan EEC One 2.3 HF1
DESCRIPTION
links turbobit
Eplan Harness ProD 2.3 SP1
DESCRIPTION
EPLAN Harness proD is a modern 3D software system for the efficient design and documentation of cable harnesses. The system's strengths lie in the automated steps involved, from importing the wiring lists from the EPLAN Platform to routing the cables and generating the documentation and 2D nail board drawings. The ability to take over mechanically relevant information from various MCAD systems and the ECAD connection information means that EPLAN Harness proD has the potential to be seamlessly integrated into PDM environments. This allows for the design of the cable harness even when there is no mechanical prototype available. In brief: development times are reduced, productivity increases and project quality is improved on a continuous basis.
links turbobit
Oldman
Re: [LINK]: EPLAN ELECTRIC P8 & PRO PANEL & FLUID & PPE v2.3
Post by Oldman » Thu Aug 22, 2013 5:51 am
what's new in the release
ck1234
Post by ck1234 » Thu Aug 22, 2013 10:03 am
Something is wrong with Pro Panel part 11.rar can you check if you can extract your files? If yes please reupload part 11. Thank you
sadefa
Post by sadefa » Fri Aug 23, 2013 11:08 pm
ck1234 wrote:Something is wrong with Pro Panel part 11.rar can you check if you can extract your files? If yes please reupload part 11. Thank you
the link will be updated tomorrow
ck1234
Post by ck1234 » Sat Aug 24, 2013 11:50 am
Did you get this version running? The Crack from version 2.2 seems not to work Win 7 x64.
If yours work which operation system you use?
PDLFFALF
Post by PDLFFALF » Sat Aug 24, 2013 1:30 pm
Boxy
Post by Boxy » Tue Aug 27, 2013 12:02 am
thanks for the upload,
but one question, does some one have it on uploaded.to?
EJansen
Post by EJansen » Tue Aug 27, 2013 8:32 am
PDLFFALF wrote:CRACK:
http://eplan-eb2.ys168.com/
When installing the license as per version 2.1 and 2.2, and applying the key from above, Eplan 2.3 returns with the following message
"A suitable dongle is not available for the validation."
Any solution? 8)
van8x10
Post by van8x10 » Thu Aug 29, 2013 3:38 am
The file SN-U10066.EGF you posted only has license for EPlan Electric, but not for Fluid and PPE. So can You Please add more licenses for them? Thank You very much!
autoguru50
Post by autoguru50 » Thu Aug 29, 2013 5:42 pm
The license will stop after 30 days. If I change the actual date one month forward, EPLAN 2.3 will not start again. Does anyone have an idea? I used the suggested U10066.EGF file for version 2.3
Good ideas are very welcome
THANKS
titus95
Post by titus95 » Thu Aug 29, 2013 10:00 pm
It already did with version 2.2. Just delete the file SN-U10066.EGF and put the downloaded (I keep one copy in the same directory that I just copy and rename). It must be adjusted by first eplan launching.
autoguru50
Post by autoguru50 » Fri Aug 30, 2013 2:17 pm
Thanks for the quick response. It seems that this is a practicable workaround - THANK YOU FOR YOUR POST
(tyou)
arachnanthe
Post by arachnanthe » Mon Sep 02, 2013 2:44 pm
Is there torrent link?
es3535
Post by es3535 » Thu Sep 05, 2013 8:41 am
Same problem.
Win7 x64
Help pls with solution.
sventek
Post by sventek » Sun Sep 08, 2013 2:45 pm
Same problem with Win8 x64
Anyone out there, who could fix this problem?
leocdms
Post by leocdms » Tue Sep 10, 2013 8:22 pm
Hi ! Sorry bodering you all guy but I'm having a lot of trouble with Eplan electric p8 2.3. I'm new to it and have no idea how to valadate it. I saw sadefa left a video but its for eplan 2.1. now i'm confused.
I saw there's a chinese web site with the crack for eplan 2.3 but its just one file (SN-U10066.EGF). ALL the intructions seams to be in chinease. can't read them.
I have no idea at all what to do.
I'll be glad if you could help me.
thx !
BULBO
Post by BULBO » Wed Sep 11, 2013 12:16 pm
Hello I have a question to mr. safeda.I have installed Eplan P8 2.3 and startup always shows error 4521. In your opinion, where is the problem?
Bonavox
Post by Bonavox » Thu Sep 12, 2013 3:03 pm
I downloaded 2.3 version.
I downloaded SN-U10066.EGF file from Chinese web.
I applied the crack from 2.1 version (as shown in video tutorial) + new SN-U10066.EGF and it seems to work.
ePLAN Electric P8 + Windows 7 x64 bit
Only one thing - after applying the crack you HAVE TO STAY in Test mode. And then the ePLAN works.
At startup it always shows error 4521. So now I am waiting what will be after 30 days.
I ran this in VirtualBox, tried both x86 and x64 Windows 7 and both works.
THX
igoruha
Post by igoruha » Mon Sep 16, 2013 5:53 am
http://eplan-eb2.ys168.com/ - does not work... :(
cuervo2k
Post by cuervo2k » Tue Sep 17, 2013 2:01 pm
Can anyone reupload the crack to another server?
van8x10
Post by van8x10 » Mon Sep 23, 2013 9:27 am
Bonavox wrote:I downloaded 2.3 version.
The same to me, but after 30 days the EPlan doesn't work because no license is validated!
(sos)
van8x10
Post by van8x10 » Mon Sep 23, 2013 10:34 am
Dear Mr. PDLFFALF,
The file SN-U10066.EGF you posted with the license was only validated in 30days after 24 Aug 2013 . So to continue running the Eplan P8 v2.3, we need to change the computer system date to a day between 25 Aug 2013 and 22 Sep 2013. It is so unconvenient!
Do you have any solution for the problem?
Thank you very much!
(sos)
popi
Post by popi » Thu Sep 26, 2013 8:08 am
Please can anyone reupload the U10066.EGF file for version 2.3 to another server?
Original chinese page does not work
dmw15
Post by dmw15 » Thu Sep 26, 2013 11:27 pm
ссылка там уже не актуальна
van8x10
Post by van8x10 » Fri Sep 27, 2013 5:12 am
cuervo2k wrote:Can anyone reupload the crack to another server?
This is for you: SN-U10066.EGF validated in 30 days from 24 Aug to 22 Sep 2013
http://rapidshare.com/share/9F638849D4F ... 86B91B69A5
Better late than never! :wink:
New SN-U10066.EGF (validated in about 30 days from 26 Sep to 26 Oct 2013 :( )
http://rapidshare.com/share/4BF4191870C ... 8E9933059E
CD1234
Post by CD1234 » Thu Oct 10, 2013 10:39 am
Can anyone help me to get this installed? I have been trying to upgrade from an old 1.7 version, I first found the thread about the 2.2 version but could not get the crack to work I kept getting the error about dongle validation. I then found this thread and am still getting the dongle validation error.
BULBO
Post by BULBO » Wed Oct 23, 2013 2:41 pm
Hi all,
I have been researching api documentation for the version 2.3. Can you help me?
keli123
Post by keli123 » Wed Oct 23, 2013 8:00 pm
Hi guys could somebody give me the links for downloading EPLAN 21, because I really need it. Already have the latest EPLAN version but I got some projects from a friend of mine, and they are saved in .db file so I am not able to import them in EPLAN P8. :( :(
van8x10
Post by van8x10 » Tue Oct 29, 2013 4:03 pm
New file SN-U10066.EGF, validated until 27 Nov 2013
http://rapidshare.com/share/A862DEA4727 ... 0A3A01E234
mezippy
Post by mezippy » Wed Oct 30, 2013 11:45 pm
Hi van8x10
Great work, all working great but is it possible to add Pro Panel to the file or is this possible?
rapter
Post by rapter » Sun Nov 03, 2013 4:15 pm
Please add a torrent link, if you possible.
ilmisu
Post by ilmisu » Wed Nov 06, 2013 2:13 pm
hi guys, may I have the crack file? in the chinese website i cannot find it...where is it?
pconline
Post by pconline » Wed Nov 13, 2013 11:33 am
http://eplan-eb2.ys168.com/ there is no file.
Can you please upload again?
pconline
Post by pconline » Sat Nov 16, 2013 11:24 pm
Here i upload the file.
I just tried it it is working. But after 27 Nov 2013 it can be stop.
http://www.dosya.tc/server19/xXWEZd/Epl ... 3.rar.html
softsmoke
eplan EEC One 2.3.5
Post by softsmoke » Mon Nov 18, 2013 8:45 pm
hi
someone who have "Eplan EEC One 2.3.5" to generate drawings?
keli123
Post by keli123 » Fri Nov 22, 2013 11:58 am
Hi guys can somebody find me eplan 21 v4.30 :( : ( ?
luizmp
Post by luizmp » Sun Dec 01, 2013 6:54 pm
Guys, any news? Can't make this work...
Win7 x86 here...
Did everything.. but when start EPLAN... says that file "EplanCommon.LIT" couldn't be found...
Then.... it says that EPLAN Client Service coulnd't load a library... and syas that I should install version 9.1.11.44100 or newer... WHAT's that? Any1 could HELP???
Can't make this work....
pconline
Post by pconline » Thu Dec 05, 2013 3:22 pm
Reinstall Client,
İt will work then
luizmp
Post by luizmp » Fri Dec 06, 2013 12:42 pm
Sorry 'bout the delay... I'll try that!!
Another thing.. the Keygen doesn't change the 30day limit trial? I mean, does it only reset the counter?
cuervo2k
Post by cuervo2k » Mon Dec 09, 2013 8:03 pm
Does anyone have a valid license?
Wolf81
Post by Wolf81 » Tue Dec 10, 2013 1:04 pm
New links for download? Hotfile seem to be down...
prcwest
Post by prcwest » Mon Dec 16, 2013 9:09 am
Hello
does anyone have a new license for EPLAN Electric P8 2.3 please
juftis
Post by juftis » Mon Dec 16, 2013 11:10 am
Just use previous crack and change computer date to 2013-12-09 for example
romex
Post by romex » Mon Dec 16, 2013 3:32 pm
please reupload on another server hotfile is shut
asfi
Post by asfi » Tue Dec 17, 2013 1:31 pm
"Just use previous crack and change computer date to 2013-12-09 for example"
juftis - when changing the date it goes, but then the date occurs throughout the project and it is wrong ..
juftis
Post by juftis » Wed Dec 18, 2013 8:44 am
It is inconvenience, of course, but there are ways around this problem.
romex
Post by romex » Sat Dec 21, 2013 3:43 pm
i did all what's in the crack and video when i try to start eplan pro it says " a suitable dongle ios not available for the validation and when i press ok it says some problems with dongle and it asks me if i want to validate using a temporary license so i choose yes and the i should put some license what should i type there or did i do something wrong
OSCARFL
Post by OSCARFL » Mon Jan 13, 2014 8:08 pm
Hi everybody,,,,
I,ve W8.1 pro 64bits
someone has it working with this system
mvujica
Post by mvujica » Thu Jan 16, 2014 5:15 pm
I have managed to run eplan on win 8.1 x64, I used multikey.sys driver version 18.1.0 and new drivers from safe net Inc. HASP in disable driver signature enforcement mode in Windows 8.1, test mode does not work on 8.1 see http://www.howtogeek.com/167723/how-to- ... d-drivers/
Eplan 2.3 worked with new SN-U10066.egf fine till December 2013, than licence expired. I tried changing system date but that does not work. Does anybody have valid egf file?
mvujica
Post by mvujica » Sat Jan 18, 2014 7:38 am
Update:
I used older SN-U10066 and set date to April 2013 and now eplan v2.3 works on win 8.1 x64.
Changing date is inconvenient, I hope somebody post permanent licence as for v2.1.
